Question about iRiver H10 MP3 Player
Computer won't recognize
I am having the same problem as nera. My iriver H10 says that it is USB CONNECTED on the screen, but my computer doesn't acknowledge it. All it does is make three fast low not beeps but tones when I plug it in, rather than the low-high two-toned noise the computer usually makes when something is plugged into the USB port. Other computers recognize my iriver though...so any help with this problem would be greatly appreciated!!
  • 1 more comment
  • Anonymous Jul 01, 2008
    i have the same problem but i dont get your solution. i dont have a volume + button i have a scroll pad?...
  • Anonymous Aug 17, 2008
    i tried this with volume up on the scroll wheel but nothing happened
  • twinkle_moon Aug 20, 2008
    Same problem here - has anyone called Iriver Tech Support?
  • 8,596 Answers
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Posted on Jun 26, 2008
SOURCE:
IRiver H10 20 gb System files
check around this forum for an answer: users
Mar 04, 2009 | iRiver H10 MP3 Player
Pc doesnt recognize iriver ipod
first of all iriver is not an ipod
try to download the driver named iriverplus that shuld work
Jan 29, 2009 | iRiver H10 MP3 Player
Vista will not recognize iRiver H10 MP3 player
Try plugging in usb with the H10 turned off. Now, press the select button (with the round symbol on it) while turning the H10 on. This starts the player in 'emergency mode' and should be recognized by XP
Jan 08, 2009 | iRiver H10 MP3 Player
My iriver plus3 software does not detect my iriver h10 player
GUYS ALL YOU HAVE TO DO IS PUSH THE USB CABLE HARDER INTO THE DEVICE. IM A GENIUS!!
Oct 15, 2008 | iRiver H10 MP3 Player
H10 6gb
iRiver H10 - Missing System Files
You must be connected to the internet for this to work: 1.Download the MTP Firm Updater Utility from iriver website - iriverinc.com/support (Audio Jukebox --> H10) 2. Unzip file, run .exe file, go thorugh wizard (if you are not in mass storage mode, it will give you instructions on the wizard on how to change this) 3. Select Recovery 4. Finish going through wizard 5. disconnect iRiver from computer, and wait for it to update - your player should be good.
If the problem happens again, then uninstall Windows Media Player 11 from your computer and rollback to Windows Media Player 10 (you will NOT lose any songs by doing so).
-Tha Mp3 Doctor
Aug 26, 2008 | iRiver H10 MP3 Player
Iriver h10
This is straight out of p. 67 of the user's manaul, available on iRiver website (it may not work if the computer does not recognize the device):
Initializing H10
67
Additional information
Firmware upgrade
66
What is firmware ?
It is the operating system that works in the H10.
iriver provides you with the latest and best features through Firmware upgrade.
You can choose manual or automatic upgrade function.
For information on automatic upgrade, refer to the iriver plus instruction manual.
Manual firmware upgrade
Select [Option - Firmware Upgrade] from the menu in iriver plus.
Do not disconnect H10 during firmware upgrade.
Internet must be connected for the "Firmware Update" function.
Change to "Player must be connected to the PC for Firmware Upgrade function.
Note
Please initialize H10 player in the following cases.
All music, pictures, text, and data will be erased from the player during this initialization.
- if there appears to be corruption on the internal hard drive.
- if an error message displays and the player doesn't boot properly.
1 Connect the player and PC using the cable supplied with the player.
Open iriver plus.
Select [Option-Portable Device Initialization]. 2
Click [Start] to begin initializing.
Initializing H10
A
A
B
B
May 30, 2008 | iRiver H10 MP3 Player
Disappearing icon
i have the same problem but its not with an icon
Nov 30, 2007 | iRiver H10 MP3 Player
IRiver not recognized on any computer
Reacquire firmware from iRiver's website
Oct 18, 2007 | iRiver H10 MP3 Player
System files missing
I fixed this problem for my mate, here's what I did:
1) plugged in H10 to pc that didn't have any iriver software on it
a) I've read if you press the "o" button on the iRiver H10 when connecting it will just connect as a usb mass storage device
2) the H10 now appears as a mass storage device
3) right click on the drive, and select format ( I choose quick format)
4) install the iRiverFirmware updater from http://iriveramerica.com/support/mtpupdate/
5) when you run the updater, it found the H10, then asked if the device was from USA or Europe, mine was from Europe
6) It stated that the iRiver firmware was v0.0, and would install v2.51 (I've seen v2.53 available on the european iriver website but could not download it).
7) proceed with installing the updated firmware
8) on the last screen it says, unplug to complete firmware update - NOTE press Finish first before unplugging
9) switching on the iRiver it 'rebooted' a few times and then when the menu appeared, I connected to the pc and just dropped some mp3 files into the music directory and all was okay.
hope this helps.
Mike.
Sep 21, 2007 | iRiver H10 MP3 Player
IRIVER H10 20GB driver
You could also do the "emergency connection" trick. First, plug the USB into your computer, hold down the "o" button and push the reset button with something that has a point. The computer will recognize your h10 as a hard drive. The you can sync music to your player or just drag-n-drop it. you'll probably need to use a program like "Easy H10" to update your player's database. It's easy to use and it only takes a couple of minutes to update.
Apr 17, 2006 | iRiver H10 MP3 Player
iRiver H10 MP3 Player Logo
401 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Ekse
Peter Dragonetti
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
