Sinotec tv LED LCD TV :STL32VBF remote doesn't work and when pressing button at the back of the unit " key lock" message
ronpar
  • 27 Answers
SOURCE: child lock
frist see if the control panel on your tv works, if so then check and see if the eye on your tv is dirty sometimes they are hard to get to i took my pocket knife and cleaned mine or air in can should work. when the eye gets dirty on the tv it won't respond to the remote. hope this helps
Posted on Jun 13, 2008
daniel719
  • 240 Answers
SOURCE: LG lcd tv got "locked"
you need the remote.
any remote dot com is a good place to find one.
Posted on Jan 12, 2009
  • 90 Answers
SOURCE: DELL LCD TV locked up w/screen message "main menu locked"
without a remote and disabled keypad keys, the only other option, is to open the unit up a physically RESET the TV. remove the cables from the power board. i believe it has a phillips head screw. careful when you separate the rear cover from the front cover. there is a board screwed in the lower right corner, there is a connecter and a ground cable screwed to the rear cover. take your time prying on the rear cover. once you separated the two pieces, look for the light yellow board with your AC power source. Unplug it for 30 minutes and repeat the process. while your at it, also look down to the lower left side of the monitor. u should be able to see the keypad. press each button, while pressing, look to see if the button is pressing against the circuit board. it may be loose, try this test, u just may be able to fix your keyboard as well. hope this works out.
Posted on Jan 30, 2009
SOURCE: child lock will not allow my tv to turn on
i was programming my television by hand because i do not have a remote to my television and i accidentally set the child lock and now my tv will not turn on what can i do to fix my tvtv is on standby, standby light is on. can turn tv on with programable remote after pressing on button several times to set code on remote. press any function button and screen says child lock is on. can't get anywhere pressing any buttons, turn tv off with on/off button and tv goes back to stand by. don't have magnavox remote any ideas?
Posted on Feb 01, 2009
  • 53 Answers
SOURCE: Philips 47PFL3603D LCD TV - TV not responding to remote
One thing you can do is take your cellphone's camera, point the remote at the camera, and press a button. You should be able to see the infrared sensor firing.
If you can verify that, your remote's fine.
In this case, what you have is a bad IR sensor board. The part # is:
313926859182. Right now, there are so many of these things failing, that finding the original might be difficult.
Don't fear, though; it's a small part. And, best of all, it's cheap. Expect to pay around $5.00 for the part, maybe a bit more, maybe less, depending on the supplier.
Now, if you are handy with a power drill (fitted with an octagon/star bit for the back of your set), you can remove the 20 or so star-bit screws from the back of your television. Don't worry about putting the set on the floor. If your TV is on a stand, simply turn it around. You'll need to remove the stand screws, but you won't need to take the TV off of the stand.
Now that you've taken the screws out and removed the back cover, look in the lower left hand area of your set. You'll see a 4 inch long circuit board with 2 cables running to it. Pull the cables out (they'll come out easy). Remove the 2 star-bit screws.
One of the board's sides is under a plastic tab. Lift the board out of its slot from the other side.
Put your new board in, reconnect the two cables, reassemble the back and you are set to go.
Expensive repair for a few bucks and a better IR sensor.
This advice assumes that the control buttons (power, volume, channel) located on the side of the set still function. It also assumes you are able to use those buttons to power on the set and verify that you still have a picture on the screen.
Posted on Aug 02, 2009
I have 32 inch Sinotec LED TV. When I press any button on the control panel "KEY LOCK " appears . How do I deactivate the key lock without a remote control
default would be to unplug for 12 hours or sometimes there is a little pin hole reset hole type button very small that you have to stick a pin or paperclip end into on the front by the power button, hold it in for 5 sconds sometimes this will reset if not get a new remote a universal one.
Mar 07, 2016 | Televison & Video
The sky remote will not operate the volume on my grundig gu22dvd have tried all the usual things codes etc but still doesnt work
Try an auto search with the remote, you might have already tried it :
1. press tv
2. press select and the red button simultaneously untill the LED light flashes twice
3. Then keep pressing the TV and Standby buttons one after the other (not at same time) until the tv swithches off, then press select to store the code, the LED should flash twice to confirm this.
Once you have the remote working the TV, you can get the remote blink back the TV code so you can write it down for future reference.
  • Press the TV button on the Sky remote
  • Hold down Select and the Red buttons together for approximately two seconds until the LED blinks twice
  • Key in 9, 9, 0
  • Key in 1 on the numeric keypad and count the number of times the Red LED blinks. This is the 1st digit.
  • Repeat for 2 and 3
  • Note: no Blink = 0 (zero)
Sep 09, 2014 | Grundig GU22DVDPX 22 in. LCD TV
Have grundig gu22dvd tv and can not get volume on the sky remote have tried the normal things and have code but still doesn't work
1. press tv
  • Key in 9, 9, 0
I locked up my set by mistake need to unlock it and adjust channel for directv I lost my remote use the front keys which caused initial problem tried to adjust volume hit channel key
Hello
Tounlock your TV you surely need its remote control. Try to get it from somewhere, from any one of your friends, who own the similar model of TV, or buy it from RCA. After getting it try the following. You can unlock it.
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
  1. Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds.
  4. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
  5. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Sinotec:
If you have the original remote (RC-A07) for Sinotec tv, then press and hold down the Music button for about 10 seconds
Jan 10, 2011 | RCA TruFlat 27F520T 27" TV
SONY DVD REMOTE CODE FOR SINOTEC LCD
I just followed the instructions to program the Samsung remote (Press tv button then press and hold the power button whilst pointing at your TV and type in the code) ....I went through every code until my TV turned off....The code for my Sinotec is 75
Jun 14, 2009 | Samsung TXM3296HF 32" TV
Polaroid flm-2011 20 inch lcd television
 I will be happy to help.
  1. Turn tv on.
  2. Press and hold tv button on remote
  3. While holding tv button press and hold power(on/off) button, led light shold go off then back on after a coupke of seconds.
  4. Release both buttons.
  5. Aim remote at tv and press the power(on/off) button every 5 seconds until tv turns off.
  6. When tv turns off press the stop button at bottom of remote, that will lock in the code.
  7. Turn tv back on with remote and test all buttons.
Let me know if this helps and please rate this solution.
Lone99star
Jan 24, 2009 | Televison & Video
19 inch polaroid lcd tv model # TLA-01911c need polaroid code for universal remote
use codes:
10835
0835
835
it was working for leadcrayon of RCForums
Jul 27, 2008 | Televison & Video
Magnavox lcd tv
Setting the Sleep Timer sleeptimer.gif The sleep timer allows your LCD TV to automatically turn OFF after a given amount of time. You can set the sleep timer using your remote control or through the onscreen display (OSD).
TO SET THE SLEEP TIMER USING THE REMOTE CONTROL
1. Press the SLEEP button on the remote control. The sleep timer appears at
the top of your screen.
2. Press the SLEEP button one or more times to select the time you want.
3. Press the EXIT button to hide the sleep timer display. Your sleep timer is now running in the background. The sleep timer will be hidden after 10 seconds.
Turning On the LCD TV.
1. Press the MAIN POWER switch in the back of the unit (see Back Connectors for location). The Status LED on the front turns orange
and your LCD TV is ready to turn on.
2. Press the POWER button on the front of your LCD TV or on your
remote control. The Status LED on the front turns green.moz-screenshot-6.jpgmoz-screenshot-5.jpg
Dec 18, 2007 | Televison & Video
Sinotec 37cm tv
If you have the original remote (RC-A07) for Sinotec tv, then press and hold down the music button for about 10 seconds. This worked for me.
Oct 05, 2007 | Televison & Video
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Electro Med Services...
