Question about Whirlpool Duet GHW9150P Front Load Washer
Washer empties and strong putrid/ammonia like smell
You run the washer and when the washer cycle empties, there is a strong smell around the washer/in laundry room. The smell is very strong sort of like an ammonia smell. Clothes from the wash do not smell like this. Also, when the washer empties very slight bubbles appear in the left drain of my kitchen sink. If you run the dishwasher, very slight bubbles also appear in the sink drain. Situation is not washer and dishwasher being run at same time. Could it be related to septic tank. Should we have septic tank pumped. What else needs to be done?
  • 113 Answers
Most likely you do have drainage problems where it is backing up
Posted on Apr 24, 2009
Had a strong Amonia smell. Fridge wants to turn on but no cooling.
Strong Ammonia smell is dead give away for LEAK. Ammonia is the chief ingredient in the absorption type cooing system. Probably not economical to repair. For a second opinion, contact a Dometic Authorized Service Center.
Thanks for your question @ FixYa.com
May 31, 2011 | Dometic NDR 1292 Refrigerator
After a wash cycle, there is water sitting in the gasket around the door. This water smells after a few days. What is to be done?
Make sure the washer sits level front to back and side to side. Wipe away any water and leave the door ajar to let the inside dry out. If the whole washer insides smell, run an empty cycle with hot water, detergent, and baking soda to refresh. Hope this helps!
Oct 17, 2010 | LG WM-2277HW Front Load Washer
When i opened my washer it smells like mildew. How do I get the smell gone?  i noticed that my towels smell mildewy also.  Will this go away if i leave the door open all the time?
With the washer empty, put in a cup or two of bleach and then run a complete cycle with HOT water and the HIGHEST water level setting. When the agitation first starts, wait a couple minutes, then turn off the machine and let it soak with the bleachy water for about 20 minutes - then turn it back on and let it finish the cycle. If it's REALLY a strong smell, add some Simple Green, or some other NON-AMMONIA detergent to the bleaching process. (Mixing ammonia and bleach together is a MAJOR no-no. It gives off nerve toxins. Very bad.) If you can't find Simple Green, then add some dishwasher detergent. Not dish soap, like Dawn or Joy, dishWASHER detergent like Cascade or Electrasol.
That should help.
If it doesn't help, then unplug the machine, turn off the water supply, disconnect the hoses, and pull the machine away from the wall. Check UNDER the machine for the problem... If the machine, or the hoses, or the drain have been leaking, the mildew smell may be coming from your floor or walls as they rot... If that's the case, you'll have to find and fix the leak, and then repair your floor and/or walls.
Also, check your dryer vent connection... When your dryer is running, do you get hot, damp air coming out from behind it? If so, the vent pipe connecton may be loose, in which case you probably have a build up of dryer lint behind and under both macines.. This can be a fire hazard (especially if you have a gas dryer) and if combined with a little water from the washer, can start to mildew and smell. Reconnecting the dryer vent correctly and cleaning under both machines may solve the issue.
Hope that helps!
Jul 10, 2009 | Samsung WF337AA Front Load Washer
My Dometic has a very styrong smell of ammonia.
TURN THE REFRIGERATOR OFF AND DO NOT USE!!!!
You have a bad cooling unit. This is the entire assembly on the back of the refrigerator that draws the heat out of the box. You will have to either have the cooling unit replaced or buy a new refrigerator. The cost difference is usually around 200 to 500 depending.
Hope this helps,
Jeff
Jul 06, 2009 | Refrigerators
WF740 Hotpoint washing machine with bad smell from drum. Tried 95 degree wash but still smells. Door seal slightly blackened but I think smell is from drum too. Any help?
Wash it out with a strong solution of washing soda placed into the drum before you fill the machine
Ps
Run the machine empty through a full hot cycle then run the soda one
The first will soften the deposits and the second should help kill the bacteria that is causing the smell.
Reducing the load so that there is more agitation helps as well
Jul 03, 2009 | Hotpoint Aquarius WD640 Front Load...
Odor from Maytag dryer
Have you cleaned your vent lately? It might be excessively outgassing an ammonia smell because some plastic part that is getting too hot. If the vent is making it run hot or not exhausting it might stink up the room. Otherwise, it might just be stinky plastic. I don't know anything about your specific model, but I had a bread maker that was the source of a garlic & ****-like ammonia smell on the top cover after the plastic turned yellow from heat & age. Not a good feature for something that makes food and lives in the kitchen.
May 11, 2009 | Maytag PYE2300AY Electric Dryer
Large Appliances
start by cleaning out the filter in bottom,
remove the access panel bottom 3 screws , open filter , some excess water will spill ,
clean it out,
next clean under the rubber flap around front of drum.
run borax through a cycle.
run clorox in a cold cycle
the issue may be that the back of the drum is coated with waxy goop from using too much softener,
Mar 24, 2008 | Kenmore Elite 45986 Front Load Washer
Foul water odor after wash
There is always a littlee water left in the sump of a washer after it is emptied. If the washer sits unused for as little as 2 or 3 days it can have that odor. One thing that I do is add about 1/4 cup of ammonia after the washer is full of water. DO NOT USE AMMONIA IF YOU USE BLEACH IN THE SAME WASH!!! IT WILL CAUSE CLORINE GAS TO BE RELEASED!! If bleach was used in the previous cycle it will be ok.
Feb 28, 2008 | GE WPGT9360E Profile Harmony 4.0 cu. ft....
Bad Smell
this is caused by a build up of old detergent and limescale.there are some industrial strength descalers around.wpro descaler is one.add the sachet to the drum with no wash load.pour in a kettle of hot water(not boiling)and leave for thirty minutes.then put washing machine on a 60 degree cycle and allow to run right through.you will need to repeat approximately every three months
Nov 16, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Strong ozone-like burning smell
Sounds to me like the motherboard inside the unit is on it's way to thermal overload. This is a common problem with this particular model. You'll smell electronics burning and one day it'll quit altogether with a burst of smoke. I had this happen to me and I traced the problem back to a faulty triac (transistor-like device) that overheated and caused the circuit board and wiring harness to burn up from excessive current draw. I repaired my motherboard with a new triac ($6) and rewired the harnesses. A cooling fan on the heatsink of the board would solve this problem.
Nov 12, 2007 | Equator EZ 3612 CEE Front Load...
Whirlpool Duet GHW9150P Front Load Washer Logo
1,099 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
