HP c310a feed roller does not turn when trying to feed paper. Out of paper error when paper is present.
2 Suggested Answers
celibytes
  • 70 Answers
SOURCE: HP PSC 1350 printer won't feed paper
Check the gear on the left side of your printer where the disk encoder strip is attach,the gear is not holding the metal shaft your need to replace that gear. The problem is in the inner hole where the shafting is attached.
Posted on Nov 03, 2009
Errors with my Printer/scaner
Jessica:
This could be one of a few things... First, Windows 8 is a completely different animal from Windows XP! Try reloading your printer driver in Windows 8. If this doesn\'t work, you need to clean the paper pickup rollers at the front of the printer (where the paper first feeds into the machine. I use a Q-tip moistened (not sopping wet) with rubbing alcohol... gently scrub the whole pickup roller and then the feed roller next to it. Check carefully (with a flashlight) for any shards of paper that might be blocking the paper path. There is also a sensor flag (small finger of plastic) sticking up that the paper must hit to let the printer know that the paper is feeding through. If you do not see the sensor flag, it is either jammed or has been broken off when a piece of paper was pulled backward out of the paper feed area. First reload the printer driver, and try to print. If it doesn\'t print, check and clean the rollers and look for the sensor flag.
May 31, 2014 | HP 1050 Plain Paper Inkjet Fax
Unable to pick up papaer on tray 2 error 13.00
common faults for poor feeding on lj5200
1, feed rollers are worn - replace
2, sep pad is worn ( cant seperate pages correctly)- replace
3, paper empty tray sensor actuator arm snapped - unable to raise cassettetray- replace arm
4. paper feed roller fail to turn- feed unit clutch assy faulty- replace feed asseembly
5.paper tray pass guide out of position (blocking feed path) - pin that holds in place has snapped- replace feed assembly
Dec 13, 2013 | HP LaserJet 5200 Printer
Error paper jam
Hello Cassandra,
It sounds like you are having phantom paper jams. When the printer starts a print job and tries to pull a piece of paper but can't grab it the printer thinks there is a jam but there really is not. If the paper pickup rollers are worn down they are not able to grab the paper correctly to feed it into the printer which causes this type of error. The rollers are considered user installable and come in a kit with the rollers and the paper separation pad which keeps more than one paper from being pickup up at the same time. Installing the paper feed kit should clear up your paper feed problems. The paper feed kit is available here: http://www.ccl-la.com/catalog/product_info.php?products_id=342
I hope this helps.
BuddyMc
Aug 06, 2013 | HP CP3525N Color LaserJet Printer
When I try to make a copy the error code P flashes and paper in unit jams but I can still make copies thru bypass
P error normally indicates that you need to add paper. If there is paper in the cassette and the paper is raising up to the roller then the paper feed rollers are most likely dirty. You can clean the rollers with a cloth and some rubbing alchol. Also make sure you dont have a small peice of paper or something in the paper path causing the paper not to feed. Also listen when you press the prnt/start button and see if you can hear the paper feed clutch turning on then the paper feed rollers turning.
Jan 16, 2011 | Office Equipment & Supplies
A sheet of paper had remain in the cylinder
  1. Remove the rear cleanout from the printer.
  2. Gently remove any jammed paper or bits of paper.
  3. Close the HP Paper Feed Cleaning Kit software on the computer.
  4. Load plain paper in the printer paper tray.
  5. Press the Power button to turn the printer off.
  6. Press the Power button to turn the printer on.
  7. Try printing again. If the printer still does not pick up paper or if a paper jam occurs again, service the printer.
Other solutions customers found helpful » HP Paper Feed Cleaning Kit -- Clean the Paper Feed Rollers with the HP Paper Feed Cleaning Kit in Windows XP and 2000 » HP Deskjet, Photosmart, and PSC All-in-Ones -- 'Out of Paper' Error Message and the Printer Does Not Pick Up or Feed Paper » HP PSC 1600 and 2350 All-in-One Series Printers -- 'Paper jam: Press OK to continue' Message Displays on the All-in-One
Dec 15, 2010 | HP PSC 1610 All-In-One InkJet Printer
I am getting the error code 13.05.00 on an HP laserjet CP3505n printer. The manual says that it is a front door jam. The jam is occurring every other time I try to print a document. The document is being...
13.05.00 HP CP3505N
Problem Solve. Same error. Generally either a real or phanton jam from the paper tray or manual feed tray.
SOMETIMES the manual feed would work but always one corner on the paper turned down when printed.
Remove toner cartridges and bottom paper tray
Turn printer on its back. The black plastic flap (about 9" long) that hangs down a small amount (near the white main feed roller) had one end most likely the wrong side of the small metal rollers above it.
This flap should hang about vertical. One end of it is most likely the wrong side of the small mostly metal roller above it. Each End of this flap should be about mid way between the two smaller metal rollers.
WITH CARE take a timber skewer and carefully encourage this flap back so that both ends are in the correct place
Sep 02, 2010 | HP COLOR LASERJET CP 3505 N PRINTER
Hi! I have an HP officejet 5510 all-in-one product. Suddenly there is no paper feed anymore. I hear the motor (or something like that) to try to pick up the paper, but the paper doesn't move, and the...
Hi
Thanks for using FixYa. To clear the error with the rear access door or duplexer still removed, clean the paper rollers.
  1. Lightly moisten a clean, lint-free cloth with distilled or bottled water, and then gently wipe the large paper rollers inside the product. Manually rotate the rollers to clean all the way around the rollers, and then allow the rollers to dry.
  2. Check to make sure that all of the paper rollers on the rear access door or duplexer are present and not missing.
  3. Clean the rollers on the rear access door or duplexer using the same method used to clean the large rollers inside the product, and then allow the rollers to dry.
  1. Make sure that all of the rollers move smoothly.
  2. If a duplexer is installed, open it to check for any obstructions.
  • 1 - Latch on top of the duplexer
  • 2 - Duplexer cover
  1. Close the rear access door and make sure that it is securely fastened. If using a duplexer, make sure it is closed correctly and reinstall it on the back of the product.
If still the issue is not resolved please refer to this link.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Nov 03, 2009 | HP DesignJet 250c InkJet Printer
Paper jam in HP Laserjet 4V
remove the cassette you can see two or 3 roller down the printer clean that roller and try.....
Oct 07, 2009 | HP LaserJet 4mv Printer
Paper Jam Error
  1. Turn the printer off and open the access cover.
  2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
  3. Turn the printer on, load some paper, and press the Form Feed button.
  4. Watch the paper as it feeds through and try to determine where the jam is occurring.
  5. Check to see if all the rollers are turning.
    If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
    If not, there is probably a feed motor or a gear problem and the printer may require service.
  6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
  7. Turn the printer off.
  8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
  9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Good luck...
Sep 04, 2008 | HP Photosmart 8750 InkJet Printer
Paper feed error
Cleaning paper rollers
  1. Turn off the unit, then unplug the power cord.
  2. Remove the rear access door. See the picture above.
  3. Wipe the paper rollers with a lint-free cloth lightly moistened with distilled or bottled water. Rotate the rollers with your fingers to clean all the way around. Figure 7: Paper rollers c00109674.jpg
  4. Allow the rollers to dry completely, then replace the rear access door. Put the pins on the right end of the door into the holes on the right side of the rear access area, then snap the door shut.
  5. Plug the unit back in and turn it on.
Jan 12, 2008 | HP PSC 1210 All-In-One InkJet Printer
171 people viewed this question
jasbo
jasbo
