Question about Dryers
My Samsung dryer #dv203aew does not power up/no lights at all
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 142 Answers
If new it is not installed properly, power is turned off, door not latching completely...
nothing happens if you hold the power on button for five seconds?
Posted on Oct 17, 2013
My Samsung dryer DV218AEWXAA is not coming on. There are no lights on the dryer. We recently had the heating element replaced. What could be wrong with it?
Is ther power at the outlet? If yes, try unplugging dryer and plugging it back in. If that doesn't work, try unplugging and plugging back in while holding down power button. Good luck.
Mar 05, 2015 | Samsung Dryers
My Samsung dryer will not power on?
could be a number of things are lights turning on? first check plug for blown fuse if its av3 pin. try swapping for same amp fuse. next check drive belt and after that could be motor or start capacitor.
Jul 23, 2014 | Samsung DV331AEW Dryer
M-dv203aew samsung dryer take apart
You mean a teardown(this is the real term to take apart something), if you try Ifixit.com, you may find something.
Mar 09, 2014 | Dryers
Samsung dryer without power
What is the model number??
Jun 27, 2013 | Samsung Dryers
Samsung#DV448AGW/XAA check filter light on
Hello. #1-Use a vacuum cleaner with hose attached and vac the drum vent screen inside the drum. #2-disconnect AC power(unplug or switch off 220volt breaker) carefully remove hose from air duck of dryer and vac inside of dryer. Vac the hose and exhaust port. Reattach hose, reconnect AC power and test operation. #3-Problem still present the exhaust sensor or the (most likely) the exhaust fan not working properly. Good Luck!
Feb 28, 2012 | Samsung DV448AGE Gas Dryer
Have a Samsung gas dryer, power comes on and panel lights up. push start button and lights come on but nothing happens, dryer won't start???
What is the model number for the samsung dryer? Usually when this happens there are small thermistors that act as safety devices in the dryer that will prevent the unit from running. For example there is a hi and low limit thermistor that if either will faulty the unit would not run at all the lights would come on but the unit would not run to prevent the unit from getting to hot. Message me back your model number and I will find your schematic showing the thermistors in your unit. You would have to check these thermistors with a multimeter and perform continutity tests on them to assure that they are functioning properly. I await your reply Thanks Rick
Jul 04, 2011 | Samsung Dryers
I have a 1.5 year old Samsung DV203AEW Electric Dryer that no longer heats up. I've tried turning off the breaker, cleaning the lint and exhaust system, changing the setting and it is not producing heat...
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Dec 27, 2010 | Dryers
Dryers Logo
54 people viewed this question
Top Dryers Experts
