Question about Kenmore 500 3.5 cu. ft. Top-Load Washing Machine 2952
Timer sticks - Kenmore 500 3.5 cu. ft. Top-Load Washing Machine 2952
    Master:
  • 492 Answers
Try puffing graphite into the timer. Graphite can be found by any key cutting location.
Posted on Oct 15, 2013
Can a defrost timer " stick"/
If it is a mechanical defrost timer, then yes, it can stick.
See that pinkish thing in the photo below? It's a shaft that you can manually rotate if the defrost time is stuck.
See if you can manually rotate the timer and get it to kick the compressor on.
Oct 16, 2014 | Refrigerators
How do you reset timer for brinks 44-1011
stick end of paper clip or toothpick into reset home to reset timer to faCTORY defaults
This will clear memory settings that occur during manufacture and testing
http://waterheatertimer.org/How-to-set-timers.html
http://waterheatertimer.org/How-to-troubleshoot-timers.html
http://waterheatertimer.org/brinks-timers-and-manuals.html
Gene
Sep 13, 2014 | Hardware & Accessories
White knight tumble dryer timer sticking at 80minutes and not moving to cool clothes
Have had the same problem with the timer sticking on the model and the same time interval, now don't trust it's safe to use at any setting over 60minutes
Jan 06, 2013 | Abbaka White Knight 44AW Electric Dryer
Dualit toaster sticking timer
This a common problem for all dualit toasters after some years since the timer is also a power electric contactor and the cotntact are sticking. Their is not any solution and you need to replace the timer with new one. You can buy a new one from ebay which the prices are very good and we have also one link how to reach the elements which will help you reach also the timer.
Nov 28, 2011 | Dualit 40352 4Slice Toaster
I have a GE Timer Cat. No. 58280 and the paper or stick on dial with the settings has disappeared. Is there a dial that I could print and re-stick on to my timer? Thank you!
I think I found a solution: this appears to be a single-outlet version of GE 06655 Light-Sensitive 8-Hour Dual-Outlet Timer. I have tried matching the dial settings from the online image and it seems to work. There are seven settings on the timer switch. Set the pointer of the rotary switch dial so the ridge clicks into place with one end pointing precisely at the triangular switch position indicator. This is the Off position. Turn the dial one click clockwise, this is the Always On position. Then comes the 2-Hour setting, meaning it comes on at dusk and turns off after two hours. Then come the 4-hour, 6-hour and 8-hour settings. Finally, the Dusk-till-Dawn setting.
Nov 30, 2010 | General Electric Hardware & Accessories
I can't find the pins that the instructions refer to.
Woods timers:
http://waterheatertimer.org/Woods-timers-and-manuals.html
1) You posted question under Woods 59383 which has segments located around edge of dial.
These segments are pulled up to set OFF times.
Segments are left in down position for ON times.
2) Other Woods timers have tiny pins that stick up on the dial.
Pins are located on part of dial that rotates.
Get your glasses.
Run your finger across the dial and you can feel tiny metal pins that stick up.
Dial has 48 pins. Each represents 1/2 hour.
Use fingernail to move pins outward from center of dial.
Pins out = timer ON
Pins inward = timer OFF
Below are 2 EXAMPLES of Woods timer showing pins and segments
Nov 23, 2010 | Woods INDUSTRIES 59383 OUTDOOR MECHANICAL...
Sticks on all cycles
if it sticks on all areas of the timer you may be missing the timer motor voltage to operate the timer,otherwise the timer itself is bad
Mar 18, 2010 | Frigidaire FEX831CS Top Load Stacked...
STICKS on cycle, wash, etc. If manually moved
Do you mean the timer or control dial sticks. If so then it may be the timer mechanism itself.
Make sure that when you are skipping a turn on the timer that the machine is actually performing that particular task of the cycle. For example if the timer gets stuck before the drain cycle, and you manually skip forward to it, that it actually drains the water out.
If so then it is most likely a worn timer mechanism which sticks.
Ash
Oct 23, 2009 | Frigidaire Dishwashers
Timer malfunction
No recalls are listed on the Whirlpool/ Roper web site on ant timers. Try www.repairclinic.com , If your timer isn't the problem, you can send the part back for a refund.
Jan 02, 2008 | Washing Machines
Kenmore 500 3.5 cu. ft. Top-Load Washing Machine 2952 Logo
51 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
