Question about Refrigerators
If cockroaches are seen on inside of fridge,how to clear it and how to avoid in future
  • 3,904 Answers
If they are in the fridge they are everywhere. You need to get an exterminator in to get rid of them.
Posted on Oct 15, 2013
    Scholar:
  • 157 Answers
Clean the apartment, throw out all the food in the fridge. Clean inside of the fridge with ammonia water and bicarb. Keep it clean. Cockroaches love filth.
Need to dismantle coffe machine Delonghi Nespresso machine infested with cockroaches inside ??
I know that cockroaches will eat things like coffee beans, I would recommend cleaning everything completely and if you find other evidence of cockroaches calling an exterminator.
Jan 03, 2018 | Washing Machines
Electrolux/Simpson Dishwasher appears to have corrupt processor program - Is there a way to reflash the micro?
No. You would need to replace the board, though I've never seen this happen unless PCB is covered in cockroaches.
What is it doing? you may have a different problem causing the erratic behavior
May 14, 2014 | Electrolux Washing Machines
The fridge and freezer smell like a dead animal. cleaned the inside with bleach but still smells for weeks. model w10212088
There are two reasons for bad smells. 1. Long time not being used. 2. Lack of cleaning inside compartment.
Solution: Unplug fridge. Keep open fridge door. Dip a dry cloth in soap water and start cleaning each and every compartment. Keep freezer door also open. And then clean with another dry cloth. Keep both doors open for nearly 5 hrs. It will be enable fresh air to **** the smell inside fridge.
After 5 hrs close the fridge and run on empty for one hour. Keep food items after one hour. Please keep all food items closed vessel. Not only it's avoid odor but also be hygienic.
If you use to keep fish items in freezer, clean fridge once in a week.(Spray roo spray in the room when you keep fridge door opened. Don't spray into fridge.)Helpful.
Jan 30, 2011 | Whirlpool Refrigerators
The refrigerator has stopped running.
A fridge is divided by many parts. if the main motor dies then the whole fridge will not function. In your case the freezer is still working but the rest isnt. Still, i think you should have it checked out by a repairman to determine any inside problem and to avoid any future trouble.
May 20, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
There is a cockrach in the idicator of my IFB front load washing machine. How do i remove it?
this is always a problem with all electronic lcd when around little cockroaches an expert would take the panel off and clean as well as spray the unit from the inside but short of that he will event die and hopfully fall away from the lcd
Apr 20, 2010 | Indesit W 123 Front Load Washer
Touchpad is not working
Hello :
If touch pad has gotten wet, then allow to dry for several days. Avoid spraying cleaning liquid near touch pad.
Check for insect infestation. Insects (cockroaches most frequently) will appear under clear surface of touch pad or under readout window; they like the warmth of the circuit boards.
Place window mesh over vent to keep insects out.
good luck .
please rate !
Mar 29, 2010 | GE Microwave Ovens
Cockroach is entering in whirl pool refregirator
While you may have a problem with the point of entry on your fridge, your more pressing problem requires an exterminator. Roaches must have moisture to survive, and there are condensing lines on your fridge that provide that. It may take several treatments to eradicate the roaches, since when you kill the existing bugs, their eggs still will hatch. Also simply eliminating food sources for the roaches will not make them go away because a roach will dine on his dead buddies carcases.
Jun 19, 2009 | Whirlpool GS5SHAXN Side by Side...
U talk about cleaning the heat pump, well where is it and how do i get to it?
The heat pump is a retagular box inside of the unit. Remove the upper housing, locate the box (about the middle of the machine), remove the six screws on the bottom and clean with a hard brisseled brush. Note: in most cases the lines inside should also be cleared. Put the machine back together and run 3 FULL tanks of HOT water through the machine. (To avoid future problems when you are done using the machine take it out onto a step and run a full tank of hot water through the machine to clear the heater and the lines.)
Apr 15, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Error code
The L3 code refers to your scanner not moving. One thing you can check is the scanner lock, which is a clear round dial located under the scanner bed (where you remove your copies from).
I've seen that dial get bumped into lock position when copies are removed from the recieving tray. Alot of times, I'll remove the dial to avoid that problem in the future.
Apr 11, 2008 | Toshiba e-Studio162D Copier
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
