Question about Philips LX3900SA System
Loud noises My Philips LX3900SA has recently become very noisey and occasional crunching sounds when playing DVDs. I'm not very clued up with this sort of thing, but I'd say there's maybe something wrong with whatever makes the DVD spin, it sounds more like a blender than a DVD player at the moment! I would appreciate some helpful advice on how to fix this fault.
    Top Expert:
  • Philips Master
  • 41,697 Answers
There could be internal debris or the motor could be failing.
Posted on Oct 07, 2017
  • 123 Answers
SOURCE: lx 9000r wont play any dvds even previously played
You can try reseting the unit.
Reset the set to the default factory settings:
All the information stored
(programmes, time and date) will be lost.
1.
Disconnect the set from power supply.
2. Press and hold down "STANDBY•ON" on the set and reconnect the set.
3. As soon as "IS TV ON?" is displayed, release "STANDBY•ON."
Hopefully reseting it will clear whatever problem it is having and allow you to once again use your DVD player.
Hope this helps. Good Luck.
Posted on Apr 08, 2008
jaffa012001
  • 376 Answers
SOURCE: Region Code
1. Press DVD "OPEN/CLOSE" key on remote Control (R/C) or main set to open the DVD door (note: if no disc on tray, then no need to open the door);
2. Press R/C numeric key sequentially 9735 (entry code, no display on TV), enter DVD region code setup menu.
3. Press R/C "down direction" or "up direction" key to change REGION CODE,"0" is all code.
4. Press R/C "OK" key to confirm.
5. Press R/C "SYSTEM" key to exit DVD system setup menu
Posted on Aug 12, 2008
SOURCE: Wrong Region
I'm living in Brazil.
I have a Home Theather Systems Philips Model HTS3565D and when i put on a DVDs show me in display Wrong Region.
Here in Brazil the DVDs are 4 Region.
Can you help me to modify in Remote Control the Region for 4?
Thank you very mych!
Elaine
Posted on Oct 13, 2008
srinivasb81
  • 51 Answers
SOURCE: plays cds not dvds
Hai,
This is is due the lense and motor section problem, to resolve this issue you need to replace the lense and motor set.
Posted on Mar 20, 2009
SOURCE: my philips 3100 home theatre system will play
Change the motor disc spindle
Posted on Sep 09, 2009
New DVDs won't play without a loud buzzing sound, and a lot of glitching/jitter on the top half of the screen.
on the a/c adapter, (red yellow and white.. unplug your yellow connector and if that doesn't fix it, then plug it back in and unplug the white one.
Mar 23, 2014 | GoVideo DV2130 DVD Player/VCR
Loud crunching sound... Bearing?
Could be, a bad bearing makes a grinding noise, and if really bad, crunching noise. They also squeal sometimes, hard to tell without seeing it
Oct 28, 2012 | Chrysler Heating & Cooling
I have a 2001 VX Commodore Sedan and i have a real loud squeaky noise at the front of the motor which sound like it is coming from the belt for either the aircondition or the radiator??? I have taken
Hi Utiila, The problem you describe is most likely from a belt and it is not uncommon. The belt may be loose or need replacement. Regards John
Oct 14, 2012 | 1998 Holden VT Commodore
06 impala lt makes noise when rolling over 30 mph noise stops when car not moving
Did you recently change your tires? An aggresive tread design, like a mud and snow tread, can create road noise that becomes more noticable at higher speeds. Bad wheel bearings can also produce a "roaring" sound, especially in front wheel drive cars. To check them, jack the front wheel up and spin the tire by hand. It won't spin smoth and even, there will be some resistance and you will hear grinding or crunching.
If your transmission was low enough on fluid, it could conceivably make noise. Also check your U joints or CV joints for play. any play in them will make noise although it is usually accompanied by a feeling of looseness or "jerking", especially when making changes in direction or speed.
There can be a lot of reasons for noise, but start by checking these things first. Hope this helps.
Oct 23, 2011 | 2006 Chevrolet Impala
Loud crunching noise when spinning really noisey
The bearings of the basket, are damage, maybe due to water leaking and getting rusted, or maybe the shocks are also wearing off. expensive fix on the drum basket.
Jan 17, 2010 | Hotpoint WMA58 Front Load Washer
NEW DVD DRIVE AS MINE DOES NOT WANT TO PLAY NO DVDS NO MORE, IT SPINS THEN STOPS THAN SPINS THEN STOPS THEN SAYS NO DICS!!! CLEANED MAGID EYE BUT STILL DONT WORK
run ur pc in safe mode and insert dvd disc and then use this around 2min and then start ur window normally and ur dvd drive working
May 07, 2009 | Philips LX3900SA System
Mp3 sound
The problem might be from the earphones, you might need to try differnt ones. As much as I know there's no mp3 noise emphlafier. Thoth you can search for an mp3 player noise reduction plug in don't think there's one thogth.
Jan 19, 2008 | Philips GoGear SA178 MP3 Player
Sound
It is due to setting of Audio options in 5.1 and having only 2 speakers for stereo. For enabling conversion select "stereo" option from Memu under sub category "Audio"
Jan 05, 2008 | Philips DVD580MT DVD Player
Philips LX3900SA System Logo
37 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
