Question about Dryers
F2 error gorenje D60.35 - Dryers
Top loading Gorenje WT 52113, it stops a few minutes into the washing cycle, an error message comes up on the small digital display, looks like d02?
This washer only has f fail code, they recommend you contact svc person for repair. Fail code for F02: F2 Door lock fault detected The door lock on the washing machine has been detected as faulty or failed to engage correctly.
  • Check that the washing machine door has been closed correctly and is engaging the door lock correctly
  • Check wiring to door lock
  • Check door lock
  • Check wiring at control module or timer
Aug 12, 2016 | Washing Machines
Gorenje wa 72145 my son put washing up liquard in last night and the bubbles over flowed so i stoped the washer and empyed it. This morning iv gone to use it and f2 error comes up and wont work
  • Check door lock
Jun 09, 2014 | Washing Machines
Gorenje dishwasher e1 error
I know that this is an old topic but I have exactly the same problem. Did you manage to fix it?
Jan 26, 2013 | Gorenje GV 62110 23 in. Built-in...
Gorenje wa72145bk erro f2
it your door lock that faulty
Jul 01, 2012 | Washing Machines
Error code "E2" of Gorenje K357
E2 - reporting a problem with the sensor of the evaporator in the refrigerator / in isolation 10_9_2011_3_02_24_pm.jpg
Jun 03, 2010 | Gorenje K357 / 2 Bottom Freezer...
Gorenje B 8960 W, shows blinking times only, not
Same problem, anyone knows how to fix it?
Dec 31, 2009 | Gorenje Refrigerators
Gorenje WA132 F2 error
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 09, 2009 | Washing Machines
I have a Gorenje fridge freezer New Line bought in 1990. The fridge door compartment rails are cracking how can I get spare parts?
I found them in Bosnia, where New Line gorenje was made in 1990. Thank you for posting my problem.
Jul 06, 2009 | Gorenje Refrigerators
Dryers Logo
46 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
