Question about Miele Dryers
Softtronic t8303 the machine stops when drying clothes after about 1 minute and the alarm goes off until the machine is shut down. When i try to start the machine with no clothes in, it keeps going till the program is done.
    Novelist:
    Scholar:
  • 100 Answers
One possibility could be that you have a clogged LINT DUCT VENT to the outside.
It sounds like the damp sensor is working fine as when your unit senses no moisture, it shuts off. Soooooo, if the LINT DUCT VENT is partially clogged somewhere between the dryer tub and the outside of the house, then the sensor is sensing too much heat because the air flow is limited terribly somewhere. Take your entire LINT DUCT TUBING and clean it completely. Also, make sure you do not have any loops or droops in the whole ducting route. Make sure the lint duct tubing is not having to blow uphill anywhere in its route to the outside of the house. Dryers can not blow damp lint up hill very well and when folks try to make a dryer do this, the dryer will try, but damp lint will collect in a low spot, or in a hose route that has too many turns in it to the outside. Make the route of the hose LEVEL and even downward if possible. If it is a good idea to vent the hose out the side of the dryer, (to reduce turns, - remember they are death in a dryer) if possilbe. Not all dryers allow this. Look in your users manual for any suggestions.
kindly,
Jim
Posted on Oct 20, 2013
  • 210 Answers
SOURCE: On sensor dry, dryer remains at 1 minute for hours...will not shut off automatically
Check your venting. Insure it is not clogged as this can cause the unit to stick at 6min mark. Just before the cool down period.
Sgt Lauder
Posted on May 31, 2008
mrboo747
  • 24 Answers
SOURCE: Dryer gets hot when not running
Getting hot when not started is a great concern.
I have a few ideas why, but this is a fire hazard and I would suggest unplugging and either getting help or replacing.
That said, there here are a few suggestions.
1) if the element is shorted to ground, it will get power to one side of the element and heat though ground. This, again, is serious.
2) if it heats forever and doesn't get warm enough to dry, this is another indication of an element that is not working up to power. Not getting 230 across the entire element and not getting hot enough to dry.
3) Many times when a dryer runs too long, the air flow if blocked by the vent being plugged or some plug withing the dryer itself.
Again, I am very concerned about this problem and suggest you not use it until it is repaired. If you want to check the element, it is fairly easy, but unit will need disassembled.
Mr Boo
Posted on Nov 30, 2008
  • 5 Answers
SOURCE: Whirlpool Ultimate Care II Quiet Dry I, LEQ9508PWO
I would suspect the timer is on it's way out the door. Do you have any areas the timer has dead spots? Check the exhaust for any plugging also.Is this only on a first time start up or is it after this dryer has been running? If after running it could be a high temp sensor, that by the time you are playing around with it, the temp has changed.
Posted on Jan 25, 2009
  • 46 Answers
SOURCE: I need help with my Kenmore Elite electric dryer
might be a bad timer
Posted on Jun 27, 2009
Illeagle
  • 525 Answers
SOURCE: The dryer stops heating before the clothes are dry.
Maytag gas dryer MDG7600aww, (Model number corrected). Below is a link, courtesy of www.repairclinic.com showing the parts breakdown and disassembly procedures.
http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
This link shows the most likely cause of your issue.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg7600aww-%3d%3di3479&PartID=3479
This link shows the next likely cause of your issue. Remove the front panel and inspect the sensor bar which is located at the 4 o'clock level on the drum bulkhead, ( see the first link for location). Ascertain that 2 wires are connected to it and that black sensor bar is not cracked or broken.
This link will offer more assistance if the above 2 items check good.
http://www.repairclinic.com/0088_8_1.asp#Subtitle_2
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg7500aww-%3d%3di516693&PartID=516693
Posted on Aug 24, 2009
2009 Kenmore Dryer. Wondering why it seems to only work on 1 drying cycle? Everytime I try to put it on another cycle all the lights flash and beep...and nothing...
sounds like the washer might not be spinning the water out of the clothes good enough . 1 60 minute cycle should dry them more than dry enough .
Oct 18, 2015 | Kenmore 8804 5.8 cu. ft. Electric Dryer
Samsung model dv5451 cooling light stays on
I am assuming when you turn it on, after couple of minutes goes off.
If you are on sensor drying and have no load or too little, then clothing might not touch the sensor enough (to show it is wet), and therefore microprocessor shuts unit down "thinking" everything is dry already. Try time dry.
Alternative: defective main board, sensor, wire harness.Call for service.
Dec 22, 2014 | Samsung Dryers
The dryer stopped working for my hwd1000 --
Check your belt. It may be shot. And that will cause your machine to do that. The heat will still work but your clothes will not dry.
Jun 14, 2017 | Haier HWD1000
How to set alarm time on bose wave radio
To set the Alarm 1 time - On the control panel, hold down ALARM
SET and press TUNING up or down. The time display changes slowly at
first, then more quickly. Release TUNING to stop.
On the remote, press TIME. The ALARM indicator flashes. Press
TUNING up or down. The time display changes slowly at first, then
more quickly. Release TUNING to stop. Press TIME to return the display
to the current time.
To turn on the Alarm 1 function - Press ALARM MODE or
ALARM in sequence to select the mode you want: tone, radio,
both tone and radio, or off.
For tone only, press until the indicator lights.
For radio only, press until the indicator lights.
For tone and radio, press until both indicators light. When the
alarm goes off, the tone sounds. Press SLEEP/SNOOZE to turn the
radio on. Press SLEEP/SNOOZE to pause the radio for 10 minutes.
To turn off the Alarm 1 function - Press ALARM MODE or
ALARM until the display shows no Alarm 1 mode indicators.
To check the Alarm 1 setting - On the control panel, hold down
ALARM SET to see the wakeup time.
On the remote, press TIME to see the wakeup time. Press TIME again to
return the display to current time.
To wake to a preselected radio station with Alarm 1 - While
holding ALARM SET, press the PRESET button for the station you want
(change between AM and FM if needed).
Dec 02, 2010 | Bose Wave radio/CD remote control -...
My dryer timer counts down to 7 minutes and then continues drying
replace the sensa board and make sure the wires on the sensors are ok
Jun 07, 2010 | Whirlpool GEW9250 Electric Dryer
Turns off after a few minutes
sounds like your motor is overheating or going bad. sometimes lint built up around the motor can cause it to overheat. or the motor is dying.
Aug 31, 2009 | Kenmore 73952 Gas Dryer
Whirlpool Calypso stops at 26 minutes and throws ob code
first you need to clean your washer
run the washer with no clothes; add 1 cup vinegar, that will cut the soap residue from the hoses do this on hot wash hot rinse
then when you wash your next load of clothes; fill the tub about 1/4 full, add the soap, turn the agitator to disolve the soap, then add the clothes
this problem happens also if you are using too much soap or a heavy duty soap such as Tide.
May 20, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Thin twin stacked washer/dryer...dryer won't stay on
My twin stacking whirlpool washer/dry. The timer switch kicks on but does not dry clothes kicks off after 5 mins but, clothes still wet.
Nov 12, 2008 | Whirlpool LTE5243D Top Load Stacked...
KITCH AID DRYER
YES MY DRYING IS HEATING UP. THE TIMER WILL NOT SHUT OFF AND STOP THE MACHINE FOR DRYING IF USE ANY TIME.
Oct 14, 2008 | KitchenAid KEYS850LQ Electric Dryer
I'm sorry to hear of your problem with your LG dryer. I have one as well and it works very well. I found my owners manual. It has a web site WWW.LGSERVICE.com. They also have a toll free number 1-877-714-7486. Perhaps either of these will help you find an answer. Good Luck
Dec 03, 2006 | LG DLE5932W Electric Dryer
Dryers Logo
166 people viewed this question
Top Miele Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
