Question about Freezers
Bosch kgu3201gb freezer
Hi, KGU3201gb fridge freezer, bleeps once every minute, please help me fix it before I kill it or myself. Thank you.
    Master:
  • 492 Answers
Try unplugging for 10 minutes to reset the cycle.
Posted on Oct 18, 2013
Hi, got a fridge freezer, the freezer door is not closing -please help
check if noting broke in the door locking mechanic. Or check if not too much ice is pressing the door open.
But if you don't hear the click, check the lock.
Feb 26, 2015 | Bosch Kge Series Fridge Freezer Door...
We ve had the Bosch fridge-freezer (KGU3201GB/01) for about 10 years. Suddenly this morning the freezer started losing temperature, which rose to -13 degrees and the alarm went off. We put the...
Hi Robert, sounds like the unit is not defrosting.
Try this to indicate defost issues.
1. relocate food in the freezer, turn the unit off for 2 days and leave the door open, this will allow total defrost.
2. clean, then restart unit with door closed, after and every 2 hours check temp, I feel you may find it will get to its operating temp reasonably fast and should stay there.
If this is the case, I suspect the defrost heater element has failed and needs replacing, this is the most common cause of your type of issue.
Hope that helps and please dont forget to vote. Regards Russ
Mar 19, 2011 | Bosch 3.2 cu. ft. / 91 liter Upright...
Hi, I have a Bosch freestanding freezer (GSD14A20GB) and recently defrosted it using a hairdryer, I now know that this was not a good idea as the following occurs when I switch it on: -Freezer appears to...
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Apr 04, 2010 | Freezers
Bosch fridge frezer
gas is sealed for life....sounds like it is auto defrost mode.leave switched on. after a full manual defrost. for at least 24 hours to settle down keep door shut... then check. should reset itself.make sure all vents,drains are clean.
Feb 14, 2010 | Freezers
Bosch Fridge Freezer KGU3200GB/01 alarm beeping temp rising
Jan 26, 2010 | Freezers
Admiral GC 2027 HNKBS
Hi i had the same problem, if you ring Maytag on 08444990101 they are the uk supplier for admiral fridge freezers. hope this helps
Mar 29, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
My Bosch frostfree fridge freezer keeps icing up!
My Bosch Frost Free Fridge Freezer did the same thing - Ice forming in the bottom of the freezer area after a few days.
It was caused by a blocked drain pipe - When the freezer does the de-frosting cycle, the melted ice drips into a tray and tehn runs into a dish on top of teh compressor, through a pipe.
If this pipe gets blocked, the de frosted ice overflows from the tray and overflows into the bottom of the freezer and then re-freezes !
To fix, pull the freezer away form the wall, locate the pipe that runs to the dish on top of the compressor and blow through it - This should clear it. Alternatively, from inside the freezer compartment, pull off the cover at the back, but the clips holding it on will probably break off, as mine did ! You can sort of push the cover back on and re-fit the food draws.
Feb 23, 2009 | Freezers
Faulty Fridge freezer
I suspect you may have a faulty compressor! Do you notice if the compressor starts?
Feb 05, 2009 | Bosch Freezers
My hotpoint ff187e fridge/freezer keeps bleeping and flashing how can i fix this? it is only 18 months old.
Turn the second knob at the top to off (freezer knob) turn the fridge freezer off. Then turn it back on. That may sort it. Or you may need to totally defrost the machine as there could be some ice blocking some vents. May need to remove the back panel of the freezer for this (inside).
Jan 31, 2009 | Freezers
Bosch Fridge Freezer Freedom Classixx
Hi there seems that the power supply unit has a fault and will need replacing suggestion to call an engineer.
Thanks J
Jan 01, 2008 | Freezers
Freezers Logo
90 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
