Question about Samsung Np305v5a-a09us 15.6" 6gb 500gb Quad Radeon Laptop
Samsung NP Series NP305V5A Laptop Keyboard dont work
    Habit-Forming:
    New Friend:
  • 110 Answers
You should try to clean the point of the flex that connects onto the motherboard with spirits.
Posted on Oct 23, 2013
3 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: how do i change the settings on the laptop samsung np 519 keyboard the letter k is 2 at moment
Examine your keyboard to ensure your "Number Lock" key is not activated.
This activation is indicated by the key being lit up.
If the key is activated, press it to deactivate the lock.
The number lock key will deactivate an entire segment of your keyboard
Start, click Run, and type regedit to open the Windows registry editor.
In the registry, open the below folders.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon.
hope this helps
Posted on Nov 01, 2012
Geekman
  • 32281 Answers
SOURCE: samsung NP-R480l laptop not charging
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Posted on Mar 02, 2013
Laptop key popped off
restart everything(each part) individually
Feb 16, 2014 | Samsung Q430 Laptop
Function keys are not working except for sleep mode - fn+esc
Hi!
You can control it. just go to your desktop."right click", choose the screen resolution. Look for the "display" and the "adjust brightness". Or you can work into it in control panel.
Jan 22, 2014 | Samsung US keyboard for RV510 RV508...
My samsung np-n148 keyboard many keys not working
Pull out the key, check if there is anything interferring.
Try different USB port.
Try a USB to PS2 converter and use the PS2 port. (Costs about $1.50)
All else fails, get a new keyboard.
Oct 15, 2013 | Samsung Us Layout Np-n148 Np-n150 N148...
Webcam working skype settings
uninstall it and reboot, let win reinstall it
start
right click computer
manage
device manager
find the cam in the list
right click it
uninstall
close everything and reboot
Oct 12, 2013 | Samsung Series 3 15.6 Np305v5a-a04us...
Mother manaul samsung laptop np305v5a-a0dus
Hello you can download the manual here at samsung:
http://www.samsung.com/us/support/owners/product/NP305V5A-A0DUS
Adobe reader, is needed to read the content, when you have downloaded the file.
Good luck
Jan 28, 2013 | Samsung Computers & Internet
Can't get wifi connection, stays in airplane mode
Hi There,
have you looked at your wifi adaptor , you might be missing the drivers that is why it is on flight mode?
also check the wifi switch on the side of the laptop make sure it is not switched off.
hope this helps .
Dec 29, 2012 | Samsung Series 3 15.6 Np305v5a-a04us...
Hello, I am looking for the basic instructions for replacing the keyboard unit on a Samsung NP-R720 laptop. I am not a computer novice ! The first computer I owned, I built in 1983, but there can be some...
First, not that the keyboard is held by two long screws (as marked in the picture below), which are to be opened from the bottom.
After removing the battery and bottom screws, you have to remove the top cover (near LCD hinges, above keyboard). After that you would be able to pull the keyboard and remove the connecting ribbon cable to detach it. Below is a video for Laptop keyboard replacement.
Also, have a look at some Similar Laptop Disassemble Guides
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 12, 2011 | Computers & Internet
Samsung Np305v5a-a09us 15.6" 6gb 500gb Quad Radeon Laptop Logo
42 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
