Question about Sharp R-244 800 Watts Microwave Oven
Set time press manual - Sharp R-244 800 Watts Microwave Oven
How do I set the clock on a Panasonic microwave nn-e271wm
To set the clock, you need to press Timer/Clock twice. Then press the 10 Min keypad several times until you get to the correct hour. Then press the 1 Min keypad as needed to get to the closest 10 minute period below the current time. Finally press the 10 Sec keypad several times to reach the current time. Then press Timer/Clock once to exit the time set feature.
Panasonic has the manual for the NN-E271WM on their downloads page: http://www.panasonic.eu/Downloads/en_GB/popup.html . Enter the model number and then click View. You will need to accept the Panasonic Terms Of Use and click View again. The direct link to the manual is currently http://tda.panasonic-europe-service.com/docs/2z5845f124z3z39cabz656ez706466z25z9709ff8b3ba329b0c218b9bf248a6442e93022b3/tsn3/data/ALL/NNE281BMBPQ/OI/912715/NN-E271WME281BME281MM.pdf . See page 21 in the manual (23 in the PDF) to see the procedure.
I hope this helps.
Dec 05, 2016 | Panasonic Microwave Ovens
How to set clock
See here (
GE JNM7196SFSS Use And Care Manual About The Other Features Cooking... ) Paraphrasing from the site:
  1. Press the [Settings] button 2 times.
  2. Enter the Appropriate time of day
  3. press [Settings] to indicate AM or PM
  4. Press [Settings] to accept the time.
You can find both the owners and the install manual here (
GE Microwave Oven manuals ) Scroll about 2/3 down the page, looking for just JVM7195.
Good Luck!
Nov 03, 2015 | GE Microwave Ovens
Setting the clock on a microwave what is the last action after setting the time. Everything I've tried results in the error message coming up.
According to the manual this is how to set clock.
To set the clock, press "Clock" once or "Timer/Clock" twice (depending on your keypad).
The colon symbol (:) will flash.
Enter time of day. The time appears in the window; the colon continues to flash.
Press "Clock" or "Timer/Clock" again - colon stops flashing; time of day is set.
If you need the manual it is on link below.
http://service.us.panasonic.com/OPERMANPDF/NNH624-SET%20UP.PDF
Good Luck
Nov 08, 2010 | Panasonic NNH965BF Microwave Oven
The clock is flashing all zeros - cant set it
Press: Stop cancel
Press: Clock or Autostart (depending on model)
Set time
Press clock or autostart.
Should have the time set......
If this is too generic pleae provide a make and model and I wil see what the manual says verbatim.
Kelly
Aug 21, 2010 | Microwave Ovens
Goes to military time
According to the manual:
Press "Clock" pad once to set clock for 12 hour time clock
and
Press "Clock" pad twice to set the time for Military time.
I'm not sure what you mean by "goes to" military time.
Is that after you've already set it for a 12 hour time clock?
Jul 22, 2010 | Emerson MW8107WA Microwave Oven
I need an instruction manual
press both Hour and Min buttons simultaneously for two seconds. You will hear a beep and the timer will reset. Don't press any other buttons for twenty seconds. The display will now change from the time to the clock. Press the hour botton. The hour digit will blink. Use the Min button to set the hour. Once you have the right hour, press the Hour button again, and the minute digits will blink. Press the Min button to set the minutes. Once you have the correct time, press the hour button one last time and your time is now set.
Sep 16, 2009 | Microwave Ovens
I NEED THE INSTRUCTIONS ON HOW TO SET THE CLOCK ON MY MICROWAVE
To set the time just press CLOCK, then press CANCEL, then enter new time setting and press CLOCK again.
Apr 07, 2009 | Microwave Ovens
How do I set the power to 50%?
If you have "Power" botton on m/w
1. set time for time cook
2. press power botton
3.set 50 and hit start
Nov 30, 2008 | Microwave Ovens
How do i set clock for time of day
You can download your owner's manual free here.
From the manual:
SETTING THE CLOCK - When the microwave oven is plugged into an outlet, the oven will display " 0:00 "
1. Press the CLOCK button; the hour digit will blink
and the clock indicator will light.
2. Press the number keys to set current hour.
3. Press the number keys to set current minute.
4. Press AM/PM to choose AM or PM.
5. Press the CLOCK button again; the display will
show the present time. After the clock has been
set, the time will appear with blinking colon,
unless the oven is cooking or defrosting.
NOTES:
- To reset the present time in the display window when the oven is off, press the CLOCK button and
reset.
- If you make a mistake when setting the time, press the STOP/CLEAR button.
- To recall the actual time while the oven is cooking or defrosting, simply press the CLOCK button
and the display will show the actual time for three seconds.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 03, 2008 | Emerson MW8107WA Microwave Oven
Sharp R-244 800 Watts Microwave Oven Logo
29 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
