Question about Fargo DTC525 ID Card Printer
My printer is reporting an head error resistance
Does not print
Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached. To reattach the cartridge, turn on the lid of the printer and then remove the cartridge from the printer head. Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report. Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
Nov 26, 2010 | HP LaserJet 1320 Printer
RX630 not printing - changed all cartridges, cleaned head multiple times, master reset. nozzle check - print head moves over paper nothing prints. Win 7
It seems simple enough, but this is one of the most effective ways of fixing printer cartridge error. Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached.
To reattach the cartridge check the following steps :
Nov 15, 2010 | Epson RX630 All-In-One InkJet Printer
When trying to print a document I keep getting an error message stating, "Cartridge Error consult user guide
Nov 15, 2010 | Office Equipment & Supplies
HOW DO I CLEAN THE INK HEAD FOR BLACK ON MY BROTHER MFC 210C
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Nov 10, 2010 | Brother MFC 210C All-In-One InkJet Printer
Will not print
Oct 26, 2010 | Lexmark Z1420 Printer
CODIGO DE ERROR 2110
The errors starting with the numeral 2 are usually print head failures.
HP reports this:
21:10 error code Explanation A service station failure has occurred. Recommended action Please call HP for technical support to troubleshoot the problem. Click here for information on contacting HP Customer Care.
Jun 15, 2009 | HP Designjet 70 InkJet Printer
Printer Canon i850 7 red flashes
Inkjet printheads are electrical devices and subject to failure. The error report may be indicating the failure of one or more of the delicate resistive elements in the head. Unfortunately, the electrical drivers failing would probably give the same indication. BTW, alcohol isn't the best choice for cleaning clogged printheads; window cleaner dissolves ink much better.
Jun 15, 2009 | Canon i850 InkJet Photo Printer
Prints photos with yellow horizontal stripes.Hv downloaded HP printing diagnostic utility and no errors were reported. If just using scanner to copy photos, prints fine but copying photos in library p
go into the printer and do a test print. start>printer & faxes>right click on the printer in question>properties>printer preference button> test print ... try the printer's own test print. This is usually caused by a poor print head, low ink, poor cartridge or the need for calibration. Look in the maintenance tab in the printer properties for head cleaner, jet cleaner etc. This also happens with refill ink cartridges.
Apr 28, 2009 | Office Equipment & Supplies
E-90 error at epson stylus pht 250
I see now that your printer is an Epson Stylus Photo 250. The error E90 is not defined, other than "contact Epson". However, other users have reported that clearing an obstruction fixed the problem. Try this.
Turn the printer on, and as soon as the print head starts to move, pull the power lead out of the printer, or turn it off at the mains. The print head should now be free to move by hand. Gently move it backwards and forwards to see if there is any obstruction. Look into the print head parking area on the right - does anything there appear to be causing an obstruction? Report back.
Jan 28, 2009 | Epson Stylus Photo R220 InkJet Printer
Error report, unable to Clean.
Please be more specific:
What model printer ?
What application generate the error?
Is the printer communicating with the computer?
Does it have ink?
Are the heads plugged really bad, requiring mechanical cleaning
or replacement?
Is the the ink spatton full, requiring servicing ?
Jul 18, 2008 | Brother Office Equipment & Supplies
Fargo DTC525 ID Card Printer Logo
27 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
