Question about Jerdon Deluxe Lighted Makeup Mirror JGL9W
I have the tri fold mirror with 4 settings, on the left side, the setting has moved from daytime to office. Can I fix this so I can have daytime for both sides?
  • 2,113 Answers
There is no way to know that unless i were there in person and could examine it
Posted on Oct 15, 2013
Volvo s80 2011 left and right mirors do not opened when unlocking the doors.
Has the mirror been knocked or damaged ? Does it make any sound or try to move ? Does it work when set to automatically fold when locking the car ? Does the mirror adjust OK ? If it does then it would appear that the electrical connection is Ok and its probably a motor/ servo fault in the mirror arm/bracket. Alsp easiest option is there a fuse for them if so check it.
Dec 21, 2016 | 2011 Volvo S80
Tip
On truck the 2004 GMC Truck Sierra you have on the dash a driver information...
Put the control (on the driver door for your side view mirrors) onto the passenger mirror position put the car in reverse, mirror tilts down and shows you the curb! (this only works on some models like the 3.0 not sure of what year of 1.8t)
on Mar 14, 2009 | 2006 Audi A4
Jeep Grand Cherokee 2013 side mirrors fold out sometimes when you start the Jeep
its in warranty, why not get them to fix it.
why ask us, ask them, its fully covered..
and all that is programmable, and mostly not adustable
if the operator guide shows no settings, that means its a dealer
only change. if at all.
The factory tool is like $10,000 so no body here has one..
did you read the operators guide yet>? in the glove box?
Mar 09, 2014 | 2013 Jeep Grand Cherokee
2004 ford expedition eddie bower
For the rear window, just need adjuts the both slightly...
Check the next procedure to Power Mirrors...
Diagnosis & Testing
The exterior mirror control switch receives power through circuit SBP12 (GN/RD) and ground through circuit GD143 (BK/VT). The exterior mirror control switch uses circuit CPM23 (GY) as the common circuit for both exterior mirror up/down and right/left movement.
  1. Possible Causes:
    Fuse 12 (7.5A) (SJB) An open in circuits CPM23 (GY), SBP12 (GN/RD) or GD143 (BK/VT A short to ground in circuit CPM23 (GY) A short to voltage in circuit CPM23 (GY) Exterior mirror control switch.
  2. Checking the voltage at the mirror switch:
    Key in OFF position. Disconnect: Exterior Mirror Control Switch C527. Key in ON position. Measure the voltage between ground and exterior mirror control switch C527-1, circuit SBP12 (GN/RD). Voltage should be greater than 10 volts.
  3. If voltage is greater than 10 volts, check that fuse 12 (7.5A) is OK. If OK, REPAIR circuit SBP12 (GN/RD) for an open.
Exterior Mirror Motor Synchronization
NOTE This procedure must be performed any time the power folding mirrors are manually folded in or out, or if the position of the mirror case has been moved without using the mirror control switch.
NOTE If the power folding mirrors are folded or unfolded continuously (6 to 10 cycles), the power lockout feature will disable the system for 2 minutes to prevent damage to the power fold motors. After 2 minutes have elapsed, normal operation will resume.
  1. Set the mirror control switch to the CENTER position.
  2. Use the mirror control switch (press rearward) to automatically cycle the power folding mirrors in and out 4 times.
  3. When an audible popping sound is heard, the power folding mirror motors are synchronized.
    NOTE It may be necessary to cycle the power folding mirrors in or out up to 4 times before they are synchronized.
Removal & Installation
Motor
  1. Before servicing the vehicle, refer to the precautions section.
    NOTE If equipped with power folding mirrors, they must be synchronized any time the mirrors have been folded or unfolded without using the mirror control switch. Refer to synchronization procedure.
  2. Position the exterior mirror glass in a downward position to obtain a gap at the edge of the mirror.
    CAUTION Place a shop towel between the exterior mirror glass and the hand to avoid personal injury in the instance of glass breakage.
  3. Insert a flat-blade screwdriver between the mirror glass tabs and the mounting plate, and rotate to separate the locking tabs from the mounting plate.
  4. Carefully pull the top edge of the glass away from the exterior mirror housing.
    0996b43f802029e0.jpg Fig. Mirror Glass removal shown
  5. If equipped, disconnect the heated mirror electrical connectors and remove the glass.
  6. Remove the 3 exterior mirror motor screws and exterior mirror motor.
  7. Disconnect the electrical connectors.
  8. To install, reverse the removal procedure.
Switch
Expedition Trim Panel Removal
NOTE The door glass must be completely raised.
  1. Remove the window control switch plate.
  2. Remove the door handle bezel.
    WARNING To avoid damage to the door trim panel, lift the door trim panel by pulling directly upward on the armrest to disengage the panel clips.
  3. Remove the two bolts and three screws, and remove the door trim panel.
  4. Remove the finish cover to access the two center screws.
  5. Disconnect the electrical connectors. Navigator Trim Panel Removal
  6. Remove the door handle bezel.
  7. Use service notch.
  8. Remove the two bolts and three screws, and remove the door trim panel.
  9. Disconnect the electrical connectors.
  10. Depress the locking tabs and remove the exterior mirror control switch.
  11. Remove the exterior mirror control switch.
If you dont want waiting more time for the Owners Manual, can check here this choice 2004-Ford-Expedition-Owners-Manual
Hope this help.
Apr 23, 2010 | 2004 Ford Expedition
Electric folding door mirror not working
Try helping the mirror move by hand. The pivot rusts from not being used. Gently work it around.
Feb 03, 2010 | 2004 Land Rover Range Rover
Electric mirrors (both sides) not returning to central position but folding all the way in/out. Is this something I can repair or fix myself?
Hello. You may or you may not have a repair to make. Let me explain. What you may be experiencing is a feature whereby you can fold the mirror in when in a tight spot. This function only occurs when the rocker switch is set in the middle, as opposed to the left which then allows you to control the driver's side mirror or the right which allows you to control the passenger side mirror. Try putting that power mirror rocker switch in different positions and see what happens, you can't break it.
That said, if indeed you can't get the power mirrors to behave properly then you will have to replace that rocker switch. Regards, Joe
PS please rate my answer. Thank you.
Jan 15, 2010 | 2000 Chrysler Grand Voyager
How do i set my wing mirrors
if you wish to "set" the seat and outside mirror, then ignition key to ON, no seatbelt, transmission in "P", no breaks. press SET at the door panel, move the seat and/or mirror to your position, then press "1" or "2", according to the key color you use ( 1 with the black key, 2 with the gray key). If you wish to fold the mirror ( if equipped with), press the button in the center of the mirror mover switch to fold them, press again to unfold.
Oct 22, 2009 | 2001 Jeep Grand Cherokee
Hummer H2 Power folding mirror won't fold
The power folding function of your exterior mirrors on your '04 H2 depends on a plastic gear to collapse those mirrors at the touch of a button. That plastic gear strips very easily. The service adviser at our Hummer dealership said that problem was rectified in later model years with a redesign of of the collapsing mechanism of those mirrors.
I don't mind manually folding our mirrors, and I was afraid to ask about the cost of the parts required to solve the issue. The service guy didn't volunteer the cost of the fix. Not typically covered by aftermarket extended service/warranty plans.
Jul 28, 2009 | 2004 Hummer H2
I broke the mirror cover on my Hyundai Sonata 06 drivers side.
dude i would just replace the hole mirror it is only like 3 bolts it is not hard and it will look alot better than a fiberglass repair plus you can get a used mirror from a junkyard for 35 to 40 bills
Jan 17, 2009 | 2006 Hyundai Sonata
Mirrors will not fold in.
It is a stuck motor. Water gives rust inside housing. Remove mirror and clean motor and components. This is a well known error for H2 mirrors.
Dec 18, 2008 | 2006 Hummer H2
Jerdon Deluxe Lighted Makeup Mirror JGL9W Logo
182 people viewed this question
Top Jerdon Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Jerdon Health and Beauty Expert? Answer questions, earn points and help others
