Sharp c1 00 - Office Equipment & Supplies
  • 63 Answers
This is normally a charge issue? what model of machine?
Posted on Oct 17, 2013
What kind of ink roller does this model take?
Compatible Brand Ink Rollers (6/BX) for use in Sharp EL1192BL Sharp EL1192G Sharp EL1701C Sharp EL1801C Sharp EL2192C Sharp EL2192G Sharp EL2192GII Sharp EL2192P Sharp EL2195
Sep 16, 2010 | Computers & Internet
Tip
Sharp AL Series Copier L1 L-1 Error Code Cause and Solution
L1 or L1-00 indicates Scanner movement failure. The scanner is the part under the glass that lights up and moves back and forth. So if you lift up the feeder so you can see the glass, turn the machine off for a few seconds then back on. Watch the movement of the scanner. It should move right and inch or two then back to the left. If all goes well the copier should come to ready. Lay a piece of paper on the glass and press the print button to watch the scanner movement. If it binds up or does not scan correctly there are 2 possibilities.
1) your scanner lock is engaged and is preventing the scanner from moving. Check the clear plastic dial located under the far left upper side of the copier, near where the paper exits the machine. Make sure it is in the unlocked position.
2) Your scanner rail is dirty and dry. This rail can be seen under the glass towards the back of the copier. The scanner rides on this rail. It is very common for these to get dirty and for the grease to dry up causing the scanner to freeze up on the rail. The glass must be removed and the rail cleaned and lubricated.
Just power off then on the copier to reset.
This works in the following models:
Sharp AL1000, Sharp AL1010, Sharp AL1020, Sharp AL1041, Sharp AL1200, Sharp AL1215, Sharp AL1220, Sharp AL1250, Sharp AL1251, Sharp AL1340, Sharp AL1451, Sharp AL1520, Sharp AL1521, Sharp AL1530CS, Sharp AL1540CS, Sharp AL1551, Sharp AL1551CS, Sharp AL1631, Sharp AL1641CS, Sharp AL1651, Sharp AL1651CS, Sharp AL1655CS, Sharp AL1661, Sharp AL1661CS
on Mar 20, 2010 | Office Equipment & Supplies
Tip
Sharp AL Series Copier H3 H-3 code reset procedure
To reset the H3 condition on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
Some model's use 2 other initial codes, so you may need to use one of these 2 alternate codes to get your display to go blank. The rest of the procedure is the same.
Alternate codes are: #, * , C, * or pound,star,C,star and also
#, Interupt, C, Interupt
If done correctly the display should go blank.
Now key in 14 as if you were going to make 14 copies.
Now press the print button.
The machine should reset and the code should be gone.
9 times out of 10 this is a false code that pops up due to power surges or noise.
If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service.
This works on the following models:
My sharp cash register ER-A550S stop working
The letter H appears in the screen. The register will not respond. Any idea to what the Letter H means?
Apr 10, 2010 | Sharp XE-A402 Electronic Cash Register
Software for Sharp XE-A201 Cash Register
You need the PC Link software for your model.
All of these manuals can be downloaded at:
http://the-checkout-tech.com/
sharp ER-1017 Service
sharp ER-1072 Service
sharp ER-1073 Service
sharp ER-1074 Service
sharp ER-1075 Service
sharp ER-1076 User Service
sharp ER-1077 Service Programming
sharp ER-1077
sharp ER-1077
sharp ER-1772 Service
sharp ER-1772s Service
sharp ER-1871 Service
sharp ER-1872 Service
sharp ER-1873 User Service
sharp ER-1875 User Service
sharp ER-1910 User Service
sharp ER-1911 User Service Programming
sharp ER-1911s User Programming
sharp ER-1920 User Service
sharp ER-1921 User(R) Service Programming
sharp ER-1921s Programming
sharp ER-1970 User Service Programming
sharp ER-2000U Service
sharp ER-2100 User Service
sharp ER-2370 Service
sharp ER-2371 User(R) Service Programming(R)
sharp ER-2385 Service
sharp ER-2386 Service
sharp ER-2386s User
sharp ER-2395 Service
sharp ER-2396 Service
sharp ER-2720 Service
sharp ER-2722 Service
sharp ER-2722A User Service
sharp ER-2742 Service
sharp ER-2742A Service
sharp ER-2770 Service
sharp ER-2782 Service
sharp ER-2782A Service
sharp ER-2905 Service
sharp ER-2908 Service
sharp ER-2910 Service Programming
sharp ER-2970 User Service
sharp ER-2975 Service
sharp ER-2980 User Service
sharp ER-2980S Service
sharp ER-3100 User Service Programming
sharp ER-3110 User Service Programming
sharp ER-3115 Service Programming
sharp ER-3120 User Service Programming
sharp ER-3550 Service
sharp ER-3600 User Service
sharp ER-3630 User Service
sharp ER-3712 User Service
sharp ER-3721 Service
sharp ER-3731 Service
sharp ER-3732 User Service
sharp ER-4100 User Service Programming(R)
sharp ER-4110 User Service Programming(R)
sharp ER-4100S Service
sharp ER-4110S Service
sharp ER-4550 Service
sharp ER-4630 User Service
sharp ER-4633 Service
sharp ER-4700 User
sharp ER-6740 Service
sharp ER-8700 Not Available, do you want to swap?
sharp ER-A150 User Service Programming
sharp ER-A160 User Service Programming
sharp ER-A170 User(R) Service Programming
sharp ER-A180 User Service Programming
sharp ER-A220 User Service Programming
sharp ER-A227G Programming
sharp ER-A250 User Service Programming
sharp ER-A310 User Service Programming
sharp ER-A320 User Programming
sharp ER-A330 User Service Programming
sharp ER-A410 User Service Programming
sharp ER-A420 User Service Programming
sharp ER-A430 User Service Programming
sharp ER-A440 User Service Programming
sharp ER-A440S Programming
sharp ER-A450 User Programming
sharp ER-A450S User Service Programming
sharp ER-A450T User Service Programming
sharp ER-A460 User Service Programming
sharp ER-A470 User Service Programming
sharp ER-A490 User(R) Service Programming
sharp ER-A510 User Service Programming
sharp ER-A510s Service
sharp ER-A520 User Service Programming
sharp ER-A530 User Service Programming
sharp ER-A550 User Service Programming
sharp ER-A550s User(R) Service
sharp ER-A570 User Service Programming
sharp ER-A610 User Service Programming
sharp ER-A650 User Service Programming
sharp ER-A650S Programming
sharp ER-A670 Not Available, do you want to swap?
sharp ER-A670S Programming
sharp ER-A750 User Service Programming
sharp ER-A770 User Service Programming
sharp ER-A770II User
sharp ER-A770M User Service
sharp ER-A771 User Service Programming
sharp ER-A850 User
sharp ER-A880 Not Available, do you want to swap?
sharp UP-3300 User Service Programming
sharp UP-3300M Service
sharp UP-3301 User Service Programming
sharp UP-600 User Service Programming
sharp UP-700 User Service Programming
sharp UP-800F User
sharp UP-810F User
sharp UP-820N User Service
sharp UP-X300 User
sharp UP-X500 User Service
sharp XE-A101 User Service Programming
sharp XE-A102 User Programming
sharp XE-A106 User
sharp XE-A110 User Service Programming
sharp XE-A120 User Service Programming
sharp XE-A130 User Service Programming
sharp XE-A201 User Service Programming
sharp XE-A202 User Service Programming
sharp XE-A203 User Programming
sharp XE-A206 User
sharp XE-A20S User Programming
sharp XE-A212 User Service Programming
sharp XE-A213 User Programming
sharp XE-A301 User Service Programming
sharp XE-A302 User Programming
sharp XE-A303 ? Programming
sharp XE-A401 User Programming
sharp XE-A402 User
sharp XE-A406 User
sharp XE-A40S User Programming
sharp XE-A505 User Programming
Dec 30, 2009 | Sharp XE-A402 Electronic Cash Register
Tip
Sharp AL Series Copier L3 L 3 code meaning and solution
Good Luck and thank you for using Fixya
on Mar 16, 2010 | Office Equipment & Supplies
Tip
Sharp AL Series Copier H4 H-4 service code reset
To reset the H4 condition on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
on Jan 04, 2010 | Office Equipment & Supplies
As the bag of a sharp 2114 error h3
SHARP - 2114 - L8-1 - zero cross signal error
SHARP - 2114 - L8-3 - auto-exposure sensor malfunction
SHARP - 2114 - H2-0 - Fusing unit temperature error
SHARP - 2114 - H3-0 - Overheated fusing unit
SHARP - 2114 - H4-0 - The fusing unit doesn't heat up
SHARP - 2114 - U2-1 - EPROM error
May 29, 2009 | Sharp AR-5316 Advanced Digital Imager...
Code for rca rcr311b remote to sharp tv
Code 1006 for Sharp TV Code 1012 for Sharp TV Code 1026 for Sharp TV Code 1095 for Sharp TV Code 1111 for Sharp TV Code 1112 for Sharp TV Code 1171 for Sharp TV Code 1173 for Sharp TV
Feb 04, 2009 | RCA RCR311B Remote Control
Tip
Sharp AL Series Copier Drum Light Cartridge Counter Reset
To reset the drum light on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Then key in 24 as if you were going to make 24 copies.
Now press the "print" button
Now key in 7 as if you were making 7 copies
Now press the print button again.
You should now be getting flashing zero's on the display.
Turn the machine off then on again and your drum light should be gone!
You can usually reset this counter at least once to get twice the life out of your drum unit.
22 people viewed this question
jasbo
jasbo
