My acer aspire5738 is connected to my tv with hdmi. And it says pc connected. But on tv screen its just black with flickering through it.
    Novelist:
  • 148 Answers
In this case, you can check the mode on the TV if it is set to HDMI and also check the HDMI cable in use. If this does not works, I would recommend you checking/updating the latest HDMI Drivers and then see if that helps.
Posted on Oct 15, 2013
xCAUSALITYx
  • 210 Answers
SOURCE: screen black out
Was it going a pink colour on the bios screen and now if you look close enough at the screen can you see your desktop?
Cheers
Posted on Jun 17, 2008
Arius
  • 446 Answers
SOURCE: help
Step 1
Shutdown your computer and look at the rear of the case to determine the type of video connections that your machine has. Nearly all computers will have the standard 15-pin VGA output port. In addition, you may also find that your computer has an S-video port, an RCA composite video port, a set of three component RCA video outputs or perhaps even an HDMI output port.
Step 2Determine the types of video inputs that are available on your plasma TV. There should be a standard RCA composite input, a three-jack RCA component input and an S-video input. In addition, you may also find a 15-pin VGA input, a DVI input or an HDMI input. Step 3 Select which type of connection you will use. HDMI and DVI represent the highest-quality connections, followed by VGA, Component, S-video, and composite. If your computer has only a VGA output and you will not using it solely to drive the plasma TV, you may want to invest in a video card upgrade. Most new video cards will offer dual monitor connections and possibly a separate TV connection. The first monitor connection is intended for the main computer monitor, and the second monitor connection, or the TV output, can be used for either a second monitor or a TV. Depending on the card, the TV output may be DVI, HDMI, component, S-video or composite. Step 4Purchase a video cable long enough to reach from your PC’s video output to your plasma TV. If the distance is over ten feet, you may want to invest in high-quality cables to ensure that the plasma TV receives a clean signal for the best possible picture. Cables over thirty feet in length, depending on the connection type, may result in poor video performance. Step 5Set your computer’s screen resolution to something that your plasma TV can accept, using the “Display” settings in the “Control Panel” in Windows. Refer to the owner’s manual of your plasma TV for the supported resolution and refresh rate. If you are using the S-video, composite or component outputs on your computer, this step may not be necessary. Step 6Connect your PC to your plasma TV using the appropriate cable. Start the computer up and it should recognize the attached display. In the “Display” settings, you will need to configure how the plasma TV is used if it is attached a second display. Most video cards support “Clone” or “Mirror” mode, which displays the same content on both displays. In addition, there is the “Extended” mode, where the second display will operate independently, and windows can be dragged from one screen to the other. If your plasma TV is the only monitor for the computer, you will not to configure the multiple display modes. Step 7Connect a cable from the sound output of your PC to your plasma TV using the appropriate audio adapters. Then relax on the couch and enjoy your videos on the big screen.
Posted on Aug 09, 2008
wings_it
  • 141 Answers
SOURCE: how to get audio by connecting pc to tv using hdmi
In your internet option and the menu advanced, you've got a sub-menu "multimedia" ,disable the box with "play sounds in webpage"
tell me if it's works.
cheers
Posted on Jan 05, 2009
SOURCE: cant get sound via hdmi connection from acer 6920g laptop
go into control pannel and acer hd set it there and also in sound, a wee bit of trial and error but its there. mine was the same, it cost me ouch on the phone! good luck mine works ok
Posted on Jan 19, 2009
belloso2
  • 71 Answers
SOURCE: Set Up PC to TV
What type of video card does your pc have??? if it is an nvidia card, you have to go to the control panel and set up for dual monitor..when you connect your laptop to an external monitor, you have to press control and f8 keys for couple of times ...that adjust the color to 256. Are you doing that?
Let me know
Posted on Apr 10, 2009
How do i connect my Acer Aspire one D270 with TCL LED TV 40. When i connect my laptop through HDMI port screen blinks but nothing shows on LED TV .LED TV just says not supported.My laptop Graphic is I
Have you checked the settings on your TV Malik? You usually need to go to settings on there and bring up HDMI. For example, if you have TV selected on the settings, you need to change to HDMI to view stuff on your TV screen from the laptop.
Dec 10, 2014 | Acer Aspire One D270-1865
Sharp aquos lenovo sl410 hdmi cable
I would look for a newer driver from lenovo. Has 8.1 got a fix?
Jan 19, 2014 | Lenovo ThinkPad SL Series SL410 (2842F7U)...
Acer aoa110 connect to tv
connect or pc with a HI-SPEED (HDMI) CABLE TO UR TV..AND PLUG IT IN TO HDMI..CONNECTION..MOSTLY ON THE SIDE OF THE TV..OR ON THE BACK...JUST LOOK AROUND......AND IT WILL WORK.. CHANGE UR AV SETTING ON UR TV...AND PC SCREEN WILL APPEAR ON UR TV SCREEN...'
CHEERS
Oct 14, 2013 | Acer Aspire One Netbook 8.9" Notebook
Laptop has jumbled horizontal muli-colored lines flickering and rolling, can't see screen
You should try to connect a VGA monitor to your laptop and see what happens. It sounds like a video card failure, and often the hdmi and the VGA are powered by different graphics chips.
If it works with a VGA monitor, try to install a new driver for your graphics card. Otherwise, try a system restore. That often solves your problem.
If a restoration doesn't help, your graphics card is probably broken. Get a new laptop. Avoid Acer :)
Feb 15, 2013 | Acer Aspire Computers & Internet
Step by step instructions how to connect acer c7 chromebook to tv using hdmi cord
Try pressing the Pearl Button or the windows button in your keyboard + P. The display options will show up, just select the extend or duplicate.
I hope this helps!
David
Feb 13, 2013 | Acer C7 Chromebook
How do i connect my acer 5738 laptop to my tv
First of all your TV should support both HDMI and VGA.
If it does lets start with HDMI as you will get audio through the HDMI cable.
Connect the HDMI cable to the TV and set the source on the TV to HDMI using your remote control, connect the other end to the laptop, hold down Fn and hit F5 to toggle between screens.
See if that helps and let me know how you get on.
Good luck
Aug 21, 2009 | Acer Aspire 5720-6661 Notebook PC
I have an Acer Aspire 8930G trying to connect to my TV with HDMI
After you connected the HDMI Cable to the TV...Did you press the FN + F4 Key on the keyboard... The first screen you will see is the notebook screen is blank and the TV has got the desktop on top of it...The second time you press the FN + F4 then you will see thedesktop on the notebook and as well as the TV...The third time you press the FN+F4 you will see the desktop on the Notebook...
Aug 15, 2009 | Computers & Internet
Acer L100 connecting to tv with hdmi
Try adjusting the screen resolution by right clicking on an open spot, going to properties and clicking on settings. Change the screen resolution to 1024x768 or better.
May 19, 2009 | Acer Aspire L100 PC Desktop
Screen flicker when watching 1080i
Component video has a max resolution of 720p. in order to use 1080i or p you have to use hdmi or dvi connections. That is why you get the flicker.
Dec 08, 2007 | Onkyo TX-SR304 Receiver
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
