Question about Pool & Spa
Hi I recently got a coleman spa 208 tropic it had no filter or filter cover on it does anyone know the part numbers or where I might be able to get them also would like to find a manual for the hot tub any suggestion a part breakdown would also help. Thx
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 38 Answers
Http://www.colemanspas.com/ everything your asking for is there. Your filter repalcement cartridge number and the manual. They also have a customer service number you can call. I hope you've found this site by now.
Posted on Oct 26, 2013
  • 11 Answers
SOURCE: how to turn on hot tub
Check at the plug in if it has a normal plug like in your home first. Should be a set of buttons there, called a GFI. One is test, and the other reset.Push reset to see if spa comes on. Most spas dont have an actual on button. Check breaker box for popped breaker also, maybe tub is having problems, and needs a service call. Also larger tubs ussually jave a gfi or fuse box outside, close to tub. Kirk
Posted on Feb 17, 2009
  • 59 Answers
SOURCE: I have a coleman spa about 4 years old that is
this has to do with where the water is coming from.
1. wall fittitng. just remove it, reseal and replace
2. pump leaking, usually means shaft seal.
3. plumbing fitting. usually just replace the fitting.
4. fiberglass cracked. get a boat repair man and have him fix it. these guys are usually pretty good.
David
Posted on May 25, 2009
  • 121 Answers
SOURCE: I have an older comfort spa softside AV200. I
You can try BackYardCity.Com or Betterhottubs they have a great selection of parts and other spa needs........I hop e this information was helpful thank you for using FixYa.Com............
Posted on Jun 17, 2009
  • 246 Answers
SOURCE: I have an appolo spa explorer model...bought it
you must have a small pump call laing if you do, air picket inside the plumbing try to turn both pump on high and wait few minutes if doesn fix try to loose the nut just a little bit with the breakers off and let the air go out. try one more time. if doesn work turn on high both pump and touch if they are working then a impeller may be broken inside one of them try to turn each one separate to find wich one as t he broken impeller.
Posted on Oct 29, 2009
  • 8 Answers
SOURCE: Coleman 500 series SPA 50A circuit breaker trips
bad connection follow wires from breaker to to moter theres abreak causing arc find it
Posted on May 09, 2010
Have new 22' x 52" Coleman Pool. How do I stop water flow to pump in order to change filter?
should have a plugs that covers the lines they come with your pool
Jul 02, 2017 | Pool & Spa
MK 208 Assembly
you can get information from manual .......
manual is available in website .........
Oct 30, 2008 | Optics
How do you locate the water filter?
Could be located at the rear. Should have the water supply line connected to it.
Apr 27, 2016 | Refrigerators
I would like to know how many square feet a Model # BRCQ0421BD Serial # 990905429 Coleman Central Air Conditioning Unit will cover. The unit supply is 208-230V 1 PH 60 Hz 10.8 RLA 97 LRA.
The Old Rule of Thumb is 400 square feet per ton, but you really need to do a heat load calculation to be safe. A lot of windows on the west or south side of the house will really increase your load and you may need a lot larger unit. Insulation also changes your load so you may be able to cool a larger area. You may be able to get the Heat Load Calculation Form either online or from Johnstone supply. They are on the internet.
Aug 07, 2012 | Coleman Heating & Cooling
Where can I find a manual for my coleman cam II central air conditioner for a mobile home? I recently purchased the mobile home and would like to know what steps to ntake to make it work at its best. ...
Check the website for Coleman/Intertherm for a manual, you will need the model and serial numbers of the unit. The filters for these typically sit on top of the unit, some come with frames, some lay directly on the coil. If you can't find a manual on the website or by contacting the company, check the yellow pages some towns have a mobile home supply house that would be able to help.
Aug 30, 2010 | Coleman Heating & Cooling
I need an owners manual for a Coleman Spa Horizon series 447
Chuck, did you find the manual? If not I have one with my spa maybe I could copy it for you.
Ron
Sep 04, 2009 | Coleman Sport & Outdoor - Others
Need owners manual for coleman spa 208 or 408
Go here and print it out. Nancy
team.maaxspas.com/manuals/horizon%20series%202000.pdf
Dec 19, 2008 | Coleman 10' X 10' Sundome Tent 9160K101
Blaupunkt kingston MP 47, unable to fine tune even frequencies
PRESS 3 AND 6 TOGETHER  and switch on the set and select the country .for example USA EUROPE and THAI for asia and press ok/menu button  .Pls try this.
R Murali (mailbox.murali@gmail.com)
Dec 06, 2008 | Blaupunkt Kingston MP47 CD Player
Pool & Spa Logo
44 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
