Question about Motorola Xoom Tablets & eReaders
Following message on screen starting rsd protocol
Following message on screen starting rsd protocol support onewire charger is connected battery charge level 0 but nothing is happening
2 Suggested Answers
xmodule
  • 38 Answers
SOURCE: no screen no power
Did you tried to reset? I'm sure it's write in the manual.
Posted on Dec 06, 2012
Get rid of dead robot
try clearing your cache partition, you can get to the android recovery with your buttons.
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
6. Use the volume buttons to move up and down through selection in this menu.
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option.
9. Scroll down to select "Yes, delete all user data".
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
Jan 21, 2015 | Tablets & eReaders
Help to reboot my tablet
Hi, you need to perform a factory reset, follow these instructions:
Dec 31, 2014 | Tablets & eReaders
I've had several issues but the one now is that all my tablet will do is show a pic of an android laying down with a red triangle on it bearing an exclamation mark. At the bottom of the screen it says NO...
Oct 29, 2014 | Tablets & eReaders
Nabi jr has a green android laying on it's back with red exclamation make, want do anything. How do I fix it?
Oct 27, 2014 | Tablets & eReaders
I bought the tablet off of face book yard sale and
hi there.
this is all i could find out from the internet so not sure if it will work for you.
I think it,s time for a factory reset , you will lost all you data !!!!!
or try this link out.
android man on his back with red triangle on his chest Google Search
Dec 15, 2017 | Tablets & eReaders
A samsung galaxy player 3.6 that wont turn on
The charger has a function that restores the battery operation parameters by discharging then charging the battery a number of times. Refer to charging instructions in the pack but I think the cycle is a 3 hourly one, time to charge from a full discharge. If the charger thinks the battery is dead then it will try to recover the battery using this process. You may have left the charger on long enough to charge then also discharge the battery.
Start again and charge for the time in the instructions ONLY, if you are not sure of the time try it for an hour, then without disconnecting the charger turn the unit on and take particular note of any screen messages, if any.
You should be able to continue as normal now, but still be aware of the time you are leaving the charger connected for, as it may take some time before it returns to normal operation and stops trying to recover what it thinks is a dead battery.
May 04, 2014 | Samsung Galaxy Tab Tablet PC
Motorola ce0168 pret
CE0168 is the Wireless approval and not the model. Please provide the model of your device.
Mark
Motorola Support
Apr 18, 2014 | Motorola Tablets & eReaders
I put a password on my android tablet and now i dont remember the password
Make sure you backup your files by connecting it to a PC (if you have access to one) via USB cable,you will have to do a hard reset, otherwise there is no other way to get past the lockscreen (unless you have a recovery option with your email address)
Below is the process to tell you how you can hard reset your Samsung tablet (should work with any tablet):
  • Ensure that the Samsung tablet is powered off.
  • Press the Power and the Volume Up button together till the device displays the start-up logo.
  • Once the logo is displayed, release the buttons and wait till the device enters the Android system recovery mode.
  • On the displayed screen, use Volume Down button to go to the wipe data/factory reset option (Volume Up and Volume Down buttons are used to highlight the displayed options on the Android system recovery screen).
  • Once the option is highlighted, press the Power button to select the option. (Pressing the Powerbutton in Android system recovery mode selects the highlighted option.)
  • On the next screen, press the Volume Down button multiple times till the Yes -- delete all user data option is highlighted.
  • Press the Power button to hard reset the Samsung tablet device while clearing the dalvik cache along with the process.
  • Once your device is hard reset and rebooted successfully, you will see that the unlock pattern obstruction is also gone, and you can now set a new unlock pattern on your Samsung tablet.
Oct 21, 2013 | Tablets & eReaders
Galaxy Problems
Sport mate, but it appears your device is communicating with you but you aren't decoding. *smiles*
First, you've got several problemchallenges all present in your device/tech gadget.
MTP- media transfer protocol...connected
USB connected.
To resolve, navigate your way to Settings/ developer options/USB debugging
Click on this and get the ? off, first.
Click again and get the ? back on.
Next, select from the displayed menu the option for USB charge only. EXIT.
Problem 1 solved.
Battery with red X marking on it while on display.
Battery is no longer considered GOOD? by your phone/tab.
Needs to be replaced.
Problem 2 solved.
Why Cellphone/tab not charging?
Check the recommended AC charger rating for your device/gadget, first.
Check the charger rating you've been using to see whether these values match.
Output DC=????
mAmps=????
Lastly, issue with Indpsert SIM card.
You need to confirm whether your cellphone/tab is locked to a particular Network carrier company or not.
If locked, you need to jailbreiak/unlock it.
Otherwise, a technician may have to check the SIM card terminals for you.
Hope these tips help. Feedback please. All the best.
Feb 05, 2018 | Samsung Galaxy Tab 8.9 3G P7300 16GB...
Tablets & eReaders Logo
Top Motorola Tablets & eReaders Experts
richie46
ray gallant
Are you a Motorola Tablet and eReader Expert? Answer questions, earn points and help others
