Question about Vehicle Parts & Accessories
Hi my ford galaxy ghia 2.3 is leaking, even closed and water spread over the top interior,any solution to fix it .thanks
Often I find wet area around the light switch,when it showers
    Scholar:
  • 170 Answers
The weatherstriping around the window is not sealing properly. If it looks shrunken or old and cracked, you need to replace it.
Posted on Oct 15, 2013
Hi have a terriory 2007 ghia and when it rains the drivers side floor is covered in water cant see any leaks could some one be able to help and would the warranty cover this thanks
not covered by warranty
clean out the door drain holes at the bottom
remove the door trim and reseal the areas around all of the openings with plastic and sealastic
Dec 02, 2017 | Cars & Trucks
What is the maximum speed ford galaxie ghia 4 cylinder 111 hp 1992
Hi, This is set at factory maximum speed & set into the vehicles computer. Please leave me feed back: Malcolm Campbell, Thanks
Oct 24, 2017 | Ford Cars & Trucks
Hi Ford Galaxy 52 plate leaking water can not find leak i top the water up every two days any info would a great help
if you cant find the leak its normally the head gasket. try topping it up and starting it from cold, looking around for leaks as it wont evaporate while cold.
Mar 18, 2011 | 1995 Honda Accord
My 07 grand vitari is leaking water in passenger side from dash foot area please advise .thanks
Easy one this, Remove the footwell carpet (Just un-pin it from the poppers and roll it up best you can, hold with tape if needed, you just need to get it clear of the footwell) Then dry the area with a towel. Get some kids waterbased paint (orange is good, shows up better) and coat the entire area (Dont worry it comes off with a wet rag). Let it dry then get a hose and go crazy! hose off the outside area, underneath, anywhere the leak is lightely to originate. Any leak inside the vehicle can be traced via the darkened now wet orange paint! simples!
If its the passenger footwell its almost always from the windscreen seal, Older Vits had a big rubber plug in the floor pan, these sometimes came loose!
If you do narrow it down to the windscreen, a word of caution. Dont try to simply spread mastic over the original seal! the leak will be from underneath this so applying anything on top is just a waste of time! The Guys at autoglass ect replace windscreen seals for a hobby. Next time you see a van driving around have a word with the driver. Most wont refuse a cheeky twenty quid for five mins work! Thats how I got mine fixed!
Nov 15, 2010 | 2002 Suzuki Grand Vitara
Top Inflatable Ring on Intex Pool Leaks
Soapy water never worked for me... Pour kids bubbles into a bowl and use a paint brush to spread the bubbles on the top ring. If there is a hole you'll see it begin to blow a bubble where the hole is.  patch with vinyl repair kit.
May 20, 2010 | Intex Easy Set Pool 15x36
Leak inside car
the water drain for the ac system is clogged.
the inside coil gets cold and water drips off of it and needs to drain to the outside.
there should be a drain spout on the outside of the fire wall.
this small drain needs to be cleared.
let me know if this helps
thank you
jm
Jan 27, 2010 | 2000 Ford Focus
Heater problems ford galaxy.
replace the heater core. its leaking
Jan 22, 2009 | 1996 Ford Taurus
Interior Carpet Getting Wet
It sounds like a plugged drain line from the air conditioner. Most cars now run in the a/c mode whenever u turn on the climate control (even when heat is on). The passenger side front is where it would be wet, and the carpet and carpet pad act like a sponge and will soak up the water. Let me know how u make out.
Oct 25, 2008 | 2003 Honda Accord
Rain water leak
The most common source of this kind of leak is the windshield, have a glass shop check the sealing around the glass
Sep 04, 2008 | 1992 Mercury Grand Marquis
Vehicle Parts & Accessories Logo
54 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
