Asus memory i have a asus a6tc laptop can i buy a new motherboard to make memory bigger than 2gb . thanks peter
  • 1,959 Answers
Yes you can buy a new MB. Here's a link to a motherboard that will support 4GB or RAM. You didn't specify what proc you have to double check to make sure the MB is compatable.
Posted on Apr 24, 2009
    Scholar:
  • 154 Answers
It seems that ur laptop doesnt support memory more than 2 gb. So, either u flash ur bios to latest version so that u can add more memory or else buy a new montherboard for ur laptop w.hich can support memory more than 2 gb
What motherboard is in asus k50i-rbbgr05 and whats the best cpu upgrade for it if any currently Pentium duo core t4400
Hello here is the asus home page:
http://www.asus.com/Notebooks_Ultrabooks/K50IJ/#support_Download
Try to contact the asus support before upgrading the cpu.
Your laptop will probably not support a bigger cpu, because there is a limit here.
The cpu from another model will probably fit the socket, but the pc will not boot at all.
This depends on how the mainboard is build, cache size and so on.
Its also very expensive to buy a cpu for a laptop.
This can easy cost the same as a new laptop.
The mainboard is build by asus or intel.
It would be easyer to by a laptop with a bigger cpu.
They do exist as quad core.
Good luck
Jun 12, 2013 | Computers & Internet
Asus memory
actually your laptop doent support memory more than 2 gb, either you have to flash ur bios to new version so that you can add more memory or else you have to buy new motherboard.
Apr 24, 2009 | Computers & Internet
I have a toshiba satellite A135-S4467 laptop, using two memory slots, totaling 1G. I've bought a Kingston ValueRAM - 2GB PC2-6400 DDR2 Laptop Memory Module. What is the best way to install my new 2G...
Hi, Yes, it would be best to take the old RAM out. I am assuming that this is 1 stick totalling 2GB. Optimally it would be good to have 2 x 1GB modules totaling 2GB, so they could work together. Otherwise, yes, just remove the the old ram and install the new module. If you are running a 32bit operating system, 3GB is all the system can use anyway. Hope this helps!
Jul 13, 2011 | Computers & Internet
I need changes my memory 2 pcs @ 1GB DDR1 PC3200 with 2 pcs @ 2GB DDR2 PC6400 in Asus P5VDC-MX Motherboard. please advice. Thank you
Number of Memory Slots: 2×184pin + 2×240pin
Memory Standard: DDR 400/DDR2 533
Maximum Memory Supported:2GB
PC6400(DDR2 800) is not supported by your motherboard. Also max memory is 2GB. PC4200 is the fastest memory you can install. There might be a BIOS update available from ASUS website to increase the speed but you would have to check the site.
Dec 01, 2009 | ASUS P5VDC-MX Motherboard
Do I need to buy 2 DDR2 Ram for my ASUS P5VDC-MX Motherboard?
with rams, if the memory it has is higher than that of your cpu, the pc will not boot up or if it is too low compared to your cpu again.
thus, you say it has got two slots right, remove both of the 512's and insert the 1gig only, run your computer, i am sure it will boot up nicely. switch it off. put one 512, if it does not boot then you should know that your ram has an excess of memory that your cpu could not apprehend to.
post a coment if this does not work.
thanks,
wonder
Sep 18, 2009 | ASUS P5VDC-MX Motherboard
Memory problem
The ASUS web site shows only two ram slots on the motherboard. Sounds as if the booklet has a misprint. Specifications on the web site list memory as: Dual Channel Memory Architecture
2 x 184-pin DIMM Sockets support max. 2GB DDR400/333/266 non-ECC, unbuffered DDR SDRAM memory. So, 2GB is max.
Jun 10, 2009 | ASUS P5PE-VM Motherboard
Asus a6tc laptop last few weeks it said no memory i it shut down at night , start up next day hear fan black screen, backlight ok and inverter ok , can you please help, peter
I think you should test your RAM module. If cleaning its edge connector with soft eraser doesn't work. But do this when unit is completely shutdown and no other power source is connected to it. Test the ram with a good spare module if this boot the system youre opt to buy a new one.
Apr 27, 2009 | ASUS Computers & Internet
PC Motherboard Memory upgrade
From Asus tech: Memory 3 184-pin DIMM slots for PC1600/PC2100 DDR SDRAM
Supports up to 2GB memory
No ECC supportThis is only compatible RAM so make sure your new chip is PC1600 or PC2100. If you mis the 2 it the faster RAM will run at the slower chip speed. Hope this helps.
Feb 20, 2009 | ASUS P4B266 Motherboard
I tried to install a new motherboard, and it is not working at al
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us This is a link to the new board you installed good luck send me more info and I WILL HELP MORE IF I can. Good luck.
Jan 16, 2009 | ASUS P4B266-C (P4B266-C WA) Motherboard
Memory Issue
You could try lowering the Cas latency. Just boot into the bios and try lowering the cas latency up by .5 For example, if it's running at 2.0 change it to 2.5 or 2.5 to 3.0 Yes this will slow down your system, but it may be a more stable speed for the ram to run at. You could also have bad ram, or maybe your problem isn't ram related at all. It's possible your motherboard is the cause of all of your problems. Peter
Oct 04, 2007 | ASUS P5RD1-VM Motherboard
Computers & Internet Logo
204 people viewed this question
David Payne
David Payne
