Question about HP (C6502A) Parallel Adapter
Windows usb is there an equivalent adapter for USB connections?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 46 Answers
Depending on the connections you need any cable can be made.
http://www.parts-data.com/Parallel_to_USB_Reverse_Adapter_DB25_male_to_USB_B_male_LPT-to_USB-0530-AK.html
This website is one of many that have different types of cables depending on your requirements.
Posted on Dec 10, 2013
How can i connect my D-LINK 3.75G HSUPA USB Adapter to my windows 7
The USB Adapter is plug and play. This means Windows will automatically detect it and start installing the drivers for it. If Windows is unable to install the drivers you might have to install the ones from the CD if one was provided along with the USB Adapter.
Please note that according to the specifications I found the D-LINK 3.75G HSUPA is only compatible with USB 2.0. This means that if you plug it into a USB 3.0 port it won't be detected by your computer and the USB Adapter will not work.
Jan 13, 2014 | D-Link DWM-156 3.75G HSUPA USB Adaptor
Can i charge my vivitar 850hd by plugging it in?
Yes. The 850W charges the battery via the USB port. You can charge it by connecting it either to a powered USB port on a computer or a wall outlet by using the supplied adapter (or equivalent).
Apr 12, 2012 | Sakar Vivitar Underwater Digital Video...
I am trying to set up my Avertec N1200 laptop with Windows XP to my Netgear wireless router. The router does not have a USB connection, but I have a Netgear wireless USB adapter. Also, I am getting the msg...
The Netgear Wireless USB adapter should be connected to your Avertec N1200 laptop to act as a wireless antenna. The driver for your Netgear Wireless Adapter should also be installed on your laptop. Once installed, click on the Windows Orb button on the lower left corner of your screen and go to All Programs. Look for the installed program for your Netgear Wireless Adapter to open up the wireless utility of your wireless adapter. That's where you should connect the wireless connection and not on Windows Wireless Manager.
Aug 27, 2011 | Computers & Internet
My garmin GPS 12 needs a serial port connection. New HP laptop with Windows 7 OS only has USB connections. Salesman sold me a Belkin F5U109 adapter but windows wont recognise it.
You should install the drivers for the adapter running as administrator. If the adapter is not supported by windows 7 you should give it back to salesman and get a new one compatible with windows 7
Mar 13, 2011 | Belkin USB PDA Adapter [ F5U109 ] (109198)...
I just reformatted my computer and am trying to install Netgear WNA1100 WirelessN 150 USB Adapter, however it gets stuck at detecting adapter. I'm running Windows XP Professional and I do not have any...
As you said that you have reformatted the computer , try to reinstall your USB bus controller drivers because it seems that your USB bus controller is not detecting your USB adapter when connected.
Try this link to download USB 2.0 driver
http://www.softwarepatch.com/tips/usb2-driver.html
Feb 21, 2011 | NetGear WNA1100 WirelessN 150 USB Adapter...
Skype Phone Adapter USB-RJ11--Malfunction dialing calls
try with another phone if negative - somthing in the adapter stops the
"#" frome going to skype .
daniel
http://rylwy.com/
Aug 08, 2009 | Radian Technologies SkyTone RST201 IP...
MANUAL FOR KEYBORD 5188
Type 5C Keyboard to USB Adapter
Operation Manual
Type 5C Keyboard to USB Adapter 5188
TYPE 5C KEYBOARD TO USB ADAPTER Page 1
This equipment generates, uses, and can radiate radio frequency energy and if not installed and used in accordance
with the instruction manual, may cause interference to radio communications. It has been tested and found to
comply with the limits for a Class A computing device in accordance with the specifications in Subpart J of Part 15
of FCC rules, which are designed to provide reasonable protection against such interference when the equipment is
operated in a commercial environment. Operation of this equipment in a residential area is likely to cause
interference, in which case the user at his own expense will be required to take whatever measures may be required
to correct the interference.
Contents
Chapter Page
1. Specifications 2
2. Introduction 3
3. Installation 3
4. Technical notes 3
5. Part Numbers and Accessories 4
1. Specifications Compatible with:
Sunä Type 5C keyboard and mouse (includes Sun Type 6 keyboard)
Ultra Spec Server Control Switch, P/N 5185 or 5195
Sun Sunblade 100 workstation
USB compliant PC workstations (a USB compliant operating system which supports the USB HID 1.1
device class specification is required)
Power:
USB bus powered device. Current load is 100 mA max (adapter only). If also powering Type 5C keyboard
and mouse requires an additional 400mA max.
Size:
4.0” x 2.4” x 1.0”
Shipping Weight:
1 lbs.
Warranty:
Ultra Spec Cables, Inc. warrants all hardware and components of the Type 5C Keyboard to USB Adapter,
with proper installation and normal use, for one year from the date of purchase.
During the warranty period, Ultra Spec Cables, Inc. will, at its option, either repair or replace hardware and
components that prove to be defective.
If your product should fail during the warranty period, phone our technical support department at 1-800-
622-2537 for warranty service (return to factory) instructions.
TYPE 5C KEYBOARD TO USB ADAPTER Page 2
2. Introduction
The Type 5C Keyboard to USB Adapter (P/N 5188) allows a USB compatible workstation to be connected to the
Server Control Switch (P/N 5185 or 5195). The adapter converts keyboard scan codes from the type 5C keyboard to
equivalent USB keyboard scan codes. The adapter also converts the mouse data to USB compatible mouse data.
The Type 5C Keyboard to USB Adapter can also be used in a standalone setup, where it is connected between a
Type 5C Keyboard/mouse and a USB based workstation.
3. Installation
3.1 Between Type 5C keyboard and workstation (standalone operation)
For all installations it is recommended that the equipment be powered off for system interconnection and/or changes
to a setup.
• Connect the port labeled To Type 5C Keyboard to either minidin8 connector on the Type 5C keyboard using a
straight through minidin8 cable (P/N 8002 or equivalent). If using a mouse, connect it to the other minidin8
connector on the keyboard.
• Connect the port labeled To Computer USB Port to any workstation USB port using a USB Type A to Type B
cable (P/N 4021 or equivalent). This type of cable is used for connecting a HUB or other device upstream to
another HUB or a host controller.
3.2 Between Server Control Switch and workstation (system operation)
to a setup.
• Connect the port labeled To Type 5C Keyboard to any Server Control switch CPU port using a straight through
• Connect the video output of the workstation to the Server Control Switch video input connector using an
appropriate cable/converter for connector and sync conversion
• Connect and power on the rest of the Server Control Switch system per the appropriate installation instructions.
4. Technical notes
Keyboard
The Type 5C Keyboard to USB Adapter emulates a Sun Type 6 USB keyboard (P/N 3201273-01) and a Sun
Crossbow USB mouse (P/N 3703632-01). The Type 5C and Type 6 keyboards match in available keys, however
several keys are relocated on the Type 6 keyboard. The adapter appropriately maps the key codes generated to the
key legends on the keyboard (i.e. all keys work the way they are labeled).
TYPE 5C KEYBOARD TO USB ADAPTER Page 3
Important Note Regarding Standby Operation:
USB supports a SUSPEND/RESUME capability that has various and incompatible implementations across differing
hardware platforms. This can affect the operation of the adapter if the workstation supports a low power or standby
mode with an incompatible implementation. Low power or standby mode is normally activated through a menu
selection (using the mouse) or by pressing the POWER key on the keyboard (upper rightmost key on both the Type
5C and Type 6 USB keyboards). For this reason, the POWER key on the Type 5C keyboard IS DISABLED when
using the adapter. In addition, it is important not to activate low power or standby mode through other means.
WHEN IN LOW POWER OR STANDBY MODE THE SYSTEM MAY NOT WAKE UP THROUGH
KEYBOARD OR MOUSE ACTIVITY, REQUIRING A HARD POWER-DOWN TO RECOVER.
In addition, the POWER key on the Type 5C keyboard does not have the capability to power-on a system as it
would when connected to a Type 5C compatible workstation (nor does a Type 6 USB keyboard have this capability
when connected to a USB workstation).
5. Part numbers and Accessories
5188 Type 5C Keyboard to USB Adapter
4021 Cable, USB Type A/B, M/M 0.5M
4022 Cable, USB Type A/B, M/M 1M
4023 Cable, USB Type A/B, M/M 2M
4024 Cable, USB Type A/B, M/M 3M
4025 Cable, USB Type A/B, M/M 4.6M
Jul 10, 2009 | HP Multimedia Cordless Keyboard/Mouse...
Re set wireless usb adapter
  1. Connect a computer to any one of the four LAN ports of the NETGEAR router.
  2. Open an Internet explorer and type the router IP address which would be either http://192.168.0.1 or http://192.168.1.1 (by default, refer to your product documentation ti determine the default IP address.) in the address bar and press Enter.
    The Login window will be prompting for a Username and Password. The default Username is admin and the default Password is password
  3. Click Wireless Settings under Setup menu.
    1. Under Security Options, Select WEP (Wired Equivalent Privacy)
    2. Change the option to Disable
May 18, 2009 | NetGear USB 2.0-Stick WiFi 108 Mb WG111T...
WANT USB DRIVER
Go to www.nokia.com
There, search for ur phone.
Download PCSuite.
Install it and connect the phone.
Now you can connect ur phone and access data in it.
Feb 01, 2008 | Adapters.com BT-0333 Bluetooth USB Adapter...
HP (C6502A) Parallel Adapter Logo
54 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
