Question about Panasonic Televison & Video
PANASONIC SX4 LOW VOLTAGE PROBLEMS - Panasonic Televison & Video
Reset? oil light on a 2011 Suzuki sx4 all wheel drive 2 ltr diesel?
-Check its manual. Possibly low oil in the engine.
Good luck
mai
Aug 12, 2015 | Suzuki Cars & Trucks
What does yellow exclamatin point on dash mean on susuky sx4
Yellow exclamation point on dash means low tire pressure.
Jun 07, 2014 | 2008 Suzuki SX4
Suzuki sx4 problems
get the codes first .they should have done that.
Dec 27, 2013 | Cars & Trucks
Panasonic problems
Your home may have suffered an electrical power surge, check the end of the electrical cord, there you may find a built in surge suppressor with two buttons, depress the reset button. If one does not exist, then you must access the interior power supply and search for a low voltage electrical fuse. Inspect and replace if burned.
Dec 22, 2013 | Heating & Cooling
Suzuki sx4 how to repair tappet noise?
My sx4 car tappet is making sound
Aug 22, 2013 | 2007 Suzuki SX4
Where is the knock sensor located on my 08 suzuki sx4
The P0327 means Knock Sensor 1 Circuit Low Input (Bank 1 or Single Sensor).
the knock sensor is located in the front of the engine located behind the oil dip stick just to the left.
_______________
Ktag K-TAG
Oct 22, 2012 | 2008 Suzuki SX4
Suzuki sx4 problems
ours turned out to be the gas cap was not tightened enough. plus warned to to TOP off the fuel tank as that puts raw fuel in the vapor lines
Feb 01, 2018 | Suzuki Cars & Trucks
I have a 2007 suzuki sx4 and recently had a oil change...now the check engine light is on and I can't set the cruise control either
We have had similar problems with 2007 SX4 for 18 months - engine light on intermittently, sometimes days, sometimes weeks, cruise control disabled when light is on. Suzuki dealer has replaced O2 sensors twice, suggested catalytic converter needs replacement ($1200) but was not certain of cause or remedy. Finally dealer has removed fuel tank and fuel pump to reveal dirty fuel filter. Dealer states dirty fuel as cause which is not their problem as they cannot control fuel quality. Dealer wants $1200 to replace pump but no guarantee it won't occur again with first new tank of fuel! Could make for very expensive driving.
Oct 02, 2010 | 2008 Suzuki SX4
Is the SX4 engine a relative of the Sidekick engine I'm considering buying an SX4. If it's engine was a close relative of the Sidekick engine, it would be a check in the plus column
We dont have the sidekick here but do have the sx4.did some homework a while ago and was impressed by it.Friend bought one and has been happy with no problems to date
Aug 04, 2009 | 2008 Suzuki SX4
At highway speeds, however, the engine is noisy.
Very dificult to diagnose from your info. Could be numerous problems i.e drive belts, pulleys, alternator, power steerng pump, excessive valve clearance, gearbox whine or the most likely culprit, TYRE NOISE. I suggest take the vehicle to a respectable repair shop just for a diagnose. Get a second or third opinion, although it is no charge most of the time if it only requires a test drive (in South Africa) and take it from there!
Regards
Phillip
Jan 28, 2009 | 2008 Suzuki SX4
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
