Question about Hotpoint Dryers
Hotpoint ultima tdc62 dryer empty water light wont go out when water is emptied
  • 55 Answers
SOURCE: hotpoint condenser tumble dryer aquarius cdt00- wont dry
I am not familiar with this particular unit, but I have a condensing dryer (Malber) which pumps out the water by itself. I am guessing that your unit requires you to empty a bin manually. Even if the bin is empty, I think the unit thinks it needs to be emptied and that is why the dryer will not work to give you hot air. If you do have such a bin, it might have a weight switch which the unit uses to detect if the bin needs emptying. See if the weight switch is working. The same weight switch idea is used on dehumidifiers.
Posted on Mar 10, 2008
dean66
  • 22 Answers
SOURCE: hotpoint dryer TDC32
i had this problem but it is NORMAL. only when the empty water light is flashing it needs emptying, i thought there was an internal problem but like i say it is normal to stay on solid throughout your drying and even when you just switch it on. i found this out in my manual
Posted on Mar 28, 2008
  • 1462 Answers
SOURCE: Tumble Dryer-empty water light won't go off
remove panel on rhs looking from back and you will see a chamber with a microswitch on top. either micrswitch is stuck, pump faulty or a lint blockage
Posted on Jul 23, 2008
SOURCE: HOTPOINT AQUARIUS CONDENSER TUMBLE DRYER CTD40
There are three water reservoirs - one at the bottom behind the condenser, a second at the back bottom of the machine and then a third at the top which is the one you would normally pull out to empty.
There is a hole at the bottom of the filter in the first reservoir (at the back of the condenser) which leads to the second reservoir at the back. If the hole gets clogged up with lint/muck then the reservoir at the back does not fill up.
So to solve this, unplug the machine, take out the condenser (front left bottom of the machine) reach through to the back and mop up the spare water with a towel and check that the hole to the back reservoir - you can feel this it is towards the right side at the back of the machine is clear from muck.
Once you have cleared it, water will flow to the second reservoir and then (once you switch on the machine) up to the main removeable reservoir at the top.
Hopefully this helps. GB
Posted on Sep 10, 2009
SOURCE: Indesit IS70c condenser dryer
CHECK PUMP AND FLOAT AT REAR OF DRYER EITHER PUMP IS BLOCKED OR PIPE FROM PUMP BUT MAKE SURE THE DRYER IS UNPLUGGED WATER AND ELECTRIC DO NOT MIX,
IF YOU ARE UNSURE WHERE TH PUMP IS GET A QUALIFIED ENGINEER
Posted on Jun 29, 2010
Hotpoint ultima wd 865 will not empty water
It is likely there is either a blockage in the filter, outlet hose or water pump.
May 25, 2012 | Washing Machines
Hotpoint Ultima Condenser Dryer TDC62 - No Heat
That trouble is cause by an heater that is already open- no connectivity. Also the wire connected to it.
I hope I answer your problem.
Mar 23, 2011 | Hotpoint Dryers
My hotpoint ultima dryer has no power to it changed fuse checked plug socket emptied water tank cleaned both filters
power comes in at mains lead goes to the choke /filter from here onto the door interlock switch then onto timer ......hope this helps
Feb 26, 2011 | Hotpoint Ultima WF860 Front Load Washer
Error code
H20 indicates incoming water supply problem.
Check that the water is fully turned on.
Check the inlet hose/s for kinks or restriction.
Make sure there is a good pressure of water to washer.
Please rate my solution.
Thankyou..
Jan 31, 2010 | Hotpoint Ultima WF860 Front Load Washer
Help my machine hotpoint ultima wma 60 wont empty water tried 5 times water sitting there had turn machine off
p my machine hotpoint ultima wma 60 wont empty water tried various times water sitting there had turn machine off
Dec 21, 2009 | Hotpoint Washing Machines
Hotpoint Ultima Condenser Dryer - where is the reservoir?
under the door, you need to take the small panel off and its there.
Mar 03, 2009 | Hotpoint Dryers
Not emptying
what that signals is the impellor on the end of the pump is jammed or loose. Check to make sure it is free.
Jun 15, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint condenser tumble dryer aquarius cdt00- wont dry
Mar 09, 2008 | Dryers
Hotpoint dryer TDC32
check the switch where you remove the tank towards he bottom
Dec 30, 2007 | Hotpoint TDC32 Electric Dryer
Water empty light wont go out
the black wire that was moving water from down condenser to up - water container - remove it. Use cotton swabs to "clean" the holes, do a run of the dryer without that black wire connected ( carefull, cause some wated might spill at this point), reattach black wire, and enjoy :)
It worked for me anyway. ( fingers crossed, its been on for 20 mins and still no red lights flashing)
Dryers Logo
27 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Dan Webster
Dan Webster
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
