Looking for dd-wrt for us robotics 9111 adsl router
  • 15 Answers
SOURCE: 3rd party firmware broke my router!
did you check whether you have downloaded the correct firmware for your linksys???
Posted on Dec 04, 2007
  • 556 Answers
SOURCE: two routers US robotics connected together
It appears you may have confused the world because of your IP addressing choices. Do you know what a subnet mask is? It determines which machines share the same network with other machines. Routers by design are the connection between different subnets, Most routers default to 255.255.255.0 for the subnet mask which means both of your routers are in the same subnet as they are 192.168.2.? meaning you have two separate networks sharing the same same subnet address when they should be unique. Try making the wireless router 192.168.3.3 or 192.168.3.1. This puts devices in your wireless network on the 192.168.3 subnet and the devices in the ADSL subnet in the 192.168.2 subnet which includes the WAN half of the wireless router. I believe this will correct your network issues. In this case if hardcoded the gateway for the wireless router would be 192.168.2.1 also known as the the adsl modem
Posted on Dec 06, 2007
jeicrash
  • 320 Answers
SOURCE: wrt150n dd-wrt firmware slow loading pages
First off thanks for using fixya.com
Second, I too am a dd-wrt user and found a similar problem when using dd-wrt with my IPCOP. You may want to go into the "Security" section of your dd-wrt and disable any fire walling or access-restrictions. Since you are already running zonealarm. Or remove zonealarm if you plan to use dd-wrt as your firewall.
Running multiple firewalls will slow down your network/Internet traffic.
Hope this helps you out.
Jei
Posted on Dec 15, 2008
Roynice152
  • 88 Answers
SOURCE: Wrt150n, Flashed with DD WRT.
You probably need to update a newer version of firmware. Here is a link for you.
http://www.coderetard.com/2008/05/30/install-dd-wrt-firmware-on-linksys-wrt150n-wrt160n-wireless-routers/
Posted on Feb 13, 2009
SOURCE: My linksys wrt54G v6 router has a blinking power
Understand that what you are trying to do, may permanently turn that router into a piece of trash. Firmware upgrades are hit and miss, and sometimes even doing everything correctly will result in a "Bricked" router. A bricked router is one that is about as useful to a computer as a brick. Proceed at your OWN RISK!
Read all directions BEFORE you try anything! First D/L the correct firmware for your router. Then D/L TFTP.EXE from the DD-WRT site. Put these files right on the desktop where you can find them and unzip the firmware. (I am assuming you are running Windows XP)
Now connect your router to the computer you are using with an Ethernet cable and plug in the power. DO NOT TRY THIS VIA WIRELESS!! Then you need to set your computer to a fixed IP address, Open your network connections (control panel - Network Connections) right click your local area connection and select properties. Highlight Internet Protocol(TCP/IP) and again select properties. Under the General Tab select "Use the following IP address" enter 192.168.1.99 Under Subnet mask enter 255.255.255.0 Click OK and wait for the TCP/IP connection to be established. The router first must be reset to the factory default configuration BEFORE you flash it.
Resetting the router means, with the router plugged in to a power source hold down the reset button (on the back of the router) for 30 seconds, then pull the power but continue holding the reset button for another 30 seconds. Then WHILE STILL HOLDING THE RESET BUTTON, plug the power back in and hold it for another 30 seconds. Now you can let the button go and allow the router to reboot.
If you still have only the power light blinking, try pinging the router. Open a command prompt, (Start RUN CMD [Enter]) and type PING -t 192.168.1.1 Leave this window open and dbl-click the TFTP.exe program. There are three empty boxes in the TFTP program. Enter the IP address of the router in the server box (192.168.1.1) enter ADMIN (all lower case) in the password box and click the dots next to the file box, browse to your desktop and select the firmware image you downloaded (.BIN)
Now if your ping command is only returning "Request Timed Out" try resetting the router again only this time watch the ping window for a response from the router. If you get a response, immediately click "upgrade" on the TFTP window. If all goes well you should get an "Upgrade Successful" message. This step is important!! RESET THE ROUTER again after waiting 10 minutes. Now if the router was not initially reset to the factory default configuration before someone tried to upgrade the firmware, it is possible that the router is hanging while it tries to boot and the firmware image was corrupted. If that is the case then you will need to read the DD-WRT Wiki under "Bricked Router". Good Luck!!
Posted on Dec 11, 2009
How to create wireless bridge
DD WRT is a firmware upgrade sight you can find wonderful firmware upgrades that make your router come to life and Evan worth more than you payed for your original router, check the router database and see if your router is listed and capable for an upgrade to dd wrt, i did it with my dir615 and it gave me a whole host of additional optins for configurations , it was a long search for "dd wrt" but well worth it.
Oct 12, 2013 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
I can't turn wps off
Open a Web browser, then type IP address into the address bar then Press enter.
->Login with username and password.
->Click Wi-Fi Protected Setup under the Wireless category.
->Click Disabled, then click Apply Changes to save and apply the settings.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/wireless-router-support/
Mar 14, 2013 | Computers & Internet
No connection display on ethernet connections
DD-WRT firmware is very specialized. Can you ask on a site that provides support for DD-WRT ? Can you log in to the console ?
Sep 09, 2012 | Linksys E3000 Wireless Router
I am trying to change the cfe on my netgear wgr614 V6 tdc but the jtag doesn't see it. The ends I am trying to get to is putting dd-wrt on it. Any ideas?
I don't know TDC version of v6, if you still have it please provide info about components (processor, flash, RAM). I have some with processor BCM5352, flash 29LV800 (some with 29LV160), RAM Samsung K4S641632
Mar 14, 2011 | NetGear WGR614 Wireless Router
Repeater router responds with 'Address not found...'
You need to start from scratch.
Whenever you need answers they can be found here -
http://www.dd-wrt.com/phpBB2/viewforum.php?f=1&sid=785382853553ee7844cfab78da0607db
But best to start with the Wili - http://www.dd-wrt.com/wiki/index.php/Installation
And here is your get out of jail card -
http://www.dd-wrt.com/wiki/index.php?title=Recover_from_a_Bad_Flash
If you have to resort to the hard method of recovery, be careful.
I have only ever permanently killed one router - doing this - http://voidmain.is-a-geek.net/redhat/wrt54g_revival.html
You will first need to establish which model router you have. Then you will (assuming you want to use DD-WRT firmware) need to flash a micro or mini firmware. Then you flash again, using the standard.
There are many users worldwide using your WRT54G and GL routers with other than standard firmware, me included. I manage a network of 9 routers running DD-WRT V23SP2 standard.
Don't give up, and when it says to leave it 30 seconds (or 2 minutes) DO! Be patient...
Apr 06, 2009 | Linksys Wireless-G WRT54G Router
Wrt150n dd-wrt firmware slow loading pages
Jei
Dec 15, 2008 | Linksys Wireless-N WRT150N Router
Router to use as relay.
Linksys WRT54GL with DD-WRT firmware. Now, DD-WRT will void the warranty, but it has been incredible for my uses when configuring WDS. A the WRT54GS has also been said to be an excellent router, but I cannot say.
Dec 22, 2007 | D-Link AirPlus DI-524 Wireless Router
WRT54GS DEVICE-NO INTERNET CONNECTIVITY
You didn't specify if you're using DSL or cable internet.
With DSL, keep in mind the software1.gif on the PC is what "dials out" to the ISP with your name / password, and you MUST set the name and password in the router. Otherwise, ONLY the computer that has the software installed (verizon, etc) will be able to connect.
Also, make sure that ONLY the LAN is connected from the router to the modem, and not both the USB and LAN.
If you're using a cable connection, you don't have to do this, however, most newer Linksys routers come with a 'setup' disk, which MUST be used regardless of connection type.
Oct 09, 2007 | Linksys Wireless-G WRT54G Router
ROUTER CONNECTIVITY
Ok, do a troubleshooting session.
Unplug the router from the internet modem.
Try at first to connect using a Network cable from you PC to one of the LAN sockets.
Can you access http://192.168.1.1  with your web browser?  (the configuration page)
     If yes it is possible that the router has the same address as your adsl modem.
    change the router address to something 192.168.0.1 instead of 192.168.1.1
     Save your changes. Plug your WRT to the adsl modem and try again.
     Does the internet work now with a wired connection ?
If the above does not work can you "ping" the machine ?
      ping 192.168.1.1
if none of that works try doing a hard reset... heres a little guide (off the DD-WRT wiki)
http://www.dd-wrt.com/wiki/index.php/Reset_And_Reboot
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
