Question about OKI MICROLINE 280 Elite Matrix Printer
Alarm 280 elite - OKI MICROLINE 280 Elite Matrix Printer
Factory alarm wire diagram/wire colors on isuzu kb 280 4x4 turbo diesel
not posting country to our USA forum
is a failed moment.
we dont have your car here.
but your car in your country will be different that others.
say Africa cars not like Australian.
for a fact.
and not only that some cars the the alarms are dealer installed.
Aug 18, 2015 | Isuzu Cars & Trucks
Sears Ken Elite upright freezer model no 25329082991 temp alarm
alarm should go off when freezer reaches minus 18c or lower.
Feb 05, 2010 | Freezers
OKI ML 280 Elite
You have the Printer emulation set incorrectly. I think it comes as IBM as default and you should try Epson instead. Its a trial and error thing but am sure emulation is incorrect.
Jun 14, 2017 | OKI MICROLINE 280 Elite Matrix Printer
Alarm shutting down scooter
I have never heard of this, and I just check the manuals to be sure. The only "Alarm" is the horn button. If that is going off while driving, I suspect that a wiring harness is frayed and shorting out.
Oct 31, 2008 | Elite Pride Go Go Traveller 3 Wheel
Oki microline 280 feeds paper continiously after a file print, and won't stop till i pull power cable
First, reinstall the driver and be sure it's the correct driver for this printer. If you drive a word document does it do the same? If not, chanses are the db application is constantly sending form feeds to the printer and the printer will do whatever it's told to do. Try a different printer setup in the db application.
Aug 27, 2008 | OKI MICROLINE 280 Elite Matrix Printer
Oki microline 280
Check printer setup where you define carrige return and line feed options. Alot of times you need to set printer to do an auto CR on reciept of LF or auto LF on reciept of CR. I run into this all the time.
Aug 02, 2008 | OKI MICROLINE 280 Elite Matrix Printer
OKI MICROLINE 280 Elite Matrix... Problem
Be sure when you install new paper that the paper out switch, usually in the paperpath somewhere, is being contacted by the new paper. Usually located on the left side of the paper platten.
Jun 04, 2008 | OKI MICROLINE 280 Elite Matrix Printer
Form feed length for 280
change in your computer driver setting
if you using windows xp
click to
start
settings
control panel
printer and fax
select your printer and right click
properties
in general menu
printing preferances
change here paper size
select letter 8.5" 11"
Feb 28, 2008 | OKI MICROLINE 280 Elite Matrix Printer
OKI MICROLINE 280 Elite Matrix Printer Logo
27 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
