Hi my lg tv keeps flashing up this function is not available and keeps turning its self on and off and the volume keeps going up
How many times do this flashes? These flashes are called blinking codes, and are fault indications. You can get an idea about the faulty circuit stage inside the TV, by these flashes, that occur at one time switch ON. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
SOURCE: LG TV keeps flashing This function is not available now.
unplug the TV. hold down the power button for 30 seconds. plug the TV in.
this worked for me :)
SOURCE: lg lcd tv keeps changing chanels
Come on, lets try to solve this. Take the batteries out of the remote so it can't interfere and try changing the channels and volume with the buttons on the tv. If this works then someone has spillled something onto the remote and gummed it all out. You simply need to take the remote apart and clean it out. If the buttons on the tv do th same as the remote did then yes, take it back.
SOURCE: "Function Not Available" error on LG 47LG50 LCD TV
A software upgrade may resolve the issue if not the main Pcb. would need replacement.
Contact LG during normal business hour 8-6 central time.
1 800 243-0000
They may help you out also let them know if you are having a lipsync issue.....Wink wink
SOURCE: LG 42 LCD TV HDD initialization in progress message
Change the hdd or remove it then connect it to PC and do for it format , it will work .
