Question about Lenovo Computers & Internet
Lenovo Thinkpad T510 is stuck continuously rebooting after the "windows did not shut down properly" gives the option to start windows normally, but then a blue screen interrupts the process and it goes back to the ThinkPad screen.
  • 2,113 Answers
A blue-screen in a portable device is almost certainly a sign of it being dropped and that the hard drive may need to be replaced
Posted on Oct 15, 2013
  • 58 Answers
SOURCE: Thinkpad R51 Blue screen
First:
does this also happen in safe mode boot. (press F8 just before windows boots). If not then go to your event viewer and check the messages at the specific time,hour messages. for example. computer booted at 23:30. in windows around 23:31:10 and then blue screen. Go to safe mode. and look in the logs what registered at 32:31:10(around this time).
If not possible to boot in safe mode. Try to remove one of the 2 memory dimm(if you have 2). so you boot with 1. maybe 1 of them doesn't work good anymore.
Posted on Nov 30, 2007
  • 101 Answers
SOURCE: IBM thinkpad T22 problem
This solution is for s-k-i-t: you will have to get a copy of the win xp install disk to fix this problem (you can borrow one as long as you have a COA on your laptop) but first get into the BIOS by pressing F1 right after you turn it on - you'll see the prompt in lower left corner. Then go to startup>boot>hard drive>Enter. This will show you the type of hard drive. If it is a IBM or Hitachi less than 60 gig chances are it is failing and this is why the hives (where XP stores its memory states) are corrupt. You can download the "Ultimate boot disk" and make a CD that will let you run hard drive test tools. If the hard drive is bad I would try to get the eBay seller to make good - depends on how long you've had it.
Posted on Feb 21, 2008
heavyice
  • 374 Answers
SOURCE: My thinkpad got stuck up while booting & i am
Is there any error message that you can see?What does it say?Or,is it just a blue screen and you can't see nothing? Blue screen can be caused by any hardware,software,poorly written device drivers recently installed and accidently shutting down of PC. If you can't see anything then take out the battery and press the power button for about 60secs.Startup without the battery first using the adapter and then see.If you still see the same blue screen then try the other options:
I want you to press F8,at startup, to bring up the advanced boot option and select "last known good configuration". Go to the BIOS setting pressing the DEL key at startup and select Load setup defaults [you might find that option in EXIT ]. Try removing any extra hardware attached like scanner,printer,pen drives etc.Later attach them again one by one and switching off and on the PC just to make sure which hardware is gone kaput. If you are able to startup the computer,use the SYSTEM RESTORE function to go back to previous date when your pc was working fine.This is to make sure you don't end up getting a blue screen at startup,again. The last option would be installing Windows OS. You can try and change the RAM sticks,if you have two then remove one n then start,do the same with the other RAM.
Posted on Jul 20, 2009
shynysaxena
  • 166 Answers
SOURCE: Lenovo ThinkPad and a blue screen
Sir this is due to Hard disk internal problems and you will need to perform PRIMARY HDD test by using BIOS setup wizard.
Posted on Jul 21, 2009
SOURCE: Lenovo ThinkPad R61 Fan
Were you able to fix it? I took out the fan and cleaned it with a toothbrush (didn't disassemble it). If it worked, can you provide some insight into what you did?
Posted on Mar 12, 2010
Laptop usb printer
You might need a new USB cord for it.
Apr 29, 2013 | IBM Lenovo ThinkPad T510 Notebook
Thinkpad t510 4314 touchpad and mouse stop responding
It shows the fault of USB ports and in my point of view you need to replace with a new motherboard.
Hope it will be helpful.
Good Luck
Aug 19, 2012 | Lenovo ThinkPad T510 4314 - Core i5 520M...
IBM T510 Slow Downloads
If there is no problem with your ISP, then the reason may be one or more problems acting together. The problem nowadays is that it is very difficult and time consuming to monitor and take care of your Lenovo PC. Even experienced users find it hard to perform such tasks on regular basis because you might need to prepare a huge amount of time and energy to deal with each issue separately.
If you want to fix the problems more efficiently, try the Lenovo speed up program, available here: http://www.speeduplenovo.com/
Jan 04, 2012 | IBM Lenovo ThinkPad T510 Notebook
How can i activate lenovo vebcam?
Instructions
  1. Open the display screen of your Thinkpad and turn on the computer. Wait for the logo screen to give way to the main desktop screen.
  2. Click on the "Start" tab in the bottom corner of the desktop screen and drop-down menu will appear.
  3. Select "All Programs" from the list of options in the drop-down menu and a list of more options will appear.
  4. Select "Capture Video From Device" and your Thinkpad window will activate. A capture window will appear on your desktop screen. From here, you can select the "Start Capture" tab in the capture window to begin shooting.
Dec 28, 2010 | Lenovo 3000 N100 Notebook
How do i reboot my thinkpad t60 ?
If this is a serious question, then the answer depends upon the version of Windows you are using.
Usually, you simply click on the Start Button in the lower left corner of your monitor/screen, then look for options to Shut Down, or Shut Down and Restart.
Failing to find those items you can always use CTRL+ALT+DEL and when the result of that comes up, look for Restart as an option.
Best thing you can do is to find the Help options and read what Microsoft has written about controlling Windows. Find their Tutorial and spend some time reading and following it.
-a.
Apr 08, 2010 | IBM Computers>Laptops Lenovo ThinkPad T60...
Lenovo sl500 crashes and reboots over and over
Pres F8 key before Windows starts and go to safe mode and uninstall latest windows updates.
Sep 29, 2009 | Lenovo ThinkPad SL500 Notebook
Hoe to reboot my computer lenovo r60
go to start in the left corner below in the desktop and click it then you will get "turn off" or "shut down" click on it then you will get the option for "stand by","turn off" and "restart", just click on "restart", and you computer will reboot, if you click on turn off then the pc will shut down
dont forget to rate the solution
May 17, 2008 | Lenovo ThinkPad R60 with Wireless Wide...
Computers & Internet Logo
175 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Lee Durbin
Lee Durbin
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
