Question about Dishwashers
GE Profile pdw9280j00ss dishwasher Star button won't work.....all other touchpad buttons work fine... Is it safe to say i need a new Strip ?
  • R. SALLOUM
    R. SALLOUM Oct 17, 2013
    all other selection work except the Start button...but i noticed build up around the strip ( water residue) and when i opened the dishwasher i could see moisture between the 2 strips that leads to the connection box...
5 Suggested Answers
  • 3 Answers
SOURCE: The middle arm on my dishwasher (GE Profile) is no...
Had same problem with mine. Actually bought all new middle arm assembly but as I was taking it apart to install new pieces, I noticed so much gunk in the middle swinging mechanism that I assumed that must have been the problem.. I really think the newer dishwashing tablets cause this buildup problem. Anyway, put on all new pieces and started the machine. Long story short, it worked great for about a month and then started doing the exact same thing. THE reason why the middle arm sprayer doesn't spin is that the little holes at each end (the ones that sit underneath and look like they should propel the sprayer arm ) get clogged. I bought some pipe cleaners, bent to an angle where I could come in from the top and pull out through the propellor hole and voila` the sprayer is swinging beautifully again.. I guess the only question I still have is why this started happening three to four years after I purchased the machine. Something somewheres else must not be doing its job.
Posted on Jun 27, 2010
heatman101
  • 43501 Answers
SOURCE: no water imput. ge profile
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Posted on Sep 07, 2010
MNTECH
  • 1543 Answers
SOURCE: GE profile PDW9280J00SS dishwasher. It
Possibly, but first, check the door switches and their cover to make sure they are OK. You will have to seperate the inner and outer halves of the door to get to them, located where the tub latch protrudes into the door.
Posted on Feb 06, 2011
ginko
  • 19396 Answers
SOURCE: GE profile PDW9280J00SS dishwasher. Dishwasher shows
Hi.
You said that there is power to the board. Be sure that there is volts in there, otherwise check power cord (test continuity rather than volts-it is safer and faster).
Check the door switch. If the door switch is faulty, then the dishwasher will not start the cycle. The door switch can be tested in a number of ways. One way is by jumping the switch and cycling, this is easier than reading Ohms or Volts while operating the switch.
Here all parts and diagrams for this model.
Regards.
Ginko.
Posted on Mar 05, 2011
GE Dishwasher Won't turn on
Door may not be fully closing for some reason.
Mar 15, 2012 | General Electric GE Profile Dishwasher 24...
I have a ge profile dishwasher model pdw9280j00ss. After a storm event, house lost power. Since that time, dishwasher constantly beeps; however has no power to it. shut off circuit, beeping stops; but...
http://www.geappliances.com/search/fast/infobase/10000380.htm
According to this link, it should reset after the power is shut off for awhile. Maybe try holding the start/reset button too. Also check the circuit breaker or any fuses
Aug 28, 2011 | GE 24 in. Profile PDW9880JSS Built-in...
GE profile PDW9280J00SS dishwasher. It will not start. The keys on the keypad light up except the start buttom. I push start and nothing happens. all the other button are lit and i think work. Do I need to...
Feb 05, 2011 | GE 24 in. Profile PDW9880JSS Built-in...
No water imput. ge profile dishwasher. PDW9280J00SS. TRIED HITTING THE FLOAT COVER.
heatman101
Sep 06, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
My dishwasher has no power and am hearing A constant highpitched noise
i do have the same problem with my ge dishwasher(model PDW9280J00SS). i just replace the key pad now it's working ok. i got the key pad on line for about $70. part no. WD34X10915
Jul 09, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
I have a ge profile pdw7800 which will not start. the problem seems to be with either the circuit board, or the touch panel. Some buttons on the touch panel work, and others dont. Please advise if this...
I'm having the same problem with my GE PDW7800's touchpad. the buttons to the right of the Start button are dying. I'm now having to play a dance between with the "button lock" mode and Time Delay to get it started. Unfortunately, the capacitive touch panels are delicate and have a limited lifespan. You're looking at replacing the touchpad, or buying a new dishwasher
I'll be replacing mine eventually, but the lowest price I've seen is currently $230, so this is a fairly expensive repair. (That is why I've not replaced it yet. I can play the button dance game a little longer, but eventually it will cease to function at all.)
Jul 16, 2010 | GE 24 in. Profile PDW7800 Built-in...
My GE Profile dishwasher won't start. The power
More then likely the Control Panel has faulted and will need to be replaced. You can try shutting off power for a few minutes and see if it resets.If so great if not time to replace.Not that hard of a repair for a DIY
Jan 08, 2018 | GE 24 in. Profile PDW7800 Built-in...
GE profile performance dishwasher- not starting after child pushed buttons.
The only way we have been able to fix this is to turn off the breaker to the dishwasher for 5 minutes and then turn the power back on. The dishwasher should reset.
May 31, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Continuous beep after power went off and on
I'm the one who posted on May 23. I tried turning off the breakers and it was still beeped when powered back on. I ordered a new touchpad and control module. When I replaced the touchpad, the beeping was gone, but not all the buttons worked, so I changed out the control module, too, and it works:) I'm going to put clear caulk along the top to prevent spills from leaking through the front panel.
May 15, 2008 | GE 24 in. Profile PDW9880JSS Built-in...
Dishwashers Logo
21 people viewed this question
Top Dishwashers Experts
