Question about Acer Computers & Internet
Remove svchost exe
Acer laptop svchost.exe-no disk
  • 3,961 Answers
The best take on this is already here: Sanera74's reply to a similar problem below
Posted on Oct 15, 2013
3 Suggested Answers
hockeyguyJC
  • 133 Answers
SOURCE: fix the svchost.exe
You **might** be infected with spyware that a regular cleaner cannot pickup.
I reccomend you find a utility called "HiJack This!" and use it under the professional care of someone who is skilled to read out your scan from the utility and tell you what to repair. Unfortunately , I am not one of those qualified to read the logs and give advice.
Posted on Aug 25, 2008
SOURCE: svchost error memmory
Svchost.exe acts as a host for a group of services on your computer. As you are aware there a many services and programs the run silently in the back ground. Svchost.exe pools many of these services in one group and runs all at the same time. This is a great for efficiency. However, it can cause your CPU to spike to 100%.
As mentioned before svchost.exe is essential. So the trick is not to block svchost.exe, its to limit your computers need to use it. You can limit your computer need for svchost.exe. By cutting down on the services that are loaded when you PC starts. This can be done quite easily.
1. Open your Start menu.
2. Click Run
3. In the command screen type: msconfig
4. In the "system configuration utility", Click "services" tab
5. Uncheck all services that are unnecessary.
6. Click "OK"
Uncheck the suspecious services but make sure you do not stop necessary services. Restart the PC to take them affect
Posted on Mar 27, 2009
ErI have all this on the windows task manag
its normal. when you open task manager and you click the process tab you see alot of them under SYSTEM. those are manditory for your computer to run.
Mar 06, 2010 | Microsoft Windows XP Home Edition
After shutting down svchost.exe appeared.and hang itself.
If its not doing this all the time, and the laptop is just stuck on, press and hold the power button down until the laptop turns off.
If its a reoccurring problem, run a check disk.
if it still does it, disconnect one piece of external hardware one at a time until the scvhost.exe doesn't hang on shutdown, and you have found the culprit.
Jan 21, 2010 | HP 510 Notebook
Everytime i open my computer, ah pop-up windows say's WINDOWS CANNOT FIND SCVHOST.EXE
First, I'll let you know what's going on, then I'm going to post from Microsoft, what svchost.exe does, and how to find out where the problem is. I can help you further if you need it.
Svchost.exe is a program in WIndows XP Pro that will start services in your computer during startup. It sounds like you have deleted a program and "service host" is still looking for it to open on startup. This can happen if the program was removed without using the correct removal procedures. It is still listed in the registry and your computer is still trying to access it. DO NOT edit your registry unless you know what you are doing. You could create a catastrophic failure of Windows. There are programs that will remove registry entries if those entries are no longer valod. You can fing a free program for this function at web sites like www.nonags.com
Following is information from the Microsoft web site:
The Svchost.exe file is located in the %SystemRoot%\System32 folder. At startup, Svchost.exe checks the services part of the registry to construct a list of services that it must load. Multiple instances of Svchost.exe can run at the same time. Each Svchost.exe session can contain a grouping of services. Therefore, separate services can run, depending on how and where Svchost.exe is started. This grouping of services allows for better control and easier debugging.
Svchost.exe groups are identified in the following registry key: HKEY_LOCAL_MACHINE\Software\Microsoft\WindowsNT\CurrentVersion\SvchostEach value under this key represents a separate Svchost group and appears as a separate instance when you are viewing active processes. Each value is a REG_MULTI_SZ value and contains the services that run under that Svchost group. Each Svchost group can contain one or more service names that are extracted from the following registry key, whose Parameters key contains a ServiceDLL value: HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Service To view the list of services that are running in Svchost:
  1. Click Start on the Windows taskbar, and then click Run.
  2. In the Open box, type CMD, and then press ENTER.
  3. Type Tasklist /SVC, and then press ENTER.
Tasklist displays a list of active processes. The /SVC switch shows the list of active services in each process. For more information about a process, type the following command, and then press ENTER: Tasklist /FI "PID eq processID" (with the quotation marks) The following example of Tasklist output shows two instances of Svchost.exe that are running. Image Name PID Services
System Process 0 N/A
System 8 N/A
Smss.exe 132 N/A
Csrss.exe 160 N/A
Winlogon.exe 180 N/A
Services.exe 208 AppMgmt,Browser,Dhcp,Dmserver,Dnscache,
Eventlog,LanmanServer,LanmanWorkstation,
LmHosts,Messenger,PlugPlay,ProtectedStorage,
Seclogon,TrkWks,W32Time,Wmi
Lsass.exe 220 Netlogon,PolicyAgent,SamSs
Svchost.exe 404 RpcSs
Spoolsv.exe 452 Spooler
Cisvc.exe 544 Cisvc
Svchost.exe 556 EventSystem,Netman,NtmsSvc,RasMan,
SENS,TapiSrv
Regsvc.exe 580 RemoteRegistry
Mstask.exe 596 Schedule
Snmp.exe 660 SNMP
Winmgmt.exe 728 WinMgmt
Explorer.exe 812 N/A
Cmd.exe 1300 N/A
Tasklist.exe 1144 N/A
The registry setting for the two groupings for this example are as follows: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Svchost:
Netsvcs: Reg_Multi_SZ: EventSystem Ias Iprip Irmon Netman Nwsapagent Rasauto Rasman Remoteaccess SENS Sharedaccess Tapisrv Ntmssvc
RApcss :Reg_Multi_SZ: RpcSs
Jun 18, 2009 | Microsoft Windows XP Professional for PC
Svchost error memmory
2. Click Run
6. Click "OK"
Mar 20, 2009 | Dell Inspiron B130 Notebook
I have deleted svchost.exe accidently from windows xp and cannot now log onto windows. I have tried expanding the file from dos however still cannot log on
this is going to be a tough one to fix. since I don't know which svchost you have deleted from the system.
usually when that happen the only solution is to reinstall the OS. even try to fix it from the registry key, the key and the pointer will be there, but not the excution file, and there is not way which svchost control what services.
HKEY_LOCAL_MACHINE\Software\Microsoft\WindowsNT\CurrentVersion\SvchostEach value under this key represents a separate Svchost group and appears as a separate instance when you are viewing active processes. Each value is a REG_MULTI_SZ value and contains the services that run under that Svchost group. Each Svchost group can contain one or more service names that are extracted from the registry key.
Dec 02, 2008 | Microsoft Windows XP Home Edition
I have deleted svchost.exe from windows xp
To complete part one, follow these steps:
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
  2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  3. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
  4. When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line: md tmp
    copy c:\windows\system32\config\system c:\windows\tmp\system.bak
    copy c:\windows\system32\config\software c:\windows\tmp\software.bak
    copy c:\windows\system32\config\sam c:\windows\tmp\sam.bak
    copy c:\windows\system32\config\security c:\windows\tmp\security.bak
    copy c:\windows\system32\config\default c:\windows\tmp\default.bak
    delete c:\windows\system32\config\system
    delete c:\windows\system32\config\software
    delete c:\windows\system32\config\sam
    delete c:\windows\system32\config\security
    delete c:\windows\system32\config\default
    copy c:\windows\repair\system c:\windows\system32\config\system
    copy c:\windows\repair\software c:\windows\system32\config\software
    copy c:\windows\repair\sam c:\windows\system32\config\sam
    copy c:\windows\repair\security c:\windows\system32\config\security
    copy c:\windows\repair\default c:\windows\system32\config\default
  6. Type exit to quit Recovery Console. Your computer will restart.
Unknown file
In software Svchost.exe is a generic host process name for services that run from dynamic-link libraries (DLLs) within the Microsoft Windows operating system.
At startup, Svchost.exe checks the services part of the registry to construct a list of services that it must load. Multiple instances of Svchost.exe can run at the same time. Each Svchost.exe session can contain a grouping of services. Therefore, separate services can run, depending on how and where Svchost.exe is started. This grouping of services permits better control and easier debugging, but it also causes some difficulty for end users wishing to see the memory usage or vendor legitimacy of individual services and processes. End users in Windows XP Professional (and derivatives, such as Windows Server 2003 and Windows XP Media Center Edition) can run the following command at the system prompt to get a breakdown:
tasklist /svc /fi "imagename eq svchost.exe" (NB: This command does not work in Windows XP Home.)
Due to being widespread among running processes, svchost.exe has long been a common disguise used by malware to hide its presence from the user. (One of the common trojan horses deceptively uses scvhost.exe). Users may then run tasklist with no arguments and match the reported PIDs with the previously shown Svchost instances. If memory usage appears abnormal, the user can look up the service names shown by their command on the internet to see if it is a known service or malware.
The Svchost.exe file is located in the %SystemRoot%\System32 folder. The main registry key involved at bootup is HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\SvcHost (values in this key will show the user at least a partial list of the actual processes behind instances of svchost).
The 30 April, 2007 release of WSUS 3.0 led to reports of svchost.exe issues, including 100% CPU usage, memory hogging, and excessive laptop fan/power usage.[1]
[edit] See also
Oct 29, 2008 | Microsoft Windows Server Standard 2003 for...
Svchost
"Svchost.exe" (Generic Host Process for Win32 Services) is an integral part of Windows OS. It cannot be stopped or restarted manually. It manages 32-bit DLLs and other services. At startup, Svchost.exe checks the services portion of the registry to construct a list of services that it needs to load. In normal conditions multiple instances of Svchost.exe run at the same time. Each Svchost.exe session can contain a grouping of services, so that separate services can be run depending on how and where Svchost.exe is started. This allows for better control and debugging. The svchost.exe file is located in the folder C:\Windows\System32. In other cases, svchost.exe is a virus, spyware, trojan or worm! To detect if it's a virus sometimes it will add letters to the Svchost to read thus SSVCHOST or SVCCHOST or something like that, thus making multiple services to run and slow down the computer, if that is the case the current antivirus you are using is not removing the virus, this can be done in the registry, its a complicated process if you do not know how to do it, so i would suggest you purchase a registry cleaner. NOTE: remember to backup the registry before you clean it
Aug 15, 2008 | Microsoft Windows XP Professional
Windows Freezing
Boot the system in safe mode
1.) restart the system
2.) pump the F8 Key until a screen comes up with different options
3.) select safe mode,
Try right clicking there and see what happens,, I,m guessing here this is a result of damages done by a previoulsy removed virus (GUESSING) it is possible that the same one could have been shard by all 3,,
I'd advise you'd uninstall norton and use the new avg free
www.free.grisoft.com
Let me know what hgappens and we can tgake this a bit further
Jul 14, 2008 | Microsoft Windows XP Home Edition
Svchost.exe
Go to start>all programmes>accesories>system tools>system restore and restore the pc to a date before you deleted the file
Nov 01, 2007 | Microsoft Windows XP Professional for PC
Computers & Internet Logo
43 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
