Sometimes wont spin after washing! it only happen about 1 in 4 washes ive cleaned the front little filter, also ive taken the waste pipe off and flushed all that clean too. any ideas?
  • 113 Answers
Be sure the lid is shutting all the way it may not be pushing the lid switch down all the way some time
Posted on Apr 24, 2009
Wont spin
have you cleaned the filter
if you have
change the motor brushes
Mar 10, 2014 | Hotpoint Aquarius WD63 Front Load...
My mastermind 708 dosen't spin after wash cycle.It spins fine in the wash cycle but dosen't drain water or spin in the spin cycle.Pease help
Your empty pump filter is blocked with debris. If it can't evacuate all the water then it wont allow the spin cycle to start. Locate the filter (probably behind a little door at the botton of the front of the machine). Remove, clean and remove the debris, re-fit and all will be well
Jul 01, 2011 | Westinghouse Washing Machines
Wont spin
"OE" code in your washer indicates a Drain error. This is because the washer is not fully drained within 10 minutes. You have to check whether there is a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge.
Thank you !!
May 25, 2010 | LG WM-2277HW Front Load Washer
Washing machine will not spin. have cleaned out
I have problem with my washing machine.could you help me please.
Apr 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Won't spin out at end of wash cycle code is OE
Please clean the filter.
Filter is behind the little door located on the front left corner of the unit.
Please read the owners manual for proper cleaning.
If filter is clean the drain pump may have failed.
Jan 16, 2010 | LG WM-1832C Front Load Washer
My Bosch classic 1200 express washing machine wont drain or spin
Possibly a blocked filter or pump.
Ths filter should be at the bottom right front of washer, sometimes behind a removeable cover at the bottom of washer.
To clean it, unscrew anti-clockwise, remove and clean.
Dec 09, 2009 | Bosch Washing Machines
Bosch WFD 2473 - wont spin. I've taken out the filter and found a broken washer in it. Can't work out where the washer comes from? Doesn't seem to fit the filter. Having cleaned the filter, washing machine...
Even if the pump is not working, then so long as there is no water in the washer, it should spin
If it does not, then I would suspect the motor brushes are worn out.
You need to remove the motor to check the brushes, if they are less than 2 or 3 mm long then they need replacing.
I do not think the washer you found is off the pump,more likely out of someones pocket.
Hope this helps with your problem.
Dec 02, 2009 | Bosch WFL 2063 Front Load Washer
Whirlpool AWM1200 washing machine wont advance at certain stages
there is a little motor in the selector switch that moves the dial around.  This little motor is defective and needs replacement.  Sometimes it's sold separately and sometimes you need the whole timer.
Apr 01, 2009 | Whirlpool AWM6120 Front Load Washer
Cleaning depends on use. 8 years is a bit over the top! When your water does not drain, check the outlet filter first, then the pipe from below the tub to the filter. Your washer wont spin 'cause the pump/filter is blocked.
Jul 24, 2006 | Whirlpool AWM6120 Front Load Washer
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
