Question about Creda Washing Machines
Creda panel heater timer not working - Creda Washing Machines
  • 27 Answers
SOURCE: How do I turn the timer off my Creda slim line
You can stop the unit coming on by turning the temperature dial down to as low as it will go. Also it could be turned off at the wall if all else fails and there is a plug point.
Posted on Jun 16, 2009
SOURCE: I HAVE A 800 WATT CREDA ELEC PANEL HEATER LOOKING
through internet
Posted on Jan 07, 2010
SOURCE: operating instructions for creda storage heaters
how do you regulate the heat from creda storage heaters model No 79163 /79151 /79141 they have 2 dials on each heater,I was told the dial on the right turn up to 6 its highest point & the left dial to its lowest number 1 .But i got up this morning & its like a sauna
Posted on Feb 16, 2010
  • 95 Answers
SOURCE: Where can I get a
Hi! It seems that this company produces mostly shower accesories, this is why i hope this will do the trick. This is a link that allouds you to read and download for free a installation and operating instructions for creda profile and creda panel heaters ( http://www.tlc-direct.co.uk/Technical/DataSheets/Creda/Creda_NPP_Instructions.pdf ).
I hope this will help you! Have a nice day!
*please don't forget to rate my support :)
Posted on Sep 02, 2011
  • 15 Answers
SOURCE: Creda heaters not working is it controll panel
More info please.
Posted on Nov 14, 2012
Creda Solarplus (48906) top oven and grill not working
Electric stoves do not have pilot lights or igniters it could be the power control board has failed .
Mar 12, 2016 | Creda Ovens
Where can I get a manual for Creda Panel heater 1500W with Timer 68?
Sep 02, 2011 | Heating & Cooling
Hello, I have recently moved into a property that has Creda PWE4ZC control panel and electric heaters. Unfortunately there is no paper work on how to programme the this panel to control when the heaters...
The dimplex RXPW4 is the same as the Creda. The manual is at http://www.dimplex.co.uk/assets/product_instructions/RXPW4_Installation_Operating_Issue_3.pdf
Jan 03, 2011 | Heating & Cooling
I didnt get a user manual with my creda cooker dont know how to set the timer
try this site for your manual
kitchen.manualsonline.com/manuals/.../creda/creda_oven_product_list.html
hope this helps
Apr 28, 2010 | Ovens
Creda Solar Plus Model 48339N Clock/Timer not working
You have to remove the complete top assy as one unit. To do this you need to remove the side panels, there are screws at the rear, and some at the front of the oven, you will then be able to see the screws securing the top
The top then slides towards the rear, then you can gain access to the timer unit.
Hope this helps.
Dec 08, 2009 | Creda Ovens
How do I turn the timer off my Creda slim line panel heater ? keeps coming on when not required. I have lost my instruction booklet. Many thanks bev
Jun 16, 2009 | Heating & Cooling
Creda concept solar plus oven timer
Hold down the 2 left buttons together, and press the + or - button at the same time..
This should reset the timer.
Please leave a fixya rating for my solution.
Thanks.
Feb 12, 2009 | Creda Ovens
Creda Simplicity 1000 Washing Machine not heating water
Make sure that you have not got the energy save button in operation, as this by-passes the heater, and will wash at the incoming water temp. It should not be showing green
If this is not the case, then the heater has probably failed.
To access the heater, you need to remove the top cover, remove the soap dispenser drawer, and undo the 4 screws securing the console panel to the top of the washer.
Pull off the timer knob, noting the position of it, and slide the console panel to the right, support it with something.
Remove wire cllip holding door seal to front of panel, and pull off the seal at the front.
Undo the screws securing the front panel at the top.
Undo 3 screws at bottom of front panel.
Lift front panel clear,and stand it at the right of washer, be careful of the wires still attached to the door lock.
At the bottom, in the center, you should find a black cover, remove that, and you will see the heater element.
You eally need a meter to test it for continuity, and or an earth fault.
Replace if faulty.
Please leave a fixya rating for my suggeted solution.
Thankyou.
Feb 09, 2009 | Creda W100FW Front Load Washer
Not heating up
If fan is working o/k , then you need to replace the heater element.
This is located behind a removable panel at the rear of the oven compartment,
Undo screws and remove element .disconnect leads, be careful not to lose them inside, fit new element, fit cover back.
Plz rate this solution.
Tthanks, and merry exmas.
Nov 16, 2008 | Creda C362E Electric Kitchen Range
Operating instructions for creda storage heaters
Jan 03, 2008 | Heating & Cooling
Washing Machines Logo
20 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
