Question about Saeco Magic Comfort 103467 Espresso Machine
Weak coffee
I've changed the grinding blade to improve the strength of the coffee but it still isn't as strong as it was a few year ago
    Habit-Forming:
    New Friend:
  • Saeco Expert
  • 123 Answers
Better make descaling proces on your machine!
Posted on Oct 21, 2013
mirran
  • 515 Answers
SOURCE: Coffee Grind
After you change the grind, how many cup of coffee have you make?
Posted on Jul 14, 2008
PABLOCSA
  • 1124 Answers
SOURCE: Saeco Vienna Deluxe -- Coffee weak weak weak
You have to clean the coffee grinder this will be fixing your problem with the ground size and brewing cycle.
Posted on Oct 13, 2008
  • 1089 Answers
SOURCE: weak coffee saeco vienna "not digital "
Hi
Has the size of you ground coffee changed? If it is not the size of granulated sugar then its your grinder. Check ebay completed listings. Saw one there couple weeks ago.
Posted on Nov 25, 2009
  • 1089 Answers
SOURCE: my magic deluxe is grinding very coarse on number
Hi
Your grinder has seperated. The cork screw in the center is not centered. Grinder needs to be replaced. If you want one let me know.
Posted on Jan 21, 2010
SOURCE: coffee is too weak
I just spoke to someone at customer service. My coffee has been weak and kind of thin. We had the Superautomatica by Saceo for years and I remembered the coffee being richer.
Anyway! The person suggested that I adjust the grind but slowly. So set it to the coarsest setting, brew 2-3 cups. Then put it to the 2nd-coarsest setting, brew 2-3 cups. To the third, brew 2-3 cups. To the forth, brew 2-3 cups. Etc. Until you're at the finest grind setting. Again, brew 2-3 cups. An awfully sensitive machine. It seems to have worked although the last few seconds of brewing continue to be a kind of milky colour (as opposed to a deep black coffee colour). You can, though, press the "cup" button to stop the brew. So once, it starts running milky, you can stop the cycle.
I hope this helps. I know I've been struggling and cursing the machine for a while :)
Posted on Jul 23, 2013
How do i fix my esam 3400 coffee grinder quantity?
I have change grinding from 7 to 1 ( it depends from coffee beans) and quality of coffee get much better (knob located inside the bean container).
Mar 09, 2016 | DeLonghi ESAM Coffee Makers & Espresso...
The coffee is becoming increasingly weak. I have used the same Illy beans since first getting it 2 years ago, so obviously no real change there. itis actually undrinkable as it is just coloured water!
Hi, Could be a few things happening here. Is your grind too coarse? Is the water tempreture not hot enough? or most likely the pump is not pumping at the correct pressure. This could mean, blockage or faulty pump. Dazza
Sep 19, 2011 | Gaggia Titanium Espresso Machine
How many seconds of grind for standard drip grind
I've long ago lost the manual that came with my grinder (I actually don't remember if it even had one), but I don't think it listed grinding times. You just grind a few seconds and check, then grind a little more if it's still too coarse. Unlike a burr grinder which is adjustable, in a blade grinder the same grind time may result in different consistencies as you change beans. By now I've just learned how long to hold the button for the different beans I buy, and the first few times I try a new blend or varietal I have to adjust the time. I think you'll just need to experiment and then you'll know what works best for your tastes.
Jun 30, 2011 | Braun KSM 2 Electric Blades Grinder
Coffee to water ratio
Weak coffee is 2 tsp per cup strong coffee is 3 tsp or 1 Tbls per cup. (3 tsp per Tblsp) 32 Tablespoons = 2 Cups, there are 4 Tblsp per 1/4 cup. If you're confused ( I am from reading my answer) Use 1 cup for weak coffee, two cups for strong or 1 & 1/2 for regular strength coffee. Hope that helps!
Apr 11, 2010 | West Bend (58036) 36-Cup Coffee Maker
Coffee is too weak
Dec 30, 2009 | Saeco Odea Giro Plus Coffee Maker
Grinds too long coffee still weak
You can adjust the grind, finer will give you stronger coffee. Think water through sand vs. pebbles. There are also settings you can find in your owners manual for adjusting the length and strength of your "pull".
Try Julius Meinl espresso roast, it's dark, rich and sweet. Definitely my favortie.
Dec 24, 2009 | DeLonghi EAM3400 Espresso Machine
Weak coffee saeco vienna "not digital "
Hi
Nov 24, 2009 | Saeco Vienna Digital Coffee Maker,...
How can I ajust my machine the coffee is coming out weak and watery I don't get that creamy,strong coffee anymore
HI
There are more than a few things that can cause weak coffee.
Grind is too coarse. It should look like coarse sugar.
You cleaned the brew unit and left a part out or put it in incorrectly.
Grind adjustment is set too high. Turn to a lower # while the grinder is operating.
Grinder is been taken apart and not put back together correctly.
Grinder is broken and the grinds are just big chunks.
Oct 23, 2009 | Spidem Trevi Digital Coffee Maker,...
Saeco Magic Comfort 103467 Espresso Machine Logo
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
