Question about Kitchen Ranges
No power to left side oven - Kitchen Ranges
  • Kitchen Ranges Master
  • 2,113 Answers
If it is 220 Volt then look for the 40 amp double breaker and shut it off and turn it on again. If this doesn't fix it unplug the oven and turn off the power to it to examine the wall plug and also check the wires from the cable inside the back of the oven (i have seen wires fall off). If it still isn't fixed check any fuses if there are any inside the top of the range. If they are ok then check that the elements are clean and slide into the sockets tightly as dirty loose connections often heat up and arc causing more damage. If this is so then you have to purchase 2 range block wiring harnesses and replace them.
Posted on Oct 15, 2013
Beko built in double oven alarm after power outage
Switch oven on using the function knob (first knob on left hand side)then press and hold(for 3 to 5 seconds) the left top button right next to the display screen this should give you a chance to set the current time on the oven after setting the current time switch oven off at function knob and on agian problem should be solved
Jul 05, 2015 | Ovens
Frigidaire oven, set over to Clean and during the clean process had a power failure. LED has "LOC", cannot open oven. I have powered oven off and back on to no avail.
one thing you could try is to set the oven to clean and see if the clean cycle will turn on then push cancel/off and see if the door opens. IF that doesnt work the door latch failed and must be replaced. to open the door ya have to pry open the latch by usinga wire hanger and try to slip it between oven door and top and pull to the left side to open latch
Good luck,
Gene
Aug 06, 2011 | Ovens
Our Chef Sapphire Clock & Oven stopped working suddenly after a power failure overnight. Are there any fuses to be found inside, or any other suggestions please. The stove top is fine and all 4...
This oven needs the time set after a power failure. The LED display will read HELPME and there is a small knob on the left side you need to turn it to set to change the time and use the second knob from left side to + and once done leave the knob on manual. The oven can be timed to turn off but it the time is not set on it the oven and stove do not work.dux_training.jpg
Aug 29, 2010 | Ovens
Need heating element for oven of 1950's Frigidaire by GM stove
Fixya is unable to identify parts sources.
Jan 23, 2018 | Ovens
Bake element split and oven will not heat.
thats an eazy one by a new element from one off our links at fixya and install it with the power off and no theres no reason why this happened it just wore out God bless,tom
Jan 01, 2009 | GE Spectra JBP78 Electric Kitchen Range
GE Spectra XL44 Gas Oven, flashing "Locked Door". Can't use oven or close door
I had the same problem happen tonight. I have an XL44 self-cleaning gas range. We unplugged it for several minutes and pressed 'cancel' a bunch of times--neither worked. We finally lucked out--opened the oven door and pressed a black button on the upper left side of the front of the oven. It turned out the flashing words and unlocked our door. Weird. There was nothing in the manual about this...
Oct 22, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
36 inch range gas not flowing to both burners
I am having the same problem with my oven. One burner comes lights on just one side. Then the second one comes on. Just one side. After a while both side get lit. My concern is unburnt fuel coming out of the oven. Going to trying taking the burner out and cleaning the ports
Sep 18, 2008 | Viking VDSC365-6B Dual Fuel (Electric and...
ONE OF THE OVEN DOESN'T WORK,
Yes the clock needed reset, by pressing down the stop cook and start cook buttons together, then +/- to the 24 hour clock time. then it works!
Sep 10, 2007 | Ovens
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
