Panasonic kxfc225 fax
My fax only pulls the paper in half about 2-3 cm and then stops pulling while the ink roll is still spinning and printing without the paper. I had this once before and was serviced once before 6 months ago. Can I fix it myself?
    Sergeant:
  • 317 Answers
Open the machine up to see if you have drop something in it like a pencil, piece of paper or other debris. Hold it upside down and see if something falls out.
Posted on Oct 22, 2013
All Office
  • 58 Answers
SOURCE: Check Rec Paper
First power off the machine. Facing the machine from the front, remove the rear tray extension that holds the paper and "feel your way" down into the right side of the of the back paper tray. You should feel a out-of-round feed roller. With a little effort you can rotate this around. Take a terry like cloth and dampen it with water and clean this roller. Before puttin any paper back into the tray, turn the machine back on so the paper feed assembly will return to the home position.
Posted on Jul 19, 2007
Logjam
  • 159 Answers
SOURCE: fax fixable? error msg
We call the moose method of clearing paper jams, the RCMP method, cuz they only know how to shoot to kill. You did good. Except, there is no such thing as "Bending" anything. The term is "re-form."
Posted on Dec 24, 2007
SOURCE: "always getting check paper size"
the sensor flag at the rear paper path sensor is worn down too short. i have seen this many times
Posted on Jun 04, 2008
playedaround
SOURCE: PANASONIC FAX MACHINE PRINTING BLACK THICK LINE
Open the front of the fax machine. Then pull down the the tray that has the down arrow imprinted on it. Locate the glass strip towards the back, just behind the center roller. Use a cloth and rubbing alcohol to clean the glass and that should remove the black line.
Posted on May 27, 2009
redzventures
  • 149 Answers
SOURCE: Paper jam in Panasonic KX-
Your document feed is separate from your received and report prints so that's why your reports are printing ok and the document feeder jams. When you open up the doc feeder and look inside the machine you will see a roller and above it on the cover that opens you will see a rubber pad. Clean both the roller and pad (in fact anything in there that is rubber) with a rubber cleaner, alcohol, or even soap and water on a cloth without it been dripping wet. You will probablt find that they are very dirty. The roller feeds the document in so that needs to be clean and the pad helps to keep all the other docs from feeding in at the same time and that should be very clean so it produces good friction.
Posted on Jul 07, 2009
Installing ink cartrage in a royal 435dx cash register
1. Open the printer compartment by lifting the black, plastic printer cover.
2. The ink roll is found in the front of the printer compartment, just behind the print
head, and is mounted in a plastic cartridge.
To remove, grasp the small clip on the left of the ink roll (where the words "PULL UP" may
be printed on the ink roll cartridge) and pull up.
The ink roll will easily pull up and away from the print head.
3. To replace a new ink roll, insert the ink roll according to markings "L" (Left) and "R"
(Right) by pressing downward to lock it into position, then close the printer cover. No tools
are necessary.
For best performance, store unopened ink roll package in a cool, dry place until installed.
NOTE: Replace with ROYAL Ink Roll, Part #013109.
Nov 16, 2010 | Office Equipment & Supplies
Paper jam in Panasonic KX-FHD331
from person who sending fax ' please eng. hany use it good
Jul 07, 2009 | Panasonic KX-FHD331 Plain Paper Thermal...
The copy/receiving function will not work.
hi,clean feed roll if the feed roll out of use please replace it.
May 14, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Apr 22, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Panasonic kx-fp155 not printing
problem is not clear.u change fax roll when it was finished.if fax was printing before ending roll .i think u have installed roll with wrong side .thermal roll only prints with one side which is coated .just see inside machine there will bi a paper for installing roll direction.if not just check thermal head .clean it check its supply.or just replace.it mian jee
Jan 13, 2009 | Panasonic KX-FP155 Plain Paper Thermal...
How do I replace the ink in Panasonic Fax, KX FHD331
First of all make sure why cover is not closing .check its locks.for to change roll just see iside the machine i am sure there will bi a printed paper from manufactrer with picture how to change a roll .it will tell u the direction of roll.by following the picture just change it MIAN AKHLAQ
Dec 18, 2008 | Panasonic KX-FHD331 Plain Paper Thermal...
Fax problem
left side is printing and right is not printing.first clean thermal head after this check cover locks may bi right side cover lock is broken .just press from right side and make a copy .otherwise replace thermal head .MIAN AKHLAQ
Dec 18, 2008 | Panasonic KX-FP80 Plain Paper Thermal...
Not printing
You probably have paper debris stuck to the underside of the print head.
While you are printing, pull the lead from the back of the printer leaving the head free floating and unlocked so you can slide it back & fore. Get a piece of kitchen roll and fold it until it's the size of the track beneath the print head slide the head to the left, place the folded kitchen roll flat down in the print track, slide the head over the folded kitchen roll until it appears on both sides of the head. Grab both ends of the roll and lift it toward the head. Slide the roll sideways left and right to physically clean the bottom of the print head. Try not to tear it as it will trap under the head. let go of one end and slide the head away until you can pull the roll out. It should have a lot of ink and gunk on it. Plug the printer in and the head will reset itself.
Now because printing has been non existant, you'll need to "Prime" the heads. Use the maintenance software and click head cleaning, when finished do not allow the nozzle check pattern to print. Carry out 3 more head cleans cancelling the nozzle check after each one by clicking [Finish] until 4 cleans have been completed. Then allow the nozzle check pattern to print and it should be back to normal. If not perfect, carry out another "Prime" as above.
Hope this helped.
Nigel
The INK Store
http://www.the-inkstore.co.uk
Dec 14, 2008 | Epson Stylus CX6400 All-In-One InkJet...
Panasonic KX-FHD331 Plain Paper Thermal transfer Fax
for printing of this machine ttr roll is use you check with another quality of that like canofax roll and cheak out for machine printing.
Mar 11, 2008 | Panasonic KX-FHD331 Plain Paper Thermal...
How Can I Reprint a Fax?
Here's a trick that I used on the Canon thermal transfer years ago. First take out the thermal transfer unit and roll up the black transfer sheet to the begining of the lost fax. Then reload the paper. Next get a solid black original equal and make a copy. The result you should get a negative copy of the lost fax. Repeat this step until all the faxes are recovered..
May 31, 2007 | Panasonic KX-FC195E Plain Paper Thermal...
jasbo
jasbo
