Question about Zanussi Microwave Ovens
Microwave door latch
One corner of the microwave door doesn't quite meet when it's closed, just a small gap but you can press it in and hear it touching. Brand new appliance. is it a problem?
  • 150 Answers
Being a brand new unit it should work properly. If it did not blow a fuse then its ok but it will only get worse with time. Have it exchanged as soon as possible.
Posted on Oct 15, 2013
MicrowaveSvc
  • 9047 Answers
SOURCE: Door latches to microwave broken
I assume you're talking about the spring that keeps tension on the door hooks (latch heads, as they're called by Sharp). When you shut the door, the "hooks" are held down by this spring to actuate the door switches. To fix this, you'll have to separate the door panels. You can download the service manual from my Web site. There's a loop built into the latch head assembly and sometimes the loop breaks. If so, you can drill a tiny hold in it and reattach the spring there. There may also be a loop on the innner door panel to hold the spring. That one can break, too. If it's broken, you'll have to find a way to secure the spring to the panel. If the panel material is thick enough, a tiny screw eye could be inserted, then epoxied overnight to secure it. I've attached a diagram to this message that should help you. If that doesn't help you, I have the service manual for the R1600-series microwaves on my Web site at: http://www.microwavedisplay.com/R1610.pdf Repost if you need more help.
Posted on Nov 15, 2006
MicrowaveSvc
  • 9047 Answers
SOURCE: sharp microwave R1940
The latch head (the assembly with the hook-like parts sticking out) also has a spring which secures it to the inner door panel. The inner door panel or latch head has a broken spring mount. To repair this, the door panels will have to be separated. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find a helpful exploded view diagram of this model at http://www3.sears.com You can order parts for Sharp models from Tritronics at http://www.wehaveparts.com.
Posted on Apr 13, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Sharp Carousel Microwave door latch stopped working door won't stay closed
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
We have *critical* safety & disassembly info at our site, linked here: http://tinyurl.com/yzjozk
We also have this full service manual at our site: http://www.microwavedisplay.com/R1480_R1481_R1482_sm.pdf
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 18, 2008
SOURCE: Broken latch microwave door - won't open
I have a semmins microwave working in great condition, last night the latch mechanism inside the microwave don't allow the door latch to close.Only the top portion, bottom portion is ok.
Posted on Dec 07, 2008
  • 228 Answers
SOURCE: NEFF H5470NOGB Microwave door latch fault
theres a small plastic hook inside the door which holds a tension spring this will have snapped off stopping the latch from entering the lock its actually quite easy to fix the inner plastic frame can be unclipped with a small flat blade screwdriver exposing the hook mechanism and the spring will be lying in the bottom of the door frame you can reconnect it to the metal inner frame it stretches the spring a little more but it will never snap again ive done this loads of times with no probs otherwise you will have to replace the outer door to reinstate the broken hook.
Posted on Aug 05, 2009
My Panasonic microwave nn-t945sfx. Door is hard to shut and is not latching correctly. I inspected the spring and latch and it appears to be working correctly. I noticed the two holes where the latch
Common problem. Apply a small dab of lithium grease to the tips of the door hooks. You might also have to adt. the door latch switch assembly inside the oven as it could be bent out of shape from the hard to close door.
Nov 19, 2014 | Panasonic Microwave Ovens
Blows fuse when you open door
Be-safe, Un-plug your microwave oven ,
Open the microwave cover ,
Close and open door few times to check the door latch(es) and switch(es).
Door switch assembly may has one or more micro switches.( Most switches are black or grey and about 1,25 in long X 3/4 in wide X 5/6 in thick with two or three wire connections).
Making sure door latch close and open these micro-switches.
You can hear the switch "clicks" when small switch pin or lever is pressed.
Sometime these door micro-switches pin or lever get stuck or broken.
You can take couple pictures before remove wires or micro switches
You can buy these switches for about 3-7 dollars online. Some web sites have video showing how to check them. (Using Volt-Ohm meter)
Jan 24, 2014 | Magic Chef MCO160UB Microwave Oven
How to fix a door latch of Samsung SMH9207ST microwave?
The small tab on the latch broke so the spring was loose. Took my drill and drilled a small hole in the main body, ran a small wire tie thru it and hooked the spring to the wire tie. Works great and more durable than the orginal dinky hook.
Dec 10, 2011 | Microwave Ovens
My microwave wont turn on. the power works, clock, timer and all electrical is working, it just wont turn on.
Most likely you have an interlock microswitch problem or a latch problem. as you just open or just close the door VERY slowly listen for 3 distinct clicks one for each of the 3 interlocks. Two you will hear as you press the door open button and the last one you will hear as the door just opens or closes. If you do NOT have 3 clicks you have a bad micro-switch.
The micro-switches you can purchase on line here:
http://www.repairclinic.com/Sharp-Microwave-Switch-Parts
Owners manual: (Provided only for telphone contacts in first 2 pages.)
http://files.sharpusa.com/Downloads/ForHome/HomeAppliances/MicrowaveOvens/Manuals/mic_man_R530ES.pdf
I think you just have a simple micro-switch problem. However... if the latch assembly that holds the switch is cracked or broken it will have to be replaced. I have seen the plastic latch assembly fail causing the switch not to work properly.
Thanks for choosing FixYa,
Kelly
Jun 28, 2011 | Sharp Carousel R530EST Microwave Oven
The top right corner of my panasonic nn-h275 otr microwave door leaves a approx. 3cm gap when closed. Fixable? Dangerous?
If the door is warped cheaper to replace the whole oven, the 3cm gap is a hazard because you have dangerous radiation leakage, the levels are exceeding safety standards and should be removed from service immediately.
Mar 27, 2011 | Panasonic NN-H275 Microwave Oven
Microwave will not cook/start when start button is pressed.
You can get the latch itself from either partstore .com or repairclinic .com
Apr 19, 2010 | Emerson MW8168B Microwave Oven
Possible door adjustment problem
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
Or you can return it for replacement.
I would not suggest trying to fix this yourself since it's under warranty.
Nov 21, 2008 | Maytag MMV4205 Microwave Oven
Oct 27, 2008 | Neff H5470 Microwave Oven
MY PANASONIC MICROWAVE OVEN HAS POWDER BUT IT DOES NOT HEAT.
I'm assuming the clock is on and controls appear to work, but won't start cooking. Quite often the latch on the door can slip out of place, so the safety interlocks do not clear even with the door closed. The latch can be accessed by removing the cover of the microwave, and should be easily visible. The latch assembly can be adjusted by loosening the screws and pushing the unit upwards. Re-tighten screws on new position. A very small adjustment is usually enough. Do not undertake repair work if you are not up to it.:::Spiceweasel.au
Apr 04, 2008 | Microwave Ovens
Microwave Ovens Logo
Top Zanussi Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
acmservice
Are you a Zanussi Microwave Oven Expert? Answer questions, earn points and help others
