Question about Ryobi Garden
No plug to join onto ignition barrel - Ryobi Garden
What wires do I join in my nc ford fairlane on the back of the ignition plug to start it I have the key and immobilizer but the ignition is broken
normally on some fords theres a round plug which clips onto the ignition barrel itself if you pull the plug off you should be able to put a flat screwdriver in center of the ignition plug and turn it like a key hope this helps im not familar with your model
Oct 11, 2016 | Ford Cars & Trucks
How to unlock ignition to a nissan stanza 1991.with key
please explain more fully as to what you are trying to do ,if its to remove the barrel then put key in and onto aux position then you can push the pin in to remove the barrel
Aug 07, 2014 | 1991 Nissan Stanza
Replace ignition lock cylinder
Hi Alex, The ignition assembly is mounted onto the steering column with blind bolts. These are special bolts designed in such a way that the heads break off when tightened to the correct torque. We usually remove them with a cold chisel and hammer. An alternative is to cut a slot into which a screw driver can be fitted. Regards John
Jul 16, 2014 | 1995 Opel Kadett 200is
How do you remove the spark plug cap. I have applied a little pressure but I dont want to damage anything.
IF you mean the metal barrel that threads onto the end of the plug:
Remove spark plug, hold by the hex with a wrench, and grab the barrel with a pair of pliers and unscrew.
May 11, 2014 | 2005 KTM 625 SMC
1992 25 HP merc Will not start when using electric start, but will pull start. What to do?
Hi, see if you have spark at the plugs when cranking with the starter motor, if not the ignition barrell may be faulty, also check and clean the multi pin plug where the main harness joins the power head harness, regards Phil.
Jul 17, 2012 | Mercury Boating
Sym jet 50 wiring
Hi, i can't exactly tell you which wire to join to which one, but i can provide you with a wiring diagram, so, hopefully, you can make it out yourself :) http://www.scribd.com/doc/9811756/SYM-Jet-Euro-Electrical-Diagram
Jun 15, 2009 | 2000 Sym Husky 125
I HAVE A MERCEDEZ 190 AND THE KEYS ARE NOT TURNING IN IGNITION BARREL NOW THE STEERING IS LOCKED ALSO I HAVE TAKEN OUT IGNITION BARREL WITH STEERING COLOUM. i WOULD LIKE TO DISINGAGE THE IGNITION BARREL...
it is better to buy a new ignition barrel.it takes a special socket to get the screws out, once the screws are out they do not need to be replaced.buy new barrel,disconnect negative battery cable,disconnect wires from barrel assembly, remove barrel from colum. first take vin# to dealership parts department to get correct barrel assembly, the keys with new assembly will fit doors and trunk
May 19, 2009 | 1993 Mercedes-Benz 190
Ignition wiring
it will need a feed from the ignition
Apr 11, 2009 | 2003 kawasaki ZR-7
Garden Logo
18 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
