Question about Hobart C-100 10 Quart Mixer
Grease for hobart c100 - Hobart C-100 10 Quart Mixer
  • 2,113 Answers
If you mean inside the gearbox then you need gear oil. Ask for it at a restaurant supply. if you mean grease for around other moving parts remember that it would be wise to find something that is food grade in case it gets into your product.
Posted on Oct 17, 2013
A-200 hobart mixer grease leak, there is grease present in some of the doughs that we make, black streaks but there is nothing dripping on to the dough...
several reasons
too much grease worn bearings or bushes not holding the shaft in the center
worn out grease seal;
the fix is an overhaul and seal replacement
Nov 01, 2017 | Hobart Food Mixers
How do I empty and then refill the grease in the gear box of my 30 quart Hobart mixer
Transmission has to be somewhat disassembled, grease removed, lower seal should be replaced and then grease added and reassembled. Not that easy to do. Check www.hobartservice.com for your local Hobart office.
May 05, 2011 | Hobart A200 Stand Mixer
What kind of oil i can used for hobart d300
Transmission uses #0 weight grease, best to get direct from Hobart (their grease is the correct weight and approved by U.S. FDA & USDA as safe for use in food equipment) but if you insist on not doing so, at least obtain an Extreme Pressure #0 grease and don't overpack the transmission, I believe it should have 35 oz. if memory serves right.
Uses a heavier grease for the planetary gear, use #2 weight. Don't need much, just a light coat on the planetary gear.
Bowl lift rails use medium weight oil, again use food grade oil supplied by Hobart.
Aug 02, 2010 | Hobart D300 Stand Mixer
How to change oil in 20 quart hobart mixer and the type of oil
on a a200 there is no oil. this mixer requiers grease. if mixer is leaking oil it is because the grease is broken down .you have to pull tpo cover off mixer remove trans. parts clean out old grease clean all trans. parts reassemble put top cover back on .then make sure mixer runs in all 3-speeds before putting 1.5 cans of -47grease back in grease can be bought @any hobart office
Dec 20, 2009 | Hobart H600 Stand Mixer
I need parts too
You could call hobart and see if parts are availiable,but i doubt it because its obsolete.Im a tech for hobart what are you looking for?
Dec 16, 2008 | Hobart A200 Stand Mixer
Sound like bearings
Ist check your agitator shaft for looseness. the shaft you put the beater on. wiggle side to side. if tight no play. If in first its quiet but you can here a grumble under load but second gets louder. and third even louder. If the shaft is tight. your gears down there are warn. you can take that all off with the two nuts underneath. and check the grease on the gears but even with new grease on them it most likely stay loud. grease it with hobart grease from your loacal hobart for the A-200 planitary not the transmision they also fve grease for Trans. if you can take the noise run it that way if not decide which arm & leg you want to give hobart for new gears.
Sep 10, 2008 | Hobart A200 Stand Mixer
Hobart N50
Some of the N50's were packed with a white grease. It tends to seperate. So the oil portion finds it's way out. It sounds like it is getting into the motor case, and is running down the inside of the column. Hobart now uses a brown clay based grease --- Darina 2.
If the amounts are small, and the mixer is not excessively noisy, I wouldn't be concerned. If you wanted to fix it, the transmission would need to be removed, cleaned, and repacked. For a Hobart tech, 3 hours labor, $45 grease, plus parts.
Jun 19, 2008 | Hobart N50 Stand Mixer
C100
Parts are no longer availiable for these units as they are old.You may be able to find something online like ebay ect,ect.I work for hobart as a service tech and havent repaired one of these units in 15 yrs.
Jun 07, 2008 | Hobart A200 Stand Mixer
A200 Mixer/Medalist L120 Mixer by Hobart
Where is it leaking grease from?Im a hobart tech and service these mixers.When i go into work i will get you the part # for the grease.You would then have to contact your local hobart branch,tell them the part # and pick up the grease.
Feb 25, 2008 | Hobart A200 Stand Mixer
How do i lubricate my 20 qt Hobart mixer and what kind of oil do i use?
you can call your local hobart branch for the part number,but you use lithium grease in the unit.in order to change the grease the transmission needs to be opened and so does the planetary. i service these mixers alot i work for hobart.if you need any more help/questions let me know.
Dec 23, 2007 | Kenwood KM400 / KM410 Chef Classic Stand...
Hobart C-100 10 Quart Mixer Logo
127 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
