Question about Garden
CubCadet ZForce 23 50" - runs, but dies when try to move
I was mowing and it suddenly just died and I couldn't determine why. Now, with blade switch off, as it should be ... it starts and runs fine, but when I try to release brake lever or bring steering handles together, it kills immediately. If I reset the brake and/or separate the handles while the engine is dying, it takes off again, but I can't go anywhere.
  • csummerspm Apr 25, 2009
    You are good :)
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 109 Answers
The safety switch under the seat is faulty and it must be replaced.
Posted on Apr 25, 2009
What would make my mower try to die w/blades engaged?
There are safty switches install on the seat. If you get up off the seat it will shut shut off. You need to to disengage the blades to get off the machine and leave it running. You may also have an issue with the switch setting. Lift up the seat and look for a switch trigger.
hpoe this helps...
May 01, 2016 | Garden
Just received my model 247.290001 mower was mowing when engine dies and will not turn over now
Did it stop suddenly? Or splutter and cough like an engine problem? If suddenly I'd suggest checking the seat switch wire hasn't become disconnected, if this doesn't solve it then check all the other safety switches.
Aug 14, 2015 | Sears Garden
Why does my toro model 74301 keeps dieing
There are many reason a lawn mower dies in gear. Buildup of grass on the underside of the deck, mowing in too deep or thick lawn causing too much load on the blade, or the air filter needs cleaning.
Jul 19, 2014 | Toro Garden
My mower will die everytime i engage the blades to mow
Check to see if one of your deck spindles isn't seized. Disengage the blades and turn each blade to see if its free. Sounds like either a spindle is seized or your electric clutch on the motor has a problem.
Jul 20, 2013 | Yard Man Yardman Riding Lawn Mower 38in...
Dies when try to engage blade
there is a switch underneath seat that shuts blades off if not pushed down or there is another one on the reverse that shuts off blades off when mowing one could have went bad hope it helps
Apr 16, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a 18.5 Poulan Pro riding lawnmower that runs fine untill I activate the blades. It then dies after mowing for a few minutes. I disengage the blades and it runs fine. Any solutions?
does it loose power then die or just shut off?does it run rough then die?try and run it with the gas cap loose th event could be plugged and the extra fuel needed to mow the vent might not be keeping up or a plugged fuel filter
Jun 06, 2012 | Garden
I have a craftsman garden tractor. I was mowing last Saturday and my mower died. I was able to jockey the break and hand throttle enought to move the mower back to the shed. Everything seems to check...
Check your seat switch. It is a prermissive switch. If the switch believes that the operator is off of the mower, any action that could hurt the operator is "denied". Both the operation of the blades and the movement of the tractor are dependent on the seat switch believing that you are on it, and in control. Pretty neat, huh? Except when you are on it and it doesn't believe you..... Try the switch. Usually they are just loose, but it might also be a loose or corroded wire at the switch.
Best of luck,
--W/D--
Aug 13, 2009 | Garden
LTX1000 42" 18HP Kohler - Blowing fuse after 2-4 min mowing.
sounds as though you are on the right track
but be sure to check the wiring directly from the electric clutch on the front of the motor back to the switch
a wire could be pinched in the frame and shorting out intermittingly
look around and find those wires and move them around and look for chaffing and tightness
and what you could also do is to unhook the clutch at the connection to it at the front of the motor and engage switch and ride around and see if fuse blows and if not you may have an electric clutch issue
Jun 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Dies when clutch disengaged
It sounds like the seat switch is disconnected or failed. Check it out. If it thinks there is no **** on the seat it will cause your symptoms.
May 25, 2009 | John Deere Garden
Cub cadet zforce
hello
check mower deck is not caked up with grass if it is it will not get enough air movementto force the grass up the chute
also try cutting in 2or3 passes so that you are not forcing too mush grass up the chute
hope this helps
Mar 13, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
208 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
