Question about Chaps Annabelle Window Treatments
Looking for these drapes and can't seem to find them anywhere
I am having rf problem remotes work most of time seems afternoons are the worst
Remotes use Infrared (little bulb sticking out the end) not radio signals. You probably have problems because the setting sun is coming through the window flooding the room with heat/light. try closing the drapes.
Apr 19, 2017 | Televison & Video
How to clean tri fold cloth window blinds
if they are that far gone I would just replace them. I don't know of any way to remove tar stains. The time that it would take to clean them would cost you the equivalent of buying new blinds.
Jason'http://shutterupbus.com
Jun 25, 2013 | Cars & Trucks
Went to vacuum the drapes... suction too strong, drapes came off the window and tore in the hose. how do you adjust the suction?
For cleaning drapes and more delicate furnishings, the stair tool or crevice tool supplied with your cleaner may be the most appropriate choice. They're designed with airflow holes which reduce pressure at the end of the hose, without compromising pick-up performance. You should find this allows you to clean the drapes more effectively without pulling them into the hose. It may also help to hold the drapes in place with one hand whilst vacuuming with the other.
If you need any further information on using or maintaining your Dyson cleaner, please get in touch with us directly. One of our experts will be happy to provide the assistance you need. You can call us free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Dyson Online Customer Support
Sep 15, 2011 | Dyson Vacuums
How to remove the drivers' side glass from the regulator- looks like rivets need to be drilled out, can't get to one. Bought a regulator/motor all-in-one assembly from American Muscle as replacement. Can't...
Check out what a replacement looks like at the ford dealer (compare)
You may have to do the rivets to remove, and again to put in a new or old working motor.
May be able to bolt back together
Check window height ,window down,before removal or use other side as a gauge of installed height
Oct 21, 2010 | 2001 Ford Mustang
Chaps Annabelle Window Treatments Logo
851 people viewed this question
Top Chaps Home Experts
Donni Steen
Tom Chichester
Are you a Chaps Home Expert? Answer questions, earn points and help others
