Sansui sv2918 when set is cold the spaekers makes a crackling sound????
  • 77 Answers
It might be the audio amp acting up when cold they have caps in the audio supply that dont have the correct value till it warms up. that is located on the main board
Posted on Oct 15, 2013
2 Suggested Answers
salt56
  • 373 Answers
SOURCE: how do i stop a
If the channel are constantly changing then you have bad channel switch inside the set. The switch is located just behind the channel up or down (depending on which direction the channel are going). I have fixed them before by taking the back off and squirting with WD40 to loosen them up. However, the best fix it to replace. They are called tact switches and there are many different kinds in different TV's You would have to have the exact replacement. Has to be unsoldered the old and solder in the new. I recommend changing all of them including the Volume + and _ and the others as well. Do a search online for electronic parts and you will find a supplier.
Posted on May 29, 2011
What is the value of cap c415 on sansui tv sv2918
Make sure you use an identical capacitor!
Feb 22, 2017 | Sansui Televison & Video
My Sansui SV2918 has vertical collapse and no sound.Please help.
Sansui.. Funai made?? Most Funai sets are identical. Find a diagram for a similar TV. Or.. Google the part# of the output IC. The datasheet should contain application data, including a basic schematic of the vertical cicuit.
May 19, 2014 | Televison & Video
Sansui sv2918 keeps blowing k2996 mosfet. Power led flashes and ta-ta-ta sound is heard
Check the Flyback Transformer
and associated circuits.
If 2SK2996 is blown, it may take out the PWM IC and some components
that goes with it.
Let me know what you find or needs further assistance.
Sep 17, 2012 | SansuiM1315 TV
I have a sansui tv model sv2918,it doesn't play
The TV has some firmware defect. Seek tech support.
Unplug it from AC mains wall socket, and plug it again after 5 minutes. This must make it a hard reset.
May 31, 2012 | Samsung Televison & Video
After about an hour the tv soaun makes a
  1. The most likely cause of this is dirt/dust in the volume potentiometer. When the set gets warm it starts to crackle. You can try bllowing or sucking the dist out of the set. But the better option is to have the sound module replaced
Aug 21, 2009 | Sansui HDLCD3210 32 in. LCD TV
Powersupply Faulty
Check for short circuit on your Powersupply. If you can isolate it, much better. check the voltage regulator if it supplies power to the system. better still check the regulator itself.
Jul 10, 2009 | Televison & Video
Hi I live in Kempton Park South Africa and my Sansui TV Model SV2918 does not swith on. The product is very good and I would like it to b repaired. Do you have suggested maintenance people that I coul
Hi, I need assistance re tuning my TV for the VCR. I am not able able to get the two solid test lines. My TV is a Sansui SV2790NICAM and the VCR an Orion.
Please help!!
Mike, C.T.
May 25, 2009 | Televison & Video
Faulty line stage sv2918 sansui tv
Can you please post the make and model. That would help u sto provide you with more details.
Thanks,
Dan
Dec 01, 2008 | Televison & Video
My AS 500 Sound Bar speakers are crakeling (PArt # 4y463)
Usually, the crackling indicates a connection that's not making a good connection. you can try twisting the plug where it connects to your computer and see if you can get it to make a better connect. Also, you may try cleaning the plug itself. When cleaning contacts with any sort of household alcohol, be aware that it can leave a residue so you'll need to use a clean/dry tissue to dry the plug and remove any residue. -hope that helps.
Nov 30, 2008 | Dell AS500 Sound Bar Computer Speakers
Sansui tv sv2918
replace vert IC301, C432, ( D431 & R431 should also be blown)
Jun 18, 2008 | SansuiM1315 TV
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
