Dynex dvd dxldvd2210a
The DvD player keeps clicking when I turn it on. Sometimes it stops after 5ish minutes, tonight it's been going for 15 and I need a fix.
SOURCE: Need instruction manual for DXPDVD9A
Go to http://su manual .com
Posted on Mar 29, 2008
Richie_asg1
  • 1036 Answers
SOURCE: Keeping the DVD player going
The problems with dvd & cd players, are located in two areas - both mechanical.
#1 On the laser cartridge, there are minute springs that hold the lens while a coil and magnet arrangement moves the lens (similar to a speaker cone) to focus on the disc. These springs become weak and break on the cheaper models - Therefore it can't see the disc information clearly - and the output is not digital - it says no disc.
#2. The main bearing at the centre of these drives can run dry and start to become rough. This may cause the disc to wobble enough to start to vibrate. This failure is characterised by a noisy drive just before giving up.
So use a product that sources a quality optics package, and a decent framework.
It's amazing that the electronics can compensate for cheap build quality - but they do! - a bit like good suspension compensates for bad road quality.
Posted on Jun 11, 2008
  • 979 Answers
SOURCE: FIXING A CYBERHOME PORTABLE DVD PLAYER
For whatever reason, the laser assembly is not able to read the discs. This could be caused by any number of reasons including an alignment gone bad, to a dirty lens, to a bad laser diode...accordianman
Posted on Jul 07, 2008
SOURCE: Dynex DVD player keeps saying no disc.
unplug tape - like connection at laser - eye & replug it. Disassemble first. IT WORKED FOR ME !!!!!!!!!
Posted on Jan 09, 2009
  • 814 Answers
SOURCE: DVD player plays 10 minutes and then freezes screen.
You may have a problem with the transport of the dvd laser. Open the compartment that you place the dvd into. You will see the spindle,the laser lens and the transport device that moves it during operation. The transport system operates on system of gears and drive rails. You must check and clean the drive rails and gears. Use a can of compressed air and blow all the dust and debris from the dvd compartment. Then use some cotton swabs with a small amount of isopropyl alcohol on the tips and clean all the rails and gears. Check the transport action by moving the transport to its most outer position and back to its most inner position. The action and travel of the transport on the rails should be smooth and easy. The gears should be clean and move easy also.These parts will require cleaning every month or so . Remember do not touch the laser lens with your hand. You should also check the lens it should look bright and shine. If not try cleaning it with a cotton swab and a small amount of alcohol. Rub the lens gently back and forth unit it is bright and shines.Now you can try playing a dvd and see if the player works properly. If this does not fix you problem. You can reset the dvd player to the factory settings.1.Press the setup button on the remote control.2.Use the left and right arrows to highlight the preferences page.3.Press enter to to enter the preferences sub-menu.4.Use the up and down arrows to find the default function and press enter. You now have reset the dvd player to factory settings Now again play a dvd to see if the player is functioning normally. If not you may have a more serious problem with the drive motor or power supply circuits. you can call Insignia customer service support at this telephone number.1-877-467-4289. Give them the model number of you dvd player and tell them the problem you are having with the loss of operation during the playing of a dvd. They will be able to tell you how to get testing and service for you dvd player. I hope this information helps you with your problem.
Posted on Jun 03, 2009
Dynex 32" 720p Flat-Panel LCD HDTV - Matte Black Logo Print Email Problem with Dynex 32" 720p Flat-Panel LCD HDTV - Matte Black I have a Dynex Bluray Player and when I connect it with AV Cab
If the item is under warranty return it asp. The problem is in the power supply, the cause is a open capacitor sometimes leaving a bulge at the top.
Apr 25, 2012 | Olympus Televison & Video
I have lost the adapter/charger for my DVD player. It is a DX-PDVD7 player. where can I get a new one?
Here are some links to a few different EBay listings for that item which is currently available online for around $10 US plus shipping:
http://www.ebay.com/itm/AC-power-adapter-Dynex-DX-PDVD7-Portable-DVD-player-/370489198814?pt=Laptop_Batteries&hash=item5642e088de
http://www.ebay.com/itm/AC-ADAPTER-POWER-CHARGER-DYNEX-DX-PDVD7-DXPDVD7-DVD-/290584026872?pt=COMP_EN_Networking_Components&hash=item43a8285ef8
http://www.ebay.com/itm/Car-Auto-Adapter-Charger-4-Dynex-DX-PDVD7-Portable-DVD-/270792672179?pt=LH_DefaultDomain_0&hash=item3f0c8043b3
http://www.ebay.com/itm/AC-ADAPTER-POWER-CHARGER-DYNEX-DX-PDVD7-DXPDVD7-DVD-/260834054534?pt=LH_DefaultDomain_0&hash=item3cbaebd186
Just use your mouse to click on the links, which are the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information and items at the website indicated.
I hope that was helpful to you, good luck and take care.
Joe.
Sep 19, 2011 | Dynex Televison & Video
DVD player in 1913-TDXB makes noise and won't allow TV to operate. First the DVD player quit working and now it makes a clicking noise when the set is turned on and set won't go past the DVD. Can the DVD...
Take the tv aparts,take some Q tips with some rubbing alcahol clean the DVD laser eye.Should help the DVD player side to work,than the tv might go in to the functional modes.
Apr 14, 2010 | Televison & Video
Diamond VC500 One Touch Capture not recording properly.
Try turning off your screen saver. The recorded file will reset to zero whenever the screen saver kicks in.
Feb 25, 2010 | Diamond Multimedia ( VC500) Video Capture
Loading keep flashing when powered on
Turn the unit off for about 10 minutes and then turn it back on. Then just wait for 'Loading' to go out - it can take 15 minutes or more. Be careful as the power supply on mine blew up after 2 years and I had to fit a new one £95.
Jun 05, 2009 | JVC DRMH50 DVD Recorder
Audio stops working on my new dynex dx-lcd32-09
Bad TV. You should call for warranty replacement
Feb 01, 2018 | Dynex 32 in. LCD Flat-Panel HDTV
Nov 30, 2008 | Dynex DX-PDVD7 Portable DVD Player
VENTURER DVD PLAYER
lookind for a venturer 8.4 widescreen portable dvd player pvs 1080g
Oct 11, 2008 | Dynex DX-PDVD7 Portable DVD Player
Screen just flickers when I put a disc in the player.
My dvd player will show the movie for awhile the it would stop turning and go any further. I would say it plays for 15 minutes any suggestions
Jul 21, 2008 | Dynex DX-PDVD7 Portable DVD Player
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
