Question about Verilux Home
Verilux light switch is broken. I have to unplug it to turn it off (or plug it in to turn it on).
    Problem Solver:
  • 13 Answers
Disassemble at the switch and check the wireing
Posted on Oct 15, 2013
Testimonial: "How does one disassemble at the switch? Thanks."
Where can I buy a Verilux VD01 lamp Ballast? I am hoping to find an inexpensive generic one if possible. Thanks in advance.
Direct. They state it has a 'replaceable ballast'.
http://www.verilux.com/customer-service/product-warranty/
VD03 here, but they seems to only do one ballast.
http://www.verilux.com/parts-and-accessories/ballast-lamp/
If you go to an electrical supply outlet, you may be able to get a generic one, but that looks a funny shape. They are usually long and rectangular.
Amazon do lamps but no ballast.
http://www.amazon.com/s?ie=UTF8&page=1&rh=i%3Aaps%2Ck%3Averilux%20lamps
Jan 28, 2016 | Televison & Video
My verilux comes on then goes off
Make certain that the bulb you replaced is seated securely. If it is, than it sounds like an internal failure of an over-temperature component (but I really don't know what the internal wiring and discrete components are used in these. I do know they are subject to line surges such as a lightening hit on the mains, even dozens of miles away.)
Probably best to talk with customer service their Customer Service Department at 800-786-6850.
If it's within the one-year warranty period, you could return it to them at: Verilux, Inc., 340 Mad River Park, Waitsfield, VT 05673 and have them repair it (proof of purchase will be required).
Apr 09, 2014 | Verilux Modern Deluxe Natural Spectrum...
Free huskystar e20
since the lights turn on then you can rule out the on/off switch and the power cord
could be a
broken part
a timing problem
try unplugging the foot pedal and then plug the foot pedal back up and see if that help
if that doens't help then it would be a good idea to have the machine checked
Oct 24, 2013 | Sewing Machines
Side lights dont work
Fuse sure didn't play, bulb is unlikely to be all bad. Check the turn signal switch, first find the turn signal switch plug, put the key to ON file, in trying to find a turn signal lamp switch wire (flash to the thread) will this wire with no light ON one side of the turn signal line connected to see if a turn signal light, the light is turn signal switch is broken, or the plug contact undesirable, don't light it is turn signal switch to light ON one side of the light path, in order to determine whether the light bulb is broken can open a small lamp or led brake lights to borrow their wire leads to a turn signal whether turn signal light, so you can determine whether the light bulb not bright side is broken.auto diagnostic tool.
Apr 10, 2013 | 2001 Alfa Romeo 147
Hazard light will not turn off on my 1998 chevy blazer
broken switch. unplug it if it stops that is your problem. if it is on the steering just find the plug under the kick panel , DO NOT UNPLUG THE YELLOW CONNECTOR that is your air bag system.
Apr 07, 2012 | 1998 Chevrolet Blazer
I need to replace old 60-watt incandescent light bulbs in fixtures that are covered by glass domes. A hardware store man once told me that the new fluorescent bulbs would not be good because they...
you could go and get led light to fit them, they are very good and they give off very little heat, a little expensive but in the long run it will be better than the currly q lighting
Aug 22, 2011 | Verilux Home
Lamp is sitting next to my computer. When lamp is turned on, it darkens computer screen. Computer screen light returns when lamp is turned off.
Your computer screen may have a light leveling sensor, if you find your monitor has this you can cover the sensor with electrical or masking tape. Clear plastic tape will not help. Good Luck!
Douglas
Jan 02, 2011 | Verilux Modern Deluxe Natural Spectrum...
How do you get breaklights unstuck ?
If it's truly the brake lights, there is a switch behind your brake pedal (usually white) that has a spring loaded button on it. Either the switch has gotten moved out of place and stuck or it is broken. It is held in by a bracket and probably no screws. It is very easy to replace. The bar that the foot rest of the brake pedal is attached to depresses the button turning on the brake lights. Just unplug it (if broken and plug in new one and snap into place. Pretty simple.
Good luck
Oct 15, 2010 | 1998 Nissan Frontier
I can't turn the monitor on. The light continuosly flashes
I would go ahead and get a new monitor. It sounds to me as if the button is broken were it connects on the inside
Feb 23, 2010 | Acer Value Line AL1717B Monitor
The main switch is broken off and it does not turn on
You have to remove the entire wrapper to get to the control circuit board, make sure you unplug unit!! Locate the small white wires that plug into the board and go to the humidity switch.Unplug the connector at the board and plug the machine in and see if everything runs. ps make sure you reinstall the bucket or unit will not run. If machine runs replace that humidity control. The plug on the board is usually white. The other white wire is 4 the light. I hope this helps./
Sep 05, 2007 | Goldstar DH304 Dehumidifier
Home Logo
217 people viewed this question
Top Verilux Home Experts
Donni Steen
Tom Chichester
Are you a Verilux Home Expert? Answer questions, earn points and help others
