Question about Garden
Jacuzzi j310 hot tub
I would like to know what Amp. breaker this model needs
  • 2,113 Answers
Http://www.jacuzzihottubs.com/brochures/archive/PROTECHLED2003.PDF
40 amp double breaker with at least 8 AWG 3 wire and a ground
Posted on Oct 17, 2013
3 Suggested Answers
SOURCE: need a users manual
Kathy,
I think what you're looking at are the part numbers for the heater and control systems used in some Jacuzzi hot tubs rather than the Jacuzzi model number. I ran into the same issue and discovered through some cross-referencing on the web (jacuzzi parts suppliers) that this is the part number control unit made by Balboa. Odds are they were used in multiple Jacuzzi models.
My suggestion: Look here http://clearcreekspas.com/model_id.html to identify the control panel for your Jacuzzi and then follow the link to the correct manual. Some cover multiple models so you will need to know the electrical requirements of yours (120 V or 240 V?) and then check the layout of each tub shell to determine which model is yours.
I figured out mine is a Jacuzzi Essence Model 350 this way.
Posted on Dec 07, 2008
  • 37 Answers
SOURCE: How to Get Hot tub off sleep mode
press temp button and then the light button in sequence.
Posted on Dec 10, 2009
I need to find a service man in the Seattle area to get my tub working. It has power but won't come on.
then look in a phone book for a plumber . I am sure there are more than 1
Feb 11, 2016 | Home
I recently switched some breaker around in my fuse box. There were a few 110's and 220's not being used. I deleted those to make some room to put a larger amp breaker for my hot tub that been sitting
Try for what ?
You removed breakers not needed or ones with little
on them, to make room for a larger 50 amp Hot Tub
Breaker,so you got your hot tub powered up
What is the question,seems you solved the issue
by making room for the new breaker !
Nov 21, 2014 | Electrical Supplies
PDC hot tub is tripping breaker
most breaker trips are from water leaks (inside/out and outside/in) and bad heaters in hot tubs i have found
Oct 15, 2013 | Jacuzzi Pool & Spa
Circuit braker keep popping
Sounds like the heating element has gone out again. Once you reset the circuit breaker and the tub turns on it will start to circulate the water. This usually runs like this for about 2 mins and then the tub will recognize it is cold and send power to the heater. If the element is back at that point it will blow the circuit breaker.
If this circuit breaker pops as soon as you turn it on then you most likely have a bad circuit board.
Rod
www.uspartscenter.com
Jan 30, 2013 | Jacuzzi Home
My hot tub top control is flashing SPA6,and hot tub is not heating up.
Here is a link for you to resource that error code.
click that link and scroll through them until you find your error code.
Rod
US Parts Center
Aug 19, 2012 | Jacuzzi Pool & Spa
Jacuzzi hot tub , trips the circuit breaker, inspection found a burn't part Z-1 in on wiring digram. Can some one help with what a z-1 is Capacator?
If you have something burnt on your circuit board you will need a new circuit board.
begin with finding the chip number on the circuit board. this chip is usually located close to the transformer on the circuit board.
Rod
US Parts Center
888-521-6183
Jun 24, 2012 | Jacuzzi Pool & Spa
The hottub keeps kicking the circuit breaker off.
Either the breaker is bad or you have an electrical problem. Unless you know how to work with electrical problems call for service. If you unplug the hot tub and plug a lamp or hair dryer into the outlet does the breaker trip? If yes, call an electrician. If the outlet is fine call for service on the hot tub.
May 01, 2010 | Home
Froze the jacuzzi.
You'll need to start electrical troubleshooting from a point where you have power and then keep testing further into the unit to find out where the power stops. Is there a local 'ground fault' reset button inside the hot tub control area (under the tub?)
Jul 11, 2009 | Home
How to wire up a spa or jacuzzi
Breaker, even GFI's are designed to trip at 135% to 600% over there load rate, so not to scare you but it depends more on the wire used from the main panel to the dryer/hot tube then the breaker. A GFI's claim to fame is the speed at which it will trip if voltage is detected on the ground side of the breaker. So to answer a question with a question, Can you overload a GFI without tripping it, Yes you can, just be careful the life of your hot tube motor and heater could be in danger if you overload the circuit.
Mar 24, 2009 | Spa Parts Plus GFCI, Circuit Breaker, 30...
Need a users manual
Kathy,
Nov 11, 2008 | Balboa Instruments Garden
Garden Logo
50 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
