Question about IBM ThinkPad T41 Notebook
Touchpad driver - IBM ThinkPad T41 Notebook
Keyboard unlock
Like most modern laptops, IBM/Lenovo laptops feature a built-in touchpad that you can use as a substitute for an external mouse device. If you experience a non-functional or "locked" touchpad, then you have one of two possible problems; either the touchpad's drivers are corrupt or a user has manually locked the touchpad. In either case, you can unlock your touchpad and restore it to functionality quickly.
Open your web browser and paste the following URL in the address bar:
Click the "Download" button and then click "I agree" to save the Lenovo touchpad driver installation file to your computer. Double-click the EXE file that you downloaded. Doing so opens the driver's installation wizard. Follow the on-screen prompts to re-install your Lenovo's touchpad drivers. If your locked touchpad is due to a corrupt or outdated device driver, then your touchpad is now unlocked and functional. Activate Touchpad Hold the Windows logo key and press the R key to open a run command box. Type "control mouse" in the box and press Enter. The Mouse Properties control panel window opens. Click the "Device Settings" tab. Click the Lenovo Touchpad in the "Devices" list and click the "Enable" button to activate the Touchpad. Click the "OK" button to save your changes. Your Lenovo's touchpad is unlocked and ready for use. Lenovo support
http://consumersupport.lenovo.com/vn/en/DriversDownLoads/drivers_show_120.html
Feb 24, 2013 | Lenovo Computers & Internet
Touch screen not working
The touchpad on the Acer Aspire is built into the notebook itself, which makes the device much harder to troubleshoot or replace. While you can connect a universal serial bus mouse to the notebook if the touchpad becomes unresponsive, attaching any external device reduces the notebook's portability. Although hardware failure can cause the touchpad to stop working, most device-related problems are due to software settings or other conflicts.
Hardware Conflict
Peripheral devices connected to the Aspire can interfere with the integrated touchpad. Disconnect all of the external devices, except for the power adapter, that are connected to the Aspire; then restart the computer. Test the touchpad after booting into Windows. If the touchpad responds, a hardware device is interfering with the pointing device. Reconnect each device one by one to the notebook, testing the touchpad throughout. If the pointing device stops responding after connecting a particular device, the component is interfering with the touchpad. Go to the device manufacturer's website and look up the product model. Check the bulletin board to see if the manufacturer has posted a notice or update addressing issues with device conflicts. If no such update is available, download the latest driver for the component and install it on the computer. b> Disabled Touchpad b> The Acer Aspire 5516 comes with a preset group of keyboard combinations, called hotkeys, that are used to enable or disable devices, configure sound volume and screen brightness, and control the notebook mode. The hotkeys "Fn" and "F7" turn the touchpad on and off. If the integrated mouse is unresponsive, hold down "Fn" and press "F7"; then test the touchpad to see if the device reactivates. If the touchpad still doesn't work, open Device Manager from within the Control Panel. Expand "Mice and Other Pointing Devices," then right-click the touchpad device. If the touchpad is disabled in Device Manager, you'll see the "Enable" option in the context menu. Click it to turn the touchpad back on; then restart the computer. Corrupt Driver b> Windows Vista talks to the touchpad through a program called a device driver. The driver enables Windows Vista to "see" the touchpad and send it instructions. Once the driver communicates these instructions to the touchpad, the touchpad informs the processor that it needs to perform a task, and a specific set of code is performed. If the driver for the touchpad is outdated or corrupt, or if the driver isn't compatible with the OS -- Acer offers touchpad drivers for Windows XP and Windows 7, but these drivers won't work with Windows Vista -- the touchpad becomes unresponsive. Expand the "Mouse and Other Pointing Devices" section from within Device Manager; if Windows detects a problem with the driver, it places a yellow exclamation point or red "X" next to the device. Double-click the touchpad driver to see the error message; then look up the message on the Microsoft Support website for further assistance. b> Touchpad Settings b> Mouse Properties, accessed through the Control Panel, contains several different configuration settings that can alter how the touchpad behaves on the Aspire 5516. On the "Device Settings" tab is the option "Disable Internal Pointing Device When External USB Pointing Device Is Attached." As the option states, if an external mouse is connected to the Aspire 5516, the touchpad will stop working; disable this option if you're using an external pointing device. Clicking the "Settings" button opens the "Properties for Synaptics Touchpad" window. On this screen are the "PalmCheck" and "Touch Sensitivity" options. If PalmCheck is set too high, or Touch Sensitivity too low, the touchpad won't respond to normal touch, making the device seem unresponsive. Hope this helps.
b>
Dec 31, 2012 | Acer Aspire Z3801 All-In-One Desktop Pc...
My touch pad scroll function is not working on my Toshiba satellite M300 laptop
To use scroll function, you have to install the touchpad drivers, which are available from Toshiba Official Support. Click Here to download the required touchpad drivers. Select 'Touchpad' from Category and install Synaptics or Alps Drivers (Depending upon the type of touchpad you have on your system).
Hope it helps! Good Luck!
CreativeTECH
May 25, 2011 | Computers & Internet
My touch pad has stoped workind
Hi.
Based on the information you have provided, the issue might be due to the Touchpad Driver.
Hence, it would be better to re-install the Touchpad Driver.
You may download the Touchpad Driver from the below link:
http://support.asus.com/download/download.aspx?modelname=Eee%20PC%204G%20Surf/XP&SLanguage=en-us
Please open the above link and select the Operating System installed in the Computer.
Then, click on the Touchpad option to view the Driver.
Download and install the Touchpad Driver.
Re-installing the Touchpad Driver should resolve the issue.
Please perform the above steps and let me know the results.
Hope this helps.
Please feel free to contact for further information and assistance.
Sep 21, 2010 | ASUS Eee 4G Notebook
My touchpad scroll not working
Problem with touchpad driver. Download and install latest driver from the manufacture's website (synaptics, alps...) if you know the driver name.
Else try the software DriverMAX
(downloadable at http://www.innovative-sol.com/drivermax/)
Im using DriverMAX. Its a good software that can automatically detect versions of drivers in our computer and update them if you have internet connection.
Also ensure that in startup programs (RUN>MSCONFIG) the touchpad driver entry is enabled!!
Oct 26, 2009 | BenQ Joybook 5100U Notebook
My touchpad mouse is not clicking
First check in control panel that your touchpad mouse is enabled.
Then if it is enable alrady then uninstall touchpad driver then reinstall driver.
If you haven't driver then download driver from this link.
http://gd.panam.acer.com/home/
select your model and operatign system then download touchpad driver.
Let me know if you need more assistanse.
Thanks.
Sep 13, 2009 | Acer Aspire 4930-6862 Laptop
HP Pavilion DV1000 touchpad and keyboard freezes
sometimes its a hardware driver software and OS driver software conflict on touchpad. if after OS installation the touchpad is already detected, no need to install the touchpad driver. try disabling the touchpad driver you installed. hope this helps
May 30, 2009 | HP Pavilion dv1000 Notebook
The touchpad got locked
u can try this all u can do is just go to this website and click on driver detective scan now and then click on the download now and then restart ur computer and then the touchpad should work and still if it doesnt work then uninstall and resintall the touchpad driver and the synaptic drivers and restart the computer and still if it doesnt work replace the touchpad from dell...the website is http://www.drivershq.com/Drivers/VistaDevices/Dell-Input-Dell-Touchpad-Pointing-Stick-Driver/13926/Drivers.aspx ................... thanks
Jan 22, 2009 | Dell XPS M1530 Laptop
Dell touchpad problem
Try to reinstall the touchpad driver.
Get it from this link.
Dec 09, 2008 | Dell F3534 Touchpad
Dell Touchpad
Download and run the touchpad driver from support.dell.com. Go to drivers and downloads>enter your service tag or choose your model>choose your operating system and click the "Input device drivers" category and download the touchpad driver.
Jul 25, 2008 | Dell F3534 Touchpad
IBM ThinkPad T41 Notebook Logo
15 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
