LCD projector red temp light appears for seemingly no apparent reason after runtime of about 45 minutes
  • AlB1 May 11, 2010
    Is the filter clean?
  • 4 Answers
Over heating, if it has it, check the fan
Posted on May 02, 2009
After 10 to 15 minuts automatically system display off
"Temp" light is red ,means that the projector is too hot
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
skype:lampdeng
Feb 28, 2014 | Dell 1210S Projector
I have a Benq w710st DLP projector and when i turn the power on after a minute it turns off. The power button turns off and both the lamp and temp lights turn red. How do I fix this and can I do it my
New bulb is probalbly needed. You need to find out what zero means on that projector. The real problem is finding out why the cooling fan is not turning on. This is probably the reason that the temp light is coming on.
Jan 06, 2013 | BenQ W710ST 3D HD Short Throw DLP...
After changing the bulb image will not come on and solid orange light appears
Other then POWER BUTTON light there are three lights more
1. lamp indicator
2. temperature indicator
3. computer input
witch one light is flashing RED or illuminated RED with POWER BUTTON orange light.
If LAMP INDICATOR light is illuminated RED than lamp runtime has reached 1800 hours. but projector still working.
If LAMP INDICATOR light flashing RED than lamp circuit failure, or abnormal function or lamp unit is damaged. In this case projector doing the same behave just like your projector.
if TEMPERATURE indicator illuminating RED the projector still projecting and if flashing RED than turned of itself
Jan 11, 2011 | Panasonic PT-LB50U Multimedia Projector
Our projector has said replace lamp for approx. 1 year. We did and it still saying to place lamp. Also it stops projecting after about 5 minutes and then 10 minutes later we are able to use it again for...
You need to reset the LAMP RUNTIME counter
1. Press the MENU button to display the menu screen
2. Press the UP and DOWN arrow buttons to select the "OPTION" menu
3. Press the ENTER button and then press the UP and DOWN button to select the LAMP RUNTIME
4. Press and hold the ENTER button for approximately 3 seconds
5. The LAMP RUNTIME screen will be displayed.
(Note: press any button other than the Power button to cancel the LAMP RUNTIME screen)
6. Press the POWER button to turn off the power
7. After the POWER button on the projector illuminates red you restart the projector
and check the LAMP RUNTIME counter it should be "0"
Nov 24, 2010 | Panasonic PT L735U Multimedia Projector
All the lights are on: power light, lamp light and temp light... How can I fix it?
If you have the manual you can look at the back for troubleshooting. The problem or solution will depend on if the lights are blinking and what color they are. The manual can be found here. You will want the basic operations manual.
http://support.casio.com/manualfile.php?rgn=1&cid=007001005
I just had a XJ- S41 projector in for repair because it wouldn't power on. The power light was red solid but the temp and lamp lights were blinking red. Apparently a reset was needed, but I was told it was an internal reset that had to be done be a technician. I'm dubious of this info as I've seen some reset procedures listed on this site that may have worked, but I can't confirm as I sent it in. It cost $45 plus shipping to have Casio do this reset and there was nothing wrong with the projector or any parts replaced. Casio wouldn't tell me exactly what reset procedure was done and they will not let you speak with a technician or even try and get more info for you. Using their online repair service though was easy and swift. Just go to www.ecasiorepair.com.
Nov 12, 2010 | Casio XJ-S31 Projector
My TLP680U projector shuts off after 1o minutes of operation.
toshiba is not one of the most rliable makes im afraidi have seen this fault before and it turned out to be the bulb which i had recentley replaced and this was apparentley the wrong one and gave the same sort of results.
Feb 25, 2009 | Toshiba TLP 680 Multimedia Projector
Projector shuts off after about 45 minutes
Just a long shot, but...
I have an epson 9000i that did the same thing. Turns out that unit has a small fan (I think 60mm) right next to the power supply to keep it cool, in addition to the large fan that exhausts past the lamp. The fan runs non-stop as long as the unit is powered-up for two reasons I can think of - keep the power supply a little cooler, and the lamp a little warmer so there's not such a temp difference when it powers-up. Long story short, that fan had died. I replaced it with an aftermarket 60mm fan and it's been working fine ever since. Hope this helps.
Bob
Jun 03, 2008 | Epson PowerLite 5550C Multimedia Projector
Both Temp and Lamp lights blink red
All you should need to do is go to the menu on the projector, and find the Filter Timer. Hit the right arrow to select the filter time, and then hold the rest button on the projector until you are prompted to confirm the reset. Hit menu to confirm and it should now reset the filter timer. Now cut the projector off and back on and the lights should stop blinking. I hope this helps.
May 23, 2008 | ViewSonic PJ551 Multimedia Projector
Projector lamp flashes and the temp red led lights.
Purchased our76C in Jan, 2007. It is our second unit now that has had the same symptoms. When the unit starts up, the Power light is steady green as normal for a few minutes, but no image is projected. After a few minutes the lights do as you described. Both times Epson support authorized a new unit to be shipped out immediately. They said they had no known issues about it and didn't indicate what was causing the problem. Apparently it is not just the lamp wither. Also, the lamps both had under 20 hours on them.
Jun 17, 2007 | Epson PowerLite 7500 Multimedia Projector
Computers & Internet Logo
David Payne
David Payne
