Question about IBM X236 Server
Physical disk not found - IBM X236 Server
    Scholar:
  • 143 Answers
Move into Raid Controller bios (ctrl +c)
Check other hard drives are visible.
If yes, you may insert disk in other free slot and see if it detects on that slot. If same issue then particular hdd may be faulty. You have to replace it
If no, turn off server, reset scsi and power cables.
Turn on server and see if it detects hard drives. If server has same issue then either scsi cable or hdd back plane may be faulty. Chance is more for hdd back plane
Thanks
Posted on Oct 16, 2013
Operating sistem not found
  • The basic input/output system (BIOS) does not detect the hard disk.
  • The hard disk is damaged.
  • Sector 0 of the physical hard disk drive has an incorrect or malformed master boot record (MBR).
    Note Some third-party programs or disk corruption can damage an MBR especially some virus's.
  • An incompatible partition is marked as Active.
  • A partition that contains the MBR is no longer active.
If you can access the BIOS, check where 1st boot is. I have known some people to place something different in here and it will refuse to boot as it attempting to read hardware that does not exist.
Apr 03, 2014 | Microsoft Windows XP Home Edition
Lenovo c340 6 gb How To Setup
This issue may occur if one or more of the following conditions are true:
·The basic input/output system (BIOS) does not detect the hard disk.
·The hard disk is damaged.
·Sector 0 of the physical hard disk drive has an incorrect or malformed master boot record (MBR).
Note: Some third-party programs or disk corruption can damage an MBR.
·An incompatible partition is marked as Active.
·A partition that contains the MBR is no longer active.
Step 1: Check all hard disk and interface cables are properly connected and are in healthy state.
Follow the steps from: "Operating System Not Found" or "Missing operating system" error message when you start your Windows XP-based computer"http://support.microsoft.com/kb/321626
Or
Nov 11, 2013 | ErrorExpert
Operating system not found
It may happen due to following reasons:
To solve this problem follow this link:- solution
If you need any kind of technical assistance, you can contact support cell at http://www.vtechsquad.com
Sep 18, 2012 | HEWLETT-PACKARD Hewlett Packard Microsoft...
My disk drive is no longer recognizing that there is a disk in it. Is there any way I can fix it at home?
you might have to physically unplug the plug you cd rom back in this should activate the found new harware wizard or you might try
make sure that the cd rom is getting enough power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard or
you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general
Nov 24, 2010 | Compaq (120192-B21) CD-ROM Drive
My external harddisk - WD 320G(my passport essential) can not recoginze on Window 7. Please help to slove.
First check physical connections of hard disk to your cpu. Check in 'device manager' disk drives tab. If its found check in "disk management" in that drive which file system its showing. If it shows raw partition mean your file system is corrupted. It requires remove that partition and create a new partition.
for open device manager : start > run > devmgmt.msc
for disk management : start > run > diskmgmt.msc
Aug 04, 2010 | Western Digital 320GB MyBook External USB...
I have a operating system not found
    Note Some third-party programs or disk corruption can damage an MBR.
Contact your hardware manufacturerYour best bet may be to contact the manufacturer of your computer or your hard disk. The manufacturer may have a utility that you can use to perform a more detailed scan for damaged areas of the disk and help verify the correct BIOS settings. However, be aware that the damage to your hard disk may be serious. Sometimes this means that your only solution is to replace your hard disk.
Mar 05, 2010 | Sony VAIO VGN-AR630E Notebook
Every time i access a file my other hard disk my computer automatically restarts itself and performs a check disk on that same hard disk. there are times when i open my computer it also run a check disk...
run a surface scan to identify any potential physical flaws on the disk, if there are no sectors found corrupted then run defrag on the drive and then index it......let me know how well this helps.........also if you do find a physical error and it is in a cluster of memory, then you need to isolate the file and look into possibly repairing it to another sector or, simply disallowing access.
Let Me Know How It Goes............Good Luck and prepare to allow a good 30min to an hr for these processes to complete
Oct 13, 2009 | Computers & Internet
Scratching the discs plays some scratched others
This is a known issue. You have to contact Microsoft or if you bought it at a store with a warranty, you can take it there to exchange it.
Jul 09, 2009 | Microsoft Xbox 360 Console
When i turn my xboxon it says open tray it doesnt play the disks
Well actually all these "fixes" are not the problem.One day a friends console got the open tray error. after cleaning and all that i found that did absolutly nothing. after taking the entire drive apart i found that the laser / moter assembly was offset. this ment that the disk was tilted 1degree towards the laser and intern hittng the laser assembly that so many peopl think is "laser burn" which actualy is the disk physically hitting the laser. how u fix this is as easy as adjusting two screws were the moter and the laser/ tray assembly meat. now thses arnt nomal phillips, flat head or torx scews. i found that stickin a drill bit in the screw head annd turnin it with some pliers did the trick. this fixes the open tray error for good unless the disk is causing it. IF anyone gets open tray ocasionally this should stop it for good.
IBM X236 Server Logo
66 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
