Question about Lands Phones
My sony ericssonw58oi wont charge says needs sony battery. had battery and charger tested.
  • melody320u May 02, 2009
    No,I have had the same chip in since I got it.
  • Molly Harte May 11, 2010
    Have you installed any kind of memory chip recently? In other words if yes to that question did the problem starts after the installation of the chip? Let me know.
  • 26 Answers
Check for 'green' staining on charge port. Clean with alcohol , and retry. If this doesn't work , strip handset and clean pcb . Be careful of the mic.Remove battery during the cleaning phase
Posted on May 02, 2009
Why is my sony hvr hd camcoder not switching on
hi,
the fault should be in side the cam, start test from the charger connecting socket, measure the power in the mother board, if any of the fusible resistor or the regulator SMD found faulty, must replace.
Dec 01, 2015 | Sony HVR-HD1000U Camcorder
My victory 4 mobilty wont charge the green light is very faint/the charger was tested working.so why wont my scooter charge
make sure battery cables are secure at battery terminals and clean.how old are the batteries.If the batteries run down fast they are no good.a good way to test them is put scooter against some thing solid and go forward.If the battery indicator drops to o the batteries are no good.It takes about 10 hours to charge the batteries
Mar 15, 2013 | Pride New Mobility Victory XL 4 Wheel...
Charging led blinking
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it
with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
Dec 02, 2012 | HP Pavilion dv9000z Notebook
Its plug in but battery wont charge
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
Nov 28, 2012 | HP Compaq nc2400 Notebook
Wont charge tell me to insert sony battery
If Your battery wont charge instead it is requesting for You to enter a sony battery, then there is a problem somewhere that need to be checked. It is either the battery is bad and require You to replace it or the charger is not working fine or probably the phones connection port is bad. You need to run a test on the 3 before you can tell which is the problem. First run a test on the battery. To test the battery please follow the steps below:
  1. Turn off Your phone,
  2. Remove the battery,
  3. Insert it in another phone,
  4. Turn it on to see if it will ask you to insert a sony battery, if it does then it means the battery is bad and need to be replaced, but if it does not, then it means it is You phone that is not recognizing the battery,
To test the phone,
  1. Insert in another battery into Your phone,
  2. Power it on,
  3. Check if it will request for You to enter a sony battery, if it does, then it means the phone is faulty and the connection port is bad, but if it accepts the battery, then it means the phone is alright.
Finally, test the charger,
  1. Try to use it on another phone to see if it will charge,
  2. if it charges, then it means the charger is alright, but if it does not charge, then it means the phone is alright,
That way after carrying out the tests, you must have detected the problem and solved the problem.
Hope this helped. Thank You for using FixYa!!!
Jan 17, 2011 | Sony Ericsson Walkman® W995 Cell Phone
My Phone is not charging when i put it in the charger or use the usb. why is that?
There are three main things that could cause the problem. The battery, the charger and the phone. You need to carry out some tests to be able to tell which exactly is the cause of the problem and how to solve it.
First you need to check is the battery, insert it in another phone, then you try to charge the battery, if it charges, then it means the problem is from the battery, the solution to that is for you to replace the battery, but if it charges, then it means the problem is not from the battery.
Next thing to test is the charger, simply try to charge another phone using the charger. If it does not charges, then you know the problem is from the charger, but if it charges, then it means the problem is not from the charger.
Test the phone by using another charger on the phone to see if it charges, if it does not charge, then it means the phones connection port is bad and need to be replaced.
Hope this information helped.
Jan 09, 2011 | Sony Ericsson Walkman W980i Cellular Phone
Wont' stay on and wont' charge
If your telephone wont stay on and wont charge, then you need to carry out some test to know where the fault is from. First, test your battery if it is working by inserting it in another phone then charging it for about 3 hours then power on the phone to see if it will come on, if it does, then it means the battery is alright. But if it does not come on, then you know the battery is bad and needs to be replaced.
Now test the phone by inserting a well tested battery inside the phone then power it on, if it comes on, then the phone is alright, but if it does not come up, try to prop the battery so it will connect tightly with the terminal of the phone, then power it on, if it comes on, then it means the battery was loose and just need some propping, but if it still does not come on, then there is a problem with the phones power panel.
Test the charger also, by trying to charge another phone with it to see if it will work, if it charges, then it means the charger is alright and if it does not charge, then it means the charger is bad and need to be replaced.
After carying out these tests, you will be able to tell which component is faulty and needs replacement.
Take care and good luck
Dec 29, 2010 | Cell Phones
My psp wont turn on nor charge. even when i take out the battery and plug in the AC adapter it wont turn on.
hi, your problem could be one of a couple of things now the first and most likely would be that your charger is no longer working so you need to try another charger or try your charger on someone else psp.
the second problem you could have could be that the charging port has come away from the circuit board and if this is the case then you will need to get a new charging port soldered onto your circuit board, this isnt something you can do yourself.
now the third problem you could have is that a part has over heate on the circuit board causing a bad circuit usually the part that fails is just after the charging port so this would need testing to find out the exact cause.
first thing you should try is putting another battery in and see if it will come on with a new battery or try a friends battery in yours, if it comes on then you know the problem is going to be either the charger or the charging port, if after trying another battery it still dont work then the chances are something has over heated and the circuit board will need testing and parts replaced if needed.
the problem with this is it all depends on how much the cost of repair is going to be because it could cost more than a second hand psp.
you could take it into a a computer shop and get a free quote on the cost of repair.
you need to try the battery first try and find someone else who has got a working psp and try their battery in yours and also try their charger on yours just to find out if the charger id the problem, if you try someone elses charger and it dont charge yours up then the problem is going to be the charging port or parts associated with that.
May 23, 2010 | Sony PSP (Piano Black)
My t1200 wont charge and also when it was charging
Sounds like your charger is not working, also it could just be your battery is no good. To check if it is the charger,remove the battery and see if the computer works with just the charger, if it is, it is your battery.
Nov 28, 2009 | MPC Computers TransPort T1200 Notebook
Lands Phones Logo
48 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
