Question about Asko Washing Machines
Replaced burnt out main control panel
I have just replaced the main control panel as the small transformer and IC burnt out. The new panel appears to work properly but simply resets after about 40 seconds in any function. Is there something simple I am forgetting to reset?
  • 35 Answers
Did you reconnect and open the water supply?
Posted on Oct 15, 2013
Testimonial: "Yes water fills as normal but stops as mentioned after 40 seconds"
vest6
  • 196 Answers
SOURCE: washer stopped working
To help you with this problem I need you to do something. Place the machine in spin cycle and see if it will pump the water out. Also, lift the lid and look at the back. There should be a model/serial number plate. This information would help.
I do not believe the motor is at fault. I suspect a bad motor coupler. If the machine willpump the water out then I am Sure.
Posted on Jan 02, 2008
VOTIT
  • 2071 Answers
SOURCE: LL SIGNAL ON CONTROL PANEL
WHAT IS WRONG WITH YOUR WASHING MACHINE?
small_11_21.jpg For a detailed Washing Machine illustration, click below.
redarrow.gif Top Load Maytag Style
redarrow.gif Top Load Whirlpool Style
redarrow.gif Top Load GE Style
redarrow.gif Front Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Jul 30, 2008
SOURCE: display board not work
Solved problem. Replaced main Control Board. Works like a charm, hopefully willl last like one too!
Posted on Sep 03, 2009
SOURCE: We had a power surge at my house and now the
Here in New Zealand if that happens, I am often asked to provide a report stating that a Surge/Spike, had caused the damage, and the insurance Company will cover it? Can you do that? At least it will lessen costs, I charge for the report, but it's still a cheaper option if you can claim? Power Surges/Spikes usually totally wreck, the electronics... So replacement is only option... You may need a serviceman to check, and if OK write a report for your insurance?
Posted on Feb 27, 2010
blueextc3221
  • 15935 Answers
SOURCE: I replaced the coupler in my Kenmore washer Ultra Care I Heavy Duty Series 80 (MOdel # 110 92582220). Simple enough, remove front/side panel. Pull motor off (only 2 eletrical disconnects), replace, re
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
SAMSUNG UN65H7150AFXZA WAS ON WORKING OK. Left an when returned black screen with standby light on.
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
Dec 13, 2016 | Samsung Televison & Video
Nikki two channel display control is not working what's the cause?
Nov 23, 2016 | Televison & Video
Changing channels
Nov 15, 2016 | Televison & Video
I can't find channel auto scan
Nov 06, 2016 | Televison & Video
MY TV SAMSUNG D8000 RESTART CONSTANTLY
Nov 05, 2016 | Samsung Televison & Video
37lg30 lcd tv. screen appears bu images jumps and flashes.
Nov 04, 2016 | LG 37LG30 37 in. LCD HDTV
After I plug the tv in, the remote works all controls but wont control after 2 minutes of plugging my TV in. This is the second new TV of the same model this has happened to.
Mains system control memory IC fault. This is a very small IC; having 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go.
Sep 13, 2016 | Televison & Video
I can't turn on my TV, it scans all the time
Main system control memory IC fault. This is a very small IC, and can be replaced. Contact any service technician. The IC can be located very near to the main system control IC; at the main board. Will look somewhat like this.
Jan 20, 2015 | Televison & Video
Manual tuning in my new Akai LT-2204AB kills me. The programs won t lock in place, although i followed the instructions.
The main system memory IC to your TV has damaged. It should be replaced. It is a very small IC, having only 8 solder terminals. It can be located very near to the main system control IC. Even though it is very small in physical size, and chap to buy, replacing it on the main board is a skilled work indeed. Contact any experienced service technician.
Jul 26, 2012 | Televison & Video
I have a Jandy Aqualink RS system. The wires for one of the valve activators was shorted and the outdoor control panel and the indoor control panel lost power. None of the circuit breakers was tripped.
On the RS system there is a small fuse on the back of the circuit board. That may have been burnt. It acts as a safety for the transformer. Make sure ALL of the power is off, then check that fuse. Do not keep the shorted valve actuator plugged in. Replace it, or leave it disconnected. Then replace the fuse. Then re-apply power to the unit. Otherwise your transformer may go out next. If the fuse is not burnt, which would surprise me, you may have a burnt transformer.
Apr 04, 2011 | Jandy AQUALINK RS TELELINK KIT
Washing Machines Logo
51 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Joseph Hoffmann
marley mcelhinney
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
