Question about Digi-Tech Digitech Vocalist Live 4 Harmonizer
Behringer xenyx 2442fx mixer manual behrtnger
I have a output problem on the main outs one of the channels is not working also the cd/tape has a channel down can you help
I am trying to record from xenyx 2442fx to audacity. I am not sure how. I think it has something to do with usb, but do not know how to connect the mixer to the computer to get a good sound. Please help.
First, connect the USB audio interface which came with the Xenyx to a USB port on the PC. Then connect the TAPE OUT from the Xenyx to the IN of the USB audio interface. And connect the OUT of the USB audio interface to the TAPE IN of the Xenyx. You should now be able to record from any of the Xenyx channels. To listen back, engage the control room button which reads CD/TAPE. Contact me if you need any clarification.
Sep 06, 2011 | Behringer XENYX 2442FX Mixer
How to connect a Behringer XENYX 2442FX Mixer to a laptop
you need a cable with two A3F  XLR s going to a 1/8" stereo phone plug, male. plug the XLRs into the Main out L&R on the mixer. plug the 1/8" into the LINE Input on the laptop. You should be able to get the cable from any music store,or Radio Shack. below is a link to the manual,in case you don't have one. Good Luck!
http://www.behringer.com/assets/1622FX_P0557_M_EN.pdf
Aug 30, 2011 | Behringer XENYX 2442FX Mixer
How do i hook up a powered moniter to the behringer xenyx 2442fx mixer?
hook it up to one of the aux output sends (1 or 2), and use the corresponding aux send knob per channel to put each channel necesarry into the monitor signal.
Nov 20, 2010 | Behringer XENYX 2442FX Mixer
Need to connect to a sound blaster live sound card for recording using sonar as recording program. hace had it in storage for sometime and can't remember what went where
This particular mixer offers a usb (2 channel connection) that can be simply plugged into the computer usb 2.0. These channels should be available in Sonar from the channel Input/output drop boxes. You may need to restart Sonar, the mixer or both for them to be recognized. You may also need to run the Wav Profiler in Sonar. Typically the Wave Profiler is found in the Options>Audio menu but may be different on each edition of Sonar. The above info is for Sonar 7.
If you are wanting to record several channels at once then I would recommend connecting your Mixer's Direct Outputs from each channel to a corresponding input of the soundblaster if your soundblaster supports multiple channels. And then use the usb outbut from the Sonar to monitor the computer playback of your master stereo channel. Or, you may connect the soundblaster outputs to unused channels of the mixer or to the tape return or auxilary inputs to monitor the computer playback on the mixer.
Alternately you can send the signal to your soundblaster via the buss outputs. This will limit the number of simaltanious output channels to the number of busses on the mixer, but you can send any mixer channel to any buss without unplugging the instruments or mics.
Here's the link to the page where you can download the free pdf manual for this mixer. Page 14 explains the output connections and has diagrams.
http://www.behringer.com/EN/Products/2442FX.aspx
Oct 09, 2010 | Behringer XENYX 2442FX Mixer
How do I adjust the volume when I plug my mp3 player in to the phonos with out the main slider
In a word, you DON'T... The main fader is the ONLY volume control in the loop going into the TAPE inputs.
If you need another volume control, then either use volume control if availlable on the tape/MP3 player.
Your other option is to use a splitter cable from the MP3 into one of the stereo input channels which do have level controls.
Now if you want to have the tape input level INDEPENDENT of the main slider, that is not really possible either. Adding a mixer AFTER the mains could accomplish this, but that is extra hardware.
Aug 06, 2010 | Behringer XENYX 2442FX Mixer
I'm running a tape player into one of the mic channels, then out the tape out; problem is any stereo presence is lost. Is it possible to run a 1/8" to RCA in the RCA in, route that to the level meter/main...
Each mic channel is MONO. You could use a 1/8 stereo splitter cable into two mic channels and then PAN them opposite to retain the stereo.
You can also use a splitter cable into the 1/4 inch stereo inputs on the mixer. The 1/8 inch plug must be a stereo plug that then splits to two RCA plugs or two 1/4 inch plugs.
Note that the manual specifies that the Tape/CD out is merely paralleled off the mains out. This means that your main fader controls the level to the CD/TAPE output... which may mean your main output has to be too loud to get adequate output from the CD/TAPE outs to be effective. This would require balancing the levels into your external amp better.
Aug 05, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Digi-Tech Digitech Vocalist Live 4 Harmonizer Logo
21 people viewed this question
Top Digi-Tech Music Experts
rjivaro
Ben Armstrong
Are you a Digi-Tech Music Expert? Answer questions, earn points and help others
